Problème réception de mail avec Postfix
Tags: #<Tag:0x00007f46a760ae88> #<Tag:0x00007f46a760ad48> #<Tag:0x00007f46a760ac30>
Bonjour j’arrive pas à recevoir de mail sur mon serveur mail qui tourne sur PostFix.
Apr 17 21:39:59 minzord postfix/submission/smtpd[28203]: connect from forward102o.mail.yandex.net[37.140.190.182]
Apr 17 21:39:59 minzord postfix/submission/smtpd[28203]: NOQUEUE: reject: RCPT from forward102o.mail.yandex.net[37.140.190.182]: 554 5.7.1 <forward102o.mail.yandex.net[37.140.190.182]>: Client host rejected: Access denied; from=<florianb3522@yandex.ru> to=<contact@minzord.eu.org> proto=ESMTP helo=<forward102o.mail.yandex.net>
root@minzord:~# postconf -n
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
compatibility_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
home_mailbox = Maildir/
inet_protocols = all
mailbox_command =
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
mua_client_restrictions = permit_sasl_authenticated, reject
mua_helo_restrictions = permit_mynetworks, reject_non_fqdn_hostname, reject_invalid_hostname, permit
mua_sender_restrictions = permit_sasl_authenticated, reject
mydestination = $myhostname, localhost.$mydomain, localhost
mydomain = minzord.eu.org
myhostname = minzord.eu.org
mynetworks = 127.0.0.0/8
myorigin = $myhostname
newaliases_path = /usr/bin/newaliases.postfix
readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES
relayhost =
sample_directory = /usr/share/doc/postfix-2.10.1/samples
sendmail_path = /usr/sbin/sendmail.postfix
smtpd_banner = $myhostname ESMTP $mail_name
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_rbl_client cbl.abuseat.org, permit Restrictions SMTP
smtpd_helo_restrictions = permit_sasl_authenticated, reject_invalid_helo_hostname, reject_non_fqdn_helo_hostname, reject_unknown_helo_hostname
smtpd_recipient_restrictions = permit_mynetworks, permit_auth_destination, permit_sasl_authenticated, reject
smtpd_restriction_classes = mua_sender_restrictions, mua_client_restrictions, mua_helo_restrictions
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $myhostname
smtpd_sasl_path = private/auth
smtpd_sasl_security_options = noanonymous
smtpd_sasl_type = dovecot
smtpd_tls_auth_only = yes
smtpd_tls_cert_file = /etc/letsencrypt/live/minzord.eu.org/cert.pem
smtpd_tls_key_file = /etc/letsencrypt/live/minzord.eu.org/privkey.pem
smtpd_tls_session_cache_database = btree:/etc/postfix/smtpd_scache
smtpd_use_tls = yes
# Postfix master process configuration file.  For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type  private unpriv  chroot  wakeup  maxproc command + args
#               (yes)   (yes)   (no)    (never) (100)
smtp            inet      n      -       n       -       -        smtpd
  -o syslog_name=postfix/submission
  -o smtpd_tls_security_level=encrypt
  -o smtpd_sasl_auth_enable=yes
  -o smtpd_reject_unlisted_recipient=no
  -o smtpd_client_restrictions=$mua_client_restrictions
  -o smtpd_helo_restrictions=$mua_helo_restrictions
  -o smtpd_sender_restrictions=$mua_sender_restrictions
  -o smtpd_recipient_restrictions=
  -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
  -o milter_macro_daemon_name=ORIGINATING
587            inet      n      -       n       -       -        smtpd
#628       inet  n       -       y       -       -       qmqpd
pickup    unix  n       -       y       60      1       pickup
cleanup   unix  n       -       y       -       0       cleanup
qmgr      unix  n       -       n       300     1       qmgr
#qmgr     unix  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       y       1000?   1       tlsmgr
rewrite   unix  -       -       y       -       -       trivial-rewrite
bounce    unix  -       -       y       -       0       bounce
defer     unix  -       -       y       -       0       bounce
trace     unix  -       -       y       -       0       bounce
verify    unix  -       -       y       -       1       verify
flush     unix  n       -       y       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       y       -       -       smtp
relay     unix  -       -       y       -       -       smtp
    -o syslog_name=postfix/$service_name
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       y       -       -       showq
error     unix  -       -       y       -       -       error
retry     unix  -       -       y       -       -       error
discard   unix  -       -       y       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       y       -       -       lmtp
anvil     unix  -       -       y       -       1       anvil
scache    unix  -       -       y       -       1       scache
postlog   unix-dgram n  -       n       -       1       postlogd
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent.  See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
#   lmtp    cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
#  mailbox_transport = lmtp:inet:localhost
#  virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus     unix  -       n       n       -       -       pipe
#  user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix  -       n       n       -       -       pipe
#  flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix	-	n	n	-	2	pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
  ${nexthop} ${user}
dovecot   unix  -       n       n       -       -       pipe
  flags=DRhu user=email:email argv=/usr/lib/dovecot/deliver -f ${sender} -d ${recipient}
L’extrait des logs indique que le courriel est envoyé depuis un compte Yandex. Dans ce cas c’est le serveur SMTP de Yandex qui transfère le courriel à ton MTA (SMTP).
Cela ne fonctionne pas car ton serveur n’est pas configuré correctement pour faire du SMTP sur le port 25. Toutes les règles que tu as ajouté au service smtp dans ton master.cf empêchent les autres serveurs de transmettre les courriels au tien : en particulier l’authentification SASL obligatoire.
Tu devrais avoir (avec submission plutôt que 587):
smtp      inet  n       -       -       -       -       smtpd
submission inet n       -       y       -       -       smtpd
Il y a aussi une erreur sur les règles à la fin de la ligne :
Sa fonctionne merci beaucoup.
