Problème installation MySql 8
Tags: #<Tag:0x00007f46b0a138a0>
Hellow , J’ ai un petit problème d installation de deux packet mysql-community-server et mysql-server
Voila le message d erreur
root@AzureWorkStation:/home/azure/Downloads# apt-get install mysql-server
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  festival festlex-cmu festlex-poslex festvox-kallpc16k guile-2.0-libs libaec0 libctemplate3 libdap23 libdapclient6v5 libdapserver7v5
  libepsilon1 libestools2.4 libfreexl1 libgc1c2 libgeotiff2 libgraphicsmagick-q16-3 libgsasl7 libhdf4-0-alt libhdf5-100 libjson-c3 libkmlbase1
  libkmlconvenience1 libkmldom1 libkmlengine1 libkmlregionator1 libkmlxsd1 libkyotocabinet16v5 libminizip1 libnetcdf11 libntlm0 libodbc1
  libogdi3.2 libosmgpsmap-1.0-1 libpcrecpp0v5 libproj12 libqhull7 libshp2 libspatialite7 libsz2 libtinyxml2.6.2v5 liburiparser1 libvsqlitepp3v5
  libxerces-c3.1 libzip4 mailutils-common odbcinst odbcinst1debian2 proj-bin proj-data python-paramiko python-pexpect python-ptyprocess
  python-pyodbc
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
  mysql-client mysql-common mysql-community-client mysql-community-client-core mysql-community-server mysql-community-server-core
The following NEW packages will be installed:
  mysql-client mysql-common mysql-community-client mysql-community-client-core mysql-community-server mysql-community-server-core mysql-server
0 upgraded, 7 newly installed, 0 to remove and 1 not upgraded.
Need to get 84.6 kB/20.3 MB of archives.
After this operation, 178 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://repo.mysql.com/apt/debian stretch/mysql-8.0 amd64 mysql-common amd64 8.0.17-1debian9 [84.6 kB]
Fetched 84.6 kB in 0s (306 kB/s)
Preconfiguring packages ...
Selecting previously unselected package mysql-common.
(Reading database ... 235950 files and directories currently installed.)
Preparing to unpack .../0-mysql-common_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-common (8.0.17-1debian9) ...
Selecting previously unselected package mysql-community-client-core.
Preparing to unpack .../1-mysql-community-client-core_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-community-client-core (8.0.17-1debian9) ...
Selecting previously unselected package mysql-community-client.
Preparing to unpack .../2-mysql-community-client_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-community-client (8.0.17-1debian9) ...
Selecting previously unselected package mysql-client.
Preparing to unpack .../3-mysql-client_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-client (8.0.17-1debian9) ...
Selecting previously unselected package mysql-community-server-core.
Preparing to unpack .../4-mysql-community-server-core_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-community-server-core (8.0.17-1debian9) ...
Selecting previously unselected package mysql-community-server.
Preparing to unpack .../5-mysql-community-server_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-community-server (8.0.17-1debian9) ...
Selecting previously unselected package mysql-server.
Preparing to unpack .../6-mysql-server_8.0.17-1debian9_amd64.deb ...
Unpacking mysql-server (8.0.17-1debian9) ...
Setting up mysql-common (8.0.17-1debian9) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Setting up mysql-community-client-core (8.0.17-1debian9) ...
Setting up mysql-community-server-core (8.0.17-1debian9) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up mysql-community-client (8.0.17-1debian9) ...
Setting up mysql-client (8.0.17-1debian9) ...
Setting up mysql-community-server (8.0.17-1debian9) ...
update-alternatives: using /etc/mysql/mysql.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Job for mysql.service failed because the control process exited with error code.
See "systemctl status mysql.service" and "journalctl -xe" for details.
invoke-rc.d: initscript mysql, action "start" failed.
● mysql.service - MySQL Community Server
   Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2019-10-03 04:18:58 CEST; 15ms ago
     Docs: man:mysqld(8)
           http://dev.mysql.com/doc/refman/en/using-systemd.html
  Process: 15935 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
  Process: 15899 ExecStartPre=/usr/share/mysql-8.0/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
 Main PID: 15935 (code=exited, status=1/FAILURE)
   Status: "Data Dictionary upgrade from MySQL 5.7 in progress"
    Error: 2 (No such file or directory)
Oct 03 04:18:57 AzureWorkStation systemd[1]: Starting MySQL Community Server...
Oct 03 04:18:58 AzureWorkStation systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
Oct 03 04:18:58 AzureWorkStation systemd[1]: Failed to start MySQL Community Server.
Oct 03 04:18:58 AzureWorkStation systemd[1]: mysql.service: Unit entered failed state.
Oct 03 04:18:58 AzureWorkStation systemd[1]: mysql.service: Failed with result 'exit-code'.
dpkg: error processing package mysql-community-server (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-community-server (= 8.0.17-1debian9); however:
  Package mysql-community-server is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 mysql-server
Que faire ???
Merci d’ avance
La version 5.7 * s’est installée sans problème , je vais rester sur cette version vu que je l’utilise pour le développement .
Juste une remarque:
le français ne s’écrit pas à l’oreille, il y a des règles pour que ceux qui lisent puissent comprendre ce que tu écris.
Par exemple, dans le cas cité, on écrit “la version 5.7 s’est installée sans problème”, et là on ne met plus une plombe à comprendre ce que tu as voulu dire.
Ceci dit, tout le monde n’as pas une orthographe parfaite, et ne faisant pas parti de ceux qui l’ont, j’ai farpaitement compris son message et je m’interroge donc :
Peut être que ce forum est réservé a une élite sortie d’un cursus littéraire ?
Alors déjà, je ne suis pas le forum.
Et en plus, je ne suis pas le dernier à faire des fautes, donc j’aurais beau jeu de les reprocher comme ça à d’autres.
Mais il y a des fautes qui piquent les yeux, et c’est bon de les relever de temps en temps, même quand ça vient de soi.
Bon, là, ça piquait, quoi.
