Problème : mon wifi ne marche plus
Tags: #<Tag:0x00007f953b58a7a0>
en allumant mon pc portable ce matin, je me rend compte que mon wifi ne marche plus.
Peut-être que c’est dû à au dernier apt-get update;apt-get upgrade.
Donc je redémarre network-manager :
root@localhost:/var/log# /etc/init.d/network-manager restart
[ ok ] Stopping network connection manager: NetworkManager.
[ ok ] Starting network connection manager: NetworkManager.
=> donc là rien à signaler
Mais au niveau du syslog, voilà ce que j’ai :
root@localhost:/var/log# cat syslog
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> caught signal 15, shutting down normally.
Oct  1 14:28:06 localhost NetworkManager[3137]: <warn> quit request received, terminating...
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (wlan0): now unmanaged
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (wlan0): device state change: unavailable -> unmanaged (reason 'removed') [20 10 36]
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (eth0): now unmanaged
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (eth0): device state change: unavailable -> unmanaged (reason 'removed') [20 10 36]
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (eth0): cleaning up...
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> (eth0): taking down device.
Oct  1 14:28:06 localhost NetworkManager[3137]: <info> exiting (success)
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> NetworkManager (version 0.9.4.0) is starting...
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> Read config file /etc/NetworkManager/NetworkManager.conf
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: init!
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: update_system_hostname
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPluginIfupdown: management mode: unmanaged
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/net/wlan0, iface: wlan0)
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:09:00.0/net/eth0, iface: eth0)
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:09:00.0/net/eth0, iface: eth0): no ifupdown configuration found.
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/lo, iface: lo)
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: end _init.
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> Loaded plugin ifupdown: (C) 2008 Canonical Ltd.  To report bugs please use the NetworkManager mailing list.
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Oct  1 14:28:06 localhost NetworkManager[5148]:    Ifupdown: get unmanaged devices count: 0
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: (19197712) ... get_connections.
Oct  1 14:28:06 localhost NetworkManager[5148]:    SCPlugin-Ifupdown: (19197712) ... get_connections (managed=false): return empty list.
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing lutin ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'lutin'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing Wifi Villette ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'Wifi Villette'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing McDonald's France ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'McDonald's France'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing 00:0A:F7:0F:07:9E ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection '00:0A:F7:0F:07:9E'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing hotspot-cite-sciences ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'hotspot-cite-sciences'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing A9F1BDF1DAB1NVT4F4F59 ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'A9F1BDF1DAB1NVT4F4F59'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing Villette Pro ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'Villette Pro'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing Linksys ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'Linksys'
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile: parsing PJ-WIRELESS5 ...
Oct  1 14:28:06 localhost NetworkManager[5148]:    keyfile:     read connection 'PJ-WIRELESS5'
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> modem-manager is now available
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> monitoring kernel firmware directory '/lib/firmware'.
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> monitoring ifupdown state file '/run/network/ifstate'.
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> found WiFi radio killswitch rfkill0 (at /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/ieee80211/phy0/rfkill0) (driver (unknown))
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> WiFi enabled by radio killswitch; disabled by state file
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> WWAN enabled by radio killswitch; enabled by state file
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> WiMAX enabled by radio killswitch; enabled by state file
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> Networking is enabled by state file
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): using nl80211 for WiFi device control
Oct  1 14:28:06 localhost NetworkManager[5148]: <warn> (wlan0): driver supports Access Point (AP) mode
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): new 802.11 WiFi device (driver: 'ath9k' ifindex: 3)
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/0
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): now managed
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): bringing up device.
Oct  1 14:28:06 localhost NetworkManager[5148]: <info> (wlan0): deactivating device (reason 'managed') [2]
Oct  1 14:28:07 localhost NetworkManager[5148]: <warn> failed to allocate link cache: (-10) Operation not supported
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): carrier is OFF
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): new Ethernet device (driver: 'r8169' ifindex: 2)
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): exported as /org/freedesktop/NetworkManager/Devices/1
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): now managed
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): bringing up device.
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): preparing device.
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> (eth0): deactivating device (reason 'managed') [2]
Oct  1 14:28:07 localhost NetworkManager[5148]: <info> Added default wired connection 'Connexion filaire 1' for /sys/devices/pci0000:00/0000:00:1c.2/0000:09:00.0/net/eth0
Oct  1 14:28:07 localhost kernel: [  230.181637] r8169 0000:09:00.0: eth0: link down
Oct  1 14:28:07 localhost kernel: [  230.182204] ADDRCONF(NETDEV_UP): eth0: link is not ready
En scannant les interfaces, voici ce que j’ai :
root@localhost:/var/log# iwlist scan
lo        Interface doesn't support scanning.
wlan0     Interface doesn't support scanning : Network is down
eth0      Interface doesn't support scanning.
