Problème Intel Wireless AC-9260
Impossible d’installer ma carte wifi Wireless AC-9260
Pourtant:
# lshw -class network
  *-network NON-RÉCLAMÉ
       description: Network controller
       produit: Wireless-AC 9260
       fabriquant: Intel Corporation
       identifiant matériel: 0
       information bus: pci@0000:05:00.0
       version: 29
       bits: 64 bits
       horloge: 33MHz
       fonctionnalités: pm msi pciexpress msix cap_list
       configuration: latency=0
       ressources: mémoire:fc700000-fc703fff
  *-network
       description: Ethernet interface
       produit: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       fabriquant: Realtek Semiconductor Co., Ltd.
       information bus: pci@0000:06:00.0
       nom logique: enp6s0
       version: 16
       numéro de série: b4:2e:99:6f:f9:84
       taille: 1Gbit/s
       capacité: 1Gbit/s
       bits: 64 bits
       horloge: 33MHz
       fonctionnalités: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-0.deb11.7-amd64 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.50 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       ressources: irq:24 portE/S:f000(taille=256) mémoire:fc604000-fc604fff mémoire:fc600000-fc603fff
puis:
# dmesg | grep iwlwifi
[   10.403228] iwlwifi 0000:05:00.0: enabling device (0000 -> 0002)
[   10.444861] iwlwifi: probe of 0000:05:00.0 failed with error -110
# dmesg | grep -i wireless
[   10.391722] Intel(R) Wireless WiFi driver for Linux
# dpkg --list | egrep -i 'wireless|iwlwifi|intel' | awk '{ print $2 }'
firmware-iwlwifi
i965-va-driver:i386
intel-media-va-driver:i386
intel-microcode
iucode-tool
iw
libdrm-intel1:amd64
libdrm-intel1:i386
libibus-1.0-5:amd64
libigdgmm11:i386
libiw30:amd64
libmfx1:amd64
rfkill
whois
wireless-regdb
wireless-tools
xserver-xorg-video-intel
et noyau:
# uname -ar
Linux zargospc 6.1.0-0.deb11.7-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.20-2~bpo11+1 (2023-04-23) x86_64 GNU/Linux
# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: enp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether b4:2e:99:6f:f9:84 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.50/24 brd 192.168.1.255 scope global dynamic enp6s0
       valid_lft 42066sec preferred_lft 42066sec
    inet6 2a01:cb00:878a:2600:b62e:99ff:fe6f:f984/64 scope global dynamic mngtmpaddr
       valid_lft 86036sec preferred_lft 14036sec
    inet6 fe80::b62e:99ff:fe6f:f984/64 scope link
les firmwares installés sont en backports.
Je n’ai rien trouvé de probant sur l’erreur -110.
j’ai peur d’avoir un soucis avec le noyau.
S’il y a un double boot windows sur ce PC, il faut éventuellement désactiver le mode ‹ fast boot › / ‹ démarrage rapide › de windows qui peut préempter la carte wifi.
Autre piste, désactiver le Wake-on-LAN du BIOS.
Sinon, plutôt que de cumuler des backports, bookworm arrive, pour ne pas dire est là.
Ce n’est pas un problème de fast boot ou de wake on lan.
Déjà le Wake on lan est banni chez moi pour des raisons de sécurité.
et sinon le wifi a déjà fonctionné sur une précédente installation. mais je ne sais pas quelle est la raison ici de son non fonctionnement.
je n’arrive pas à identifier la cause de l’erreur (erreur -110) si la signification du code -110.
Pour background seulement: Intel(R) Wireless-AC 9260 and the Linux iwlwifi driver
 iwlwifi: probe of 0000:02:00.0 failed with error -110
 iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
Et à confirmer si le problème existe aussi lors d’un démarrage à froid, ou seulement après réveil de mise en veille (pour faire le parallèle avec ce problème connu sous windows).
sinon:
Intel® Wireless-AC 9260 4.14+ iwlwifi-9260-th-b0-jf-b0-34.618819.0.tgz
Last Reviewed : 10 mars 2023
je n’ai pas parlé de veille, et je n’utilise aucune mise en veille sur cette machine.
Je vais regarder tes liens.
