problême d'install wine avec wineCVS.sh
Salut, puisque c’est le sujet ici, je me permet de m’imiscer dans la conversation afin de vous demander des eclaircissements sur ce message pdt l’installation de wineCVS.sh
--------- Error log - file /root/.WineCVS/sources/cvscedega/ErrorLog : ---------
./ppl.l:1337: warning: implicit declaration of function ‘max’
./ppl.l:1337: error: ‘ALLOCBLOCKSIZE’ undeclared (first use in this function)
./ppl.l: At top level:
./ppl.l:1346: warning: conflicting types for ‘macro_add_arg’
./ppl.l:1346: error: static declaration of ‘macro_add_arg’ follows non-static declaration
./ppl.l:493: error: previous implicit declaration of ‘macro_add_arg’ was here
./ppl.l: In function ‘macro_add_arg’:
./ppl.l:1349: error: ‘macexpstackentry_t’ undeclared (first use in this function)
./ppl.l:1349: error: ‘mep’ undeclared (first use in this function)
./ppl.l:1368: error: ‘debuglevel’ undeclared (first use in this function)
./ppl.l:1368: error: ‘DEBUGLEVEL_PPLEX’ undeclared (first use in this function)
./ppl.l:1370: error: ‘input_name’ undeclared (first use in this function)
./ppl.l:1371: error: ‘line_number’ undeclared (first use in this function)
./ppl.l:1378: error: ‘pp_macexp’ undeclared (first use in this function)
./ppl.l:1379: warning: implicit declaration of function ‘push_buffer’
./ppl.l: In function ‘macro_add_expansion’:
./ppl.l:1387: error: ‘macexpstackentry_t’ undeclared (first use in this function)
./ppl.l:1387: error: ‘mep’ undeclared (first use in this function)
./ppl.l:1396: error: ‘debuglevel’ undeclared (first use in this function)
./ppl.l:1396: error: ‘DEBUGLEVEL_PPLEX’ undeclared (first use in this function)
./ppl.l:1398: error: ‘input_name’ undeclared (first use in this function)
./ppl.l:1399: error: ‘line_number’ undeclared (first use in this function)
./ppl.l:1411: warning: conflicting types for ‘put_buffer’
./ppl.l:1411: error: static declaration of ‘put_buffer’ follows non-static declaration
./ppl.l:476: error: previous implicit declaration of ‘put_buffer’ was here
./ppl.l: In function ‘put_buffer’:
./ppl.l:1415: error: ‘pass_data’ undeclared (first use in this function)
./ppl.l: In function ‘do_include’:
./ppl.l:1439: error: ‘includelogicentry_t’ undeclared (first use in this function)
./ppl.l:1439: error: ‘iep’ undeclared (first use in this function)
./ppl.l:1441: error: ‘includelogiclist’ undeclared (first use in this function)
./ppl.l:1462: warning: implicit declaration of function ‘open_include’
./ppl.l:1462: warning: assignment makes pointer from integer without a cast
./ppl.l:1467: error: ‘seen_junk’ undeclared (first use in this function)
./ppl.l:1468: error: ‘include_state’ undeclared (first use in this function)
./ppl.l:1469: error: ‘include_ppp’ undeclared (first use in this function)
./ppl.l:1470: error: ‘pass_data’ undeclared (first use in this function)
./ppl.l:1473: error: ‘debuglevel’ undeclared (first use in this function)
./ppl.l:1473: error: ‘DEBUGLEVEL_PPMSG’ undeclared (first use in this function)
./ppl.l:1474: error: ‘input_name’ undeclared (first use in this function)
./ppl.l:1474: error: ‘line_number’ undeclared (first use in this function)
./ppl.l:1474: error: ‘include_ifdepth’ undeclared (first use in this function)
./ppl.l: In function ‘push_ignore_state’:
./ppl.l:1488: error: ‘pp_ignore’ undeclared (first use in this function)
make[2]: *** [lex.ppl.o] Erreur 1
make[2]: quittant le répertoire « /root/.WineCVS/sources/cvscedega/winex/tools/wrc »
make[1]: *** [wrc] Erreur 2
make[1]: quittant le répertoire « /root/.WineCVS/sources/cvscedega/winex/tools »
make: *** [tools] Erreur 2
Error in Make
Try fixing the error based on the output above, and
run the script again, without paramaters (Eg: WineCVS.sh)
Je ne sais pas ce que je dois faire la…
Merci d’avance!
A+
contrairement à ce que tu penses, ton post ne concernait pas la méthode propre d’installation qui était décrite dans le fil ou tu as posté.
Je me permets donc de rappatrier ton post dans le support pour que tu trouves plus de réponses.
Sinon, c’est quoi ce script wineCVS.sh ?
Tu ne serais pas en train d’installer un affreux logiciel non libre appelé cedega sur une belle debian libre ?
Je te rappelle que winex n’a rien à voir avec wine :wink:
Oups, dans le post en cours, j’avais cru lire un truc sur cedega… Désolé…
En fait, je suis effectivement en train d’installer ce logiciel affreux, mais c’est que pour mes etudes, il y a des logiciels que je dois absolument utiliser, donc…
Merci d’avoir rapatrié mon post!!
++ :wink:
Bon, sinon, j’ai essayé d’utiliser ce script et même j’ai réussi à force de corriger moi même le code et la config de compil à compiler et à fabriquer un paquet cedega gratuit basé sur le cvs (il y a une entrée de make pour faire un paquet debian). Je vais voir si je retrouve mon patch.
Je n’ai neanmoins jamais reussi à le faire tourner.
Je ne crois pas avoir vu quelquepart quelqu’un qui reussissait à utiliser la version gratuite depuis la fin des debats ou ils promettaient de continuer à la fournir gratuitement.
winex est donc comme ils ont promis disponible gratuitement, mais AMA inutilisable.
Ba c’est un peu bizarre cette politique…
Je dois faire comment pour reussir à faire marcher ce truc alors?!
Merci en tout cas de prendre du temps pour tester le script…
[quote=“born to dig”]Ba c’est un peu bizarre cette politique…
Merci en tout cas de prendre du temps pour tester le script…[/quote]Je veux dire que j’y ai passé déjà deux mois sans resultat il y a un an :laughing:
Je regarderais demain ce que j’avais trouvé.
Je crois que j’en ai parlé ici, tu devrais trouver des trucs en cherchant un peu.
Oki, je vais regarder ça…
merki
Je t’ai compilé ça, ça m’amusait de voir le pbm, j’ai compilé la version du 15/3/2007. Je te met le paquet sur http://boisson.homeip.net/sarge/winex_20070315-1_i386.deb
Les fichiers sont localisés dans /usr/local
Paquet non testé, compilé sur une sarge
OK. Bon, ben j’avais mis deux mois pour le même resultat. Ensuite faut m’expliquer comment ça s’utilise…
Je n’ai eu aucune erreur, je pense que leur cvs évolue et que j’ai eu du bol. Le ./configure, make a parfaitement fonctionné. Par contre pour l’utiliser, ça c’est une autre paire de manches…