Interface doesn’t support scanning : Network is down => donc j’ai relancer wlan0
ifconfig wlan0 down
ifconfig wlan0 up
Mais syslog me répond par ceci :
Oct  1 15:19:55 localhost kernel: [  661.457314] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mais au moins avec ifconfig wlan0 down/ifconfig wlan0 up, le wlan0 est devenu scannable (mais les informations sont trop bizarre avec des unknow partout :
root@localhost:/var/log# iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: 00:1A:30:8E:6F:55
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=42/70  Signal level=-68 dBm
                    Encryption key:on
                    ESSID:"\x00"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
                              11 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=000005e879e5818d
                    Extra: Last beacon: 840ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 010882040B0C12161824
                    IE: Unknown: 030101
                    IE: Unknown: 050400010000
                    IE: Unknown: 0706465220010D17
                    IE: Unknown: 0B0504000B8D5B
                    IE: Unknown: 2A0104
                    IE: Unknown: 32043048606C
                    IE: Unknown: 851E05008F000F00FF0359007267303030342D61702D7075622D320004000027
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                        Authentication Suites (1) : PSK
                    IE: Unknown: DD06004096010104
                    IE: Unknown: DD050040960305
                    IE: Unknown: DD050040960B09
                    IE: Unknown: DD050040961400
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
          Cell 02 - Address: 00:1A:30:8E:6F:51
                    Channel:1
                    Quality=39/70  Signal level=-71 dBm
                    Encryption key:off
                    ESSID:"hotspot-cite-sciences"
                    Mode:Master
                    Extra:tsf=000005e879e585dc
                    Extra: Last beacon: 824ms ago
                    IE: Unknown: 0015686F7473706F742D636974652D736369656E636573
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 3603616603
          Cell 03 - Address: 00:1A:30:8E:6F:52
                    Channel:1
                    Encryption key:on
                    ESSID:"lutin"
                    Mode:Master
                    Extra:tsf=000005e879e41dae
                    Extra: Last beacon: 892ms ago
                    IE: Unknown: 00056C7574696E
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 04 - Address: B4:E9:B0:5D:A4:90
                    Channel:1
                    Quality=26/70  Signal level=-84 dBm
                    Encryption key:off
                    Mode:Master
                    Extra:tsf=000007a271df3960
                    Extra: Last beacon: 920ms ago
                    IE: Unknown: 010882848B0C12961824
                    IE: Unknown: 030101
                    IE: Unknown: 0706465220010D14
                    IE: Unknown: 0B050000338D5B
                    IE: Unknown: 2A0100
                    IE: Unknown: 2D1AAC191BFFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D1601000500000000000000000000000000000000000000
                    IE: Unknown: 851E01008F000F00FF0359007372303035382D61702D7075622D330000000040
                    IE: Unknown: 9606004096000A00
          Cell 05 - Address: 00:1A:30:8E:6F:53
                    Channel:1
                    Quality=32/70  Signal level=-78 dBm
                    Encryption key:on
                    ESSID:"\x00"
                    Mode:Master
                    Extra:tsf=000005e879e586d3
                    Extra: Last beacon: 848ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Authentication Suites (1) : 802.1x
          Cell 06 - Address: 00:1A:30:8D:40:92
                    Channel:5
                    Frequency:2.432 GHz (Channel 5)
                    Quality=20/70  Signal level=-90 dBm
                    Encryption key:on
                    ESSID:"lutin"
                    Mode:Master
                    Extra:tsf=0000018fb4a0b190
                    Extra: Last beacon: 624ms ago
                    IE: Unknown: 030105
                    IE: Unknown: 2A0100
                    IE: Unknown: 851E03008F000F00FF0359007267303030342D61702D7075622D330003000027
                    IE: Unknown: 9606004096001100
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 07 - Address: 00:1A:30:8D:40:94
                    Channel:5
                    Quality=24/70  Signal level=-86 dBm
                    Encryption key:on
                    ESSID:"billwifi"
                    Mode:Master
                    Extra:tsf=0000018fb49fec4c
                    Extra: Last beacon: 664ms ago
                    IE: Unknown: 000862696C6C77696669
                    IE: Unknown: 030105
                    IE: Unknown: 2A0100
                    IE: Unknown: 851E03008F000300070059007267303030342D61702D7075622D330003000027
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 08 - Address: 00:1A:30:8F:D0:62
                    Channel:5
                    Quality=29/70  Signal level=-81 dBm
                    Encryption key:on
                    ESSID:"lutin"
                    Mode:Master
                    Extra:tsf=000005e87b842f3c
                    Extra: Last beacon: 668ms ago
                    IE: Unknown: 030105
                    IE: Unknown: 2A0104
                    IE: Unknown: 851E07008F000F00FF0359007372303131322D61702D70756200000004000027
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 09 - Address: 00:1A:30:8F:D0:61
                    Channel:5
                    Quality=27/70  Signal level=-83 dBm
                    Encryption key:off
                    Mode:Master
                    Extra:tsf=000005e87b848719
                    IE: Unknown: 030105
                    IE: Unknown: 0B050400188D5B
                    IE: Unknown: 2A0104
          Cell 10 - Address: 00:1A:30:8D:40:93
                    Channel:5
                    Quality=25/70  Signal level=-85 dBm
                    Encryption key:on
                    ESSID:"\x00"
                    Mode:Master
                    Extra:tsf=0000018fb4a0b18d
                    Extra: Last beacon: 672ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 030105
                    IE: Unknown: 2A0100
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD050040961401
          Cell 11 - Address: 00:18:B9:2A:C3:81
                    Channel:9
                    Frequency:2.452 GHz (Channel 9)
                    Quality=56/70  Signal level=-54 dBm
                    Encryption key:off
                    Mode:Master
                    Extra:tsf=000005e8731e53b9
                    Extra: Last beacon: 392ms ago
                    IE: Unknown: 030109
                    IE: Unknown: 0B0506000D8D5B
                    IE: Unknown: 2A0106
                    IE: Unknown: 851E03008F000F00FF0359007267303030342D61702D70756200000006000025
          Cell 12 - Address: 00:18:B9:2A:C3:82
                    Channel:9
                    Encryption key:on
                    ESSID:"lutin"
                    Mode:Master
                    Extra:tsf=000005e8731dfbe1
                    Extra: Last beacon: 388ms ago
                    IE: Unknown: 030109
                    IE: Unknown: 2A0106
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 13 - Address: 00:18:B9:2A:C3:83
                    Channel:9
                    Quality=52/70  Signal level=-58 dBm
                    Encryption key:on
                    ESSID:"\x00"
                    Mode:Master
                    Extra:tsf=000005e8731d9193
                    Extra: Last beacon: 464ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 030109
                    IE: Unknown: 2A0106
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 14 - Address: 24:77:03:51:97:05
                    Channel:9
                    Quality=28/70  Signal level=-82 dBm
                    Encryption key:on
                    ESSID:"WIN-TRL5OM52KDI-33010"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                    Mode:Master
                    Extra:tsf=01cebe9b7d0a0393
                    Extra: Last beacon: 444ms ago
                    IE: Unknown: 001557494E2D54524C354F4D35324B44492D3333303130
                    IE: Unknown: 01088C129824B048606C
                    IE: Unknown: 030109
                    IE: Unknown: 050402030000
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: DD790050F204104A0001101044000102103B000103104700107406C292E267004FB1D626FE7F70170910210011496E74656C20436F72706F726174696F6E10230014496E74656C2852292043656E7472696E6F285229102400012D104200012D1054000800010050F20400011011000556454E555310080002008C
                    IE: Unknown: 2D1A040017FFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D1609080300000000000000000000000000000000000000
                    IE: Unknown: DD0B0017350101000000000000
          Cell 15 - Address: 00:18:B9:2A:C3:85
                    Channel:9
                    Quality=51/70  Signal level=-59 dBm
                    Encryption key:on
                    ESSID:"\x00"
                    Mode:Master
                    Extra: Last beacon: 452ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 030109
                    IE: Unknown: 2A0106
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 16 - Address: FE:99:93:39:FC:C7
                    Channel:10
                    Frequency:2.457 GHz (Channel 10)
                    Quality=34/70  Signal level=-76 dBm
                    Encryption key:on
                    ESSID:"A9F1BDF1DAB1NVT4F4F59"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s
                    Mode:Ad-Hoc
                    Extra:tsf=0000000564096f12
                    Extra: Last beacon: 384ms ago
                    IE: Unknown: 00154139463142444631444142314E5654344634463539
                    IE: Unknown: 010482848B96
                    IE: Unknown: 03010A
                    IE: Unknown: 06020000
          Cell 17 - Address: 00:1A:30:8F:D0:63
                    Channel:5
                    Encryption key:on
                    ESSID:"\x00"
                    Mode:Master
                    Extra:tsf=000005e87b85218f
                    Extra: Last beacon: 652ms ago
                    IE: Unknown: 000100
                    IE: Unknown: 030105
                    IE: Unknown: 2A0104
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 18 - Address: 00:1A:30:8D:40:91
                    Channel:5
                    Encryption key:off
                    Mode:Master
Une idée ? Merci beaucoup.
Post scriptum :
Voici mon fichier /etc/network/interfaces (que je n’ai pas touché) :
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
#allow-hotplug eth0
#iface eth0 inet dhcp
Voici ma carte wifi et ma carte ethernet
# lspci
08:00.0 Network controller: Atheros Communications Inc. AR9485 Wireless Network Adapter (rev 01)
=> Ma carte wifi
09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 07)
=> Ma carte éthernet
J’ai aussi réinstallé le noyau et l’intramfs avec le paquets .deb de linux-image-amd64 et linux-image-2.6-amd64,
network-manager, network-manager-gnome, et firmware-realtek, mais ça n’a pas changé mon problème.
Sinon, il y aurait-il un moyen d’avoir l’avant dernère version de network-manager (downgrade) ?
Je n’ai plus l’avant dernière version dans mon cache.
pour confirmer que ça vient bien d’un problème de network manager, essaie de le désactiver et de configurer ton interface à la main, en CLI.
Ton wlan0 est désactivé lors de la config:
on dirait que c’est lié à un bouton d’activation
[quote=“fluo”]Sinon, il y aurait-il un moyen d’avoir l’avant dernère version de network-manager (downgrade) ?
Je n’ai plus l’avant dernière version dans mon cache.[/quote]
Oui, c’est tout à fait possible avec les snapshots : snapshot.debian.org/
Rien à voir avec ce soucis bien décrit par fluo…
…Dans un précédent fil sur un problème de wifi, quelqu’un a dit se coller à une page de wiki sur les soucis de wifis. Est-ce l’un(e) d’entre vous ? Quelqu’un aurait un lien ? Les soucis de wifi sont bien récurrents.
Ici :
http://www.isalo.org/wiki.debian-fr/Mon_wifi_ne_marche_pas!
Auteur(e)s : Agentsteel et Goodluck47
Désolé de polluer en faisant les questions et les réponses… pour ne pas résoudre le soucis du fil :wink: À sortir au prochain problème de wifi au besoin…
Bon, j’ai testé le noyau de la version précédente (merci à thunban pour snapshot.debian.org) et le noyau backports, et même les firmwares non-libres correspondants, mais mon wifi ne marche toujours pas. Je sais que ma carte wifi n’est pas cassé car le wifi marche avec le CD live de debian.
Donc je suis revenus sur la dernière version stable de wheezy. Mon interrupteur wifi est toujours allumé (sur on).
J’arrive à cerner les logs de wlan0 mais je n’arrive pas à les interpréter, à savoir :
-quand je fait /etc/init.d/network-manager restart, pour wlan0 syslog me répond :
root@localhost:/var/log# cat syslog | grep -i wlan
Oct  2 17:30:31 localhost NetworkManager[3428]: <info> (wlan0): now unmanaged
Oct  2 17:30:31 localhost NetworkManager[3428]: <info> (wlan0): device state change: unavailable -> unmanaged (reason 'removed') [20 10 36]
Oct  2 17:30:31 localhost NetworkManager[5754]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/net/wlan0, iface: wlan0)
Oct  2 17:30:31 localhost NetworkManager[5754]:    SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): using nl80211 for WiFi device control
Oct  2 17:30:31 localhost NetworkManager[5754]: <warn> (wlan0): driver supports Access Point (AP) mode
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): new 802.11 WiFi device (driver: 'ath9k' ifindex: 3)
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/0
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): now managed
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): bringing up device.
Oct  2 17:30:31 localhost NetworkManager[5754]: <info> (wlan0): deactivating device (reason 'managed') [2]
Quand je tape ifconfig wlan0 up, syslog me répond :
Oct  2 17:31:20 localhost kernel: [  566.953443] ADDRCONF(NETDEV_UP): wlan0: link is not ready
ça me tue vraiment. Une idée ?
pas d’idée, j’ai essayé de chercher sur
sans succés.
Essaie de changer de network manager (wicd par exemple)
Punaise, je mérite vraiment des baffes :blush: :079
Il fallait faire clic droit sur l’icone de network-manager dans le tableau de bord, et cocher “Activer le réseau sans fil”, et le problème est résolu.
Cela dit, ça c’est la solution “graphique”, alors que j’aurais voulu la solution cli.
Merci 1000 fois à toux ceux qui m’on aidé dans ce fil.
