salut voila pour moii d ou peuvent venir les problems apres analyse de Xorg.0.log
Tout d a bord les fonts
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
Meme si malgrès tout:
*) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
D autre part et c 'ets surtout ca je pense qu il dot mettre sa vie pour cette raison:
(II) S3VIRGE(0): Not using default mode “640x350” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “320x175” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “640x400” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “320x200” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “720x400” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “360x200” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “640x480” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “320x240” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “800x600” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “400x300” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “800x600” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “400x300” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1024x768” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “512x384” (vrefresh out of range)
(II) S3VIRGE(0): Not using default mode “512x384” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1152x864” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “576x432” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1280x960” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “640x480” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1280x1024” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “640x512” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1600x1200” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “1792x1344” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “896x672” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1856x1392” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “928x696” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1920x1440” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “960x720” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “832x624” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “416x312” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1280x768” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “1280x800” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “640x400” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1152x768” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “1400x1050” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “700x525” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1440x900” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “720x450” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1600x1024” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “800x512” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1680x1050” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “840x525” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “1920x1200” (insufficient memory for mode)
(II) S3VIRGE(0): Not using default mode “960x600” (hsync out of range)
(II) S3VIRGE(0): Not using default mode “2048x1536” (insufficient memory for mode)
(II) S3VIRGE(0): Not using mode “1024x768” (no mode of this name)
(–) S3VIRGE(0): Virtual size is 800x600 (pitch 800)
() S3VIRGE(0): *Default mode “800x600”: 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) S3VIRGE(0): Modeline “800x600” 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
() S3VIRGE(0): Default mode “800x600”: 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) S3VIRGE(0): Modeline “800x600” 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
() S3VIRGE(0): Default mode “800x600”: 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) S3VIRGE(0): Modeline “800x600” 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
() S3VIRGE(0): Default mode “640x480”: 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) S3VIRGE(0): Modeline “640x480” 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
() S3VIRGE(0): Default mode “640x384”: 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) S3VIRGE(0): Modeline “640x384” 40.07 640 672 740 840 384 384 386 397 doublescan
() S3VIRGE(0): Default mode “576x384”: 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
(II) S3VIRGE(0): Modeline “576x384” 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync
() S3VIRGE(0): Default mode “512x384”: 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) S3VIRGE(0): Modeline “512x384” 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync
() S3VIRGE(0): Default mode “400x300”: 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) S3VIRGE(0): Modeline “400x300” 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
() S3VIRGE(0): Default mode “400x300”: 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) S3VIRGE(0): Modeline “400x300” 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
() S3VIRGE(0): Default mode “400x300”: 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) S3VIRGE(0): Modeline “400x300” 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
(**) S3VIRGE(0): Default mode “320x240”: 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) S3VIRGE(0): Modeline “320x240” 12.60 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
(++) S3VIRGE(0): DPI set to (96, 96)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
Voila aparement il teste 50000 modes differnets pour demarrer X
Donc je saisd pas trop quoi faire…
Parce que je me demande si resoudre ce probleme de lenteur au demarrage resoluerait les bugs d affichage…
Peut etre dans le dpkg-reconfigure xserver-xorg paser de s3virge a SVGA ou qqchose comm ca nop ?
merci de vos réponses
