Problème installation pdc
Bonjour à tous.
Je suis novice en ce qui concerne le linux.
J’essaye de faire controleur de domaine avec Debian.
J’ai suivi les instruction suivante :
http://damstux.free.fr/wiki/index.php?title=PDC_Samba_LDAP#Installation_du_serveur_OpenLDAP
J’ai un gros problème quand j’arrive a : smbldap-populate
J’ai l’erreur suivante :
Using builtin directory structure Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 173. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 237. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 237. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. Use of uninitialized value in concatenation (.) or string at /usr/sbin/smbldap-populate line 275. entry dc=domaine,dc=local already exist. entry ou=Users,dc=domaine,dc=local already exist. entry ou=Groups,dc=domaine,dc=local already exist. entry ou=Machines,dc=domaine,dc=local already exist. entry ou=Idmap,dc=domaine,dc=local already exist. entry sambaDomainName=domaine,dc=domaine,dc=local already exist. Updating it... failed to modify entry: sambasid: value #0 invalid per syntax at /usr/sbin/smbldap-populate line 453, <GEN1> line 7. entry uid=Administrator,ou=Users,dc=domaine,dc=local already exist. entry uid=nobody,ou=Users,dc=domaine,dc=local already exist. entry cn=Domain Admins,ou=Groups,dc=domaine,dc=local already exist. entry cn=Domain Users,ou=Groups,dc=domaine,dc=local already exist. entry cn=Domain Guests,ou=Groups,dc=domaine,dc=local already exist. entry cn=Domain Computers,ou=Groups,dc=domaine,dc=local already exist. entry cn=Administrators,ou=Groups,dc=domaine,dc=local already exist. entry cn=Print Operators,ou=Groups,dc=domaine,dc=local already exist. entry cn=Backup Operators,ou=Groups,dc=domaine,dc=local already exist. entry cn=Replicators,ou=Groups,dc=domaine,dc=local already exist.
Les already exist sont normale vu que j’ai fait plusieurs fois la meme commande.
C’est :
que je pense qui casse tout.
Si vous avez eu le même problème, merci de répondre :stuck_out_tongue:
Merci a tous :slightly_smiling:
