Salut à tous
Voilà un petit moment que je cherche comment intégrer un monitoring de mes daemons dans mon conky .
a force de longue fouille j’ai trouvé EZ monitor qui a tous ce qu’il faut ! et meme trop pour moi justement
je cherche donc a reduire le script pour n’avoir en sortie que le résultat de " services" soit l’équivalent d’un # ./ezmonitor.sh -e
et sans l’option -e car conky ne les acceptes pas .
voici le script EZ monitor en entier
#!/bin/bash
# eZ Server Monitor `sh #
# @name eZ Server Monitor `sh #
# @author ShevAbam #
# @website ezservermonitor.com #
# @created 18 Sept 2015 #
# @version 2.2 #
# * [ CONFIG ] * #
# Disk usage - Show or hide virtual mountpoints (tmpfs)
DISK_SHOW_TMPFS=false
# Service who returns WAN IP
GET_WAN_IP="http://www.ezservermonitor.com/myip"
# Hosts to ping
PING_HOSTS=("google.com" "facebook.com" "yahoo.com")
# Services port number to check
# syntax :
# SERVICES_NAME[port_number]="label"
# SERVICES_HOST[port_number]="localhost"
SERVICES_NAME[21]="FTP Server"
SERVICES_HOST[21]="localhost"
SERVICES_NAME[22]="SSH"
SERVICES_HOST[22]="localhost"
SERVICES_NAME[80]="Web Server"
SERVICES_HOST[80]="localhost"
SERVICES_NAME[3306]="Database"
SERVICES_HOST[3306]="localhost"
# Temperatures blocks (true for enable)
TEMP_ENABLED=false
# * [ VARS ] * #
# Constants -- DON'T TOUCH !!
ESM_NAME="eZ Server Monitor \`sh"
ESM_VERSION="2.2"
ESM_AUTHOR="ShevAbam"
ESM_CREATED="18 September 2015"
ESM_URL="http://www.ezservermonitor.com"
# Colors
NC="\e[0m"
RED="\e[31;40m"
GREEN="\e[32;40m"
YELLOW="\e[33;40m"
WHITE="\e[37;40m"
# Styles
BOLD="\e[1m"
RESET="\e[0m"
WHITE_ON_GREY="\e[100;97m"
# * [ FUNCTIONS ] * #
function makeTitle()
echo -e "${BOLD}${WHITE_ON_GREY} $1 ${RESET}"
# Function : system
function system()
OS=`uname -s`
if [ -e "/usr/bin/lsb_release" ] ; then
DISTRO=`/usr/bin/lsb_release -ds`
elif [ -e "/etc/system-release" ] ; then
DISTRO=`cat /etc/system-release`
else
DISTRO=`find /etc/*-release -type f -exec cat {} \; | grep NAME | tail -n 1 | cut -d= -f2 | tr -d '"'`;
fi
HOSTNAME=`hostname`
KERNEL_INFO=`/bin/uname -r`
UPTIME=`cat /proc/uptime`
UPTIME=${UPTIME%%.*}
UPTIME_MINUTES=$(( UPTIME / 60 % 60 ))
UPTIME_HOURS=$(( UPTIME / 60 / 60 % 24 ))
UPTIME_DAYS=$(( UPTIME / 60 / 60 / 24 ))
LAST_BOOT_DATE=`who -b | awk '{print $3}'`
LAST_BOOT_TIME=`who -b | awk '{print $4}'`
USERS_NB=`who | wc -l`
CURRENT_DATE=`/bin/date '+%F %T'`
makeTitle "System"
echo -e "${GREEN} Hostname\t ${WHITE}$HOSTNAME"
echo -e "${GREEN} OS\t\t ${WHITE}$OS $DISTRO"
echo -e "${GREEN} Kernel\t ${WHITE}$KERNEL_INFO"
echo -e "${GREEN} Uptime\t ${WHITE}$UPTIME_DAYS day(s), $UPTIME_HOURS hours(s), $UPTIME_MINUTES minute(s)"
echo -e "${GREEN} Last boot\t ${WHITE}$LAST_BOOT_DATE $LAST_BOOT_TIME"
echo -e "${GREEN} Current user(s) ${WHITE}$USERS_NB connected"
echo -e "${GREEN} Server datetime ${WHITE}$CURRENT_DATE"
# Function : load average
function load_average()
PROCESS_NB=`ps -e h | wc -l`
PROCESS_RUN=`ps r h | wc -l`
CPU_NB=`cat /proc/cpuinfo | grep "^processor" | wc -l`
LOAD_1=`cat /proc/loadavg | awk '{print $1}'`
# LOAD_1_PERCENT=`echo $LOAD_1 | awk '{print 100 * $1}'`
LOAD_1_PERCENT=`echo $(($(echo $LOAD_1 | awk '{print 100 * $1}') / $CPU_NB))`
if [ $LOAD_1_PERCENT -ge 100 ] ; then
LOAD_1_PERCENT=100;
fi
if [ $LOAD_1_PERCENT -ge 75 ] ; then
LOAD_1_COLOR=${RED}
elif [ $LOAD_1_PERCENT -ge 50 ] ; then
LOAD_1_COLOR=${YELLOW}
else
LOAD_1_COLOR=${WHITE}
fi
LOAD_2=`cat /proc/loadavg | awk '{print $2}'`
# LOAD_2_PERCENT=`echo $LOAD_2 | awk '{print 100 * $1}'`
LOAD_2_PERCENT=`echo $(($(echo $LOAD_2 | awk '{print 100 * $1}') / $CPU_NB))`
if [ $LOAD_2_PERCENT -ge 100 ] ; then
LOAD_2_PERCENT=100;
fi
if [ $LOAD_2_PERCENT -ge 75 ] ; then
LOAD_2_COLOR=${RED}
elif [ $LOAD_2_PERCENT -ge 50 ] ; then
LOAD_2_COLOR=${YELLOW}
else
LOAD_2_COLOR=${WHITE}
fi
LOAD_3=`cat /proc/loadavg | awk '{print $3}'`
# LOAD_3_PERCENT=`echo $LOAD_3 | awk '{print 100 * $1}'`
LOAD_3_PERCENT=`echo $(($(echo $LOAD_3 | awk '{print 100 * $1}') / $CPU_NB))`
if [ $LOAD_3_PERCENT -ge 100 ] ; then
LOAD_3_PERCENT=100;
fi
if [ $LOAD_3_PERCENT -ge 75 ] ; then
LOAD_3_COLOR=${RED}
elif [ $LOAD_3_PERCENT -ge 50 ] ; then
LOAD_3_COLOR=${YELLOW}
else
LOAD_3_COLOR=${WHITE}
fi
echo
makeTitle "Load Average"
echo -e "${GREEN} Since 1 minute $LOAD_1_COLOR $LOAD_1_PERCENT% ($LOAD_1)"
echo -e "${GREEN} Since 5 minutes $LOAD_2_COLOR $LOAD_2_PERCENT% ($LOAD_2)"
echo -e "${GREEN} Since 15 minutes $LOAD_3_COLOR $LOAD_3_PERCENT% ($LOAD_3)"
echo -e "${GREEN} Processus\t ${WHITE}$PROCESS_NB process, including $PROCESS_RUN running"
# Function : CPU
function cpu()
CPU_NB=`cat /proc/cpuinfo | grep -i "^processor" | wc -l`
CPU_INFO=`cat /proc/cpuinfo | grep -i "^model name" | awk -F": " '{print $2}' | head -1 | sed 's/ \+/ /g'`
CPU_FREQ=`cat /proc/cpuinfo | grep -i "^cpu MHz" | awk -F": " '{print $2}' | head -1`
if [ -z $CPU_FREQ ] ; then
CPU_FREQ=`cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq`
CPU_FREQ=$(( $CPU_FREQ / 1000 ))
fi
CPU_CACHE=`cat /proc/cpuinfo | grep -i "^cache size" | awk -F": " '{print $2}' | head -1`
CPU_BOGOMIPS=`cat /proc/cpuinfo | grep -i "^bogomips" | awk -F": " '{print $2}' | head -1`
echo
makeTitle "CPU"
if [ $CPU_NB -gt 1 ] ; then
echo -e "${GREEN} Number\t ${WHITE}$CPU_NB"
fi
echo -e "${GREEN} Model\t\t ${WHITE}$CPU_INFO"
echo -e "${GREEN} Frequency\t ${WHITE}$CPU_FREQ MHz"
echo -e "${GREEN} Cache L2\t ${WHITE}$CPU_CACHE"
echo -e "${GREEN} Bogomips\t ${WHITE}$CPU_BOGOMIPS"
# Function : memory
function memory()
MEM_TOTAL=`/usr/bin/free -tmo | grep -i Mem: | awk '{print $2}'`
MEM_FREE=`/usr/bin/free -tmo | grep -i Mem: | awk '{print $4+$6+$7}'`
echo
makeTitle "Memory"
echo -e "${GREEN} RAM\t\t${WHITE}$MEM_FREE Mb free of $MEM_TOTAL Mb"
# Function : network
function network()
INTERFACES=`/sbin/ifconfig |awk -F '[/ |: ]' '{print $1}' |sed -e '/^$/d'`
if [ -e "/usr/bin/curl" ] ; then
IP_WAN=`curl -s ${GET_WAN_IP}`
else
IP_WAN=`wget ${GET_WAN_IP} -O - -o /dev/null`
fi
echo
makeTitle "Network"
for INTERFACE in $INTERFACES
do
IP_LAN=`/sbin/ip -f inet -o addr show ${INTERFACE} | cut -d\ -f 7 | cut -d/ -f 1`
echo -e "${GREEN} IP LAN (${INTERFACE})\t ${WHITE}$IP_LAN"
done
echo -e "${GREEN} IP WAN\t ${WHITE}$IP_WAN"
# Function : ping
function ping()
echo
makeTitle "Ping"
for HOST in ${PING_HOSTS[@]}
do
PING=`/bin/ping -qc 1 $HOST | awk -F/ '/^rtt/ { print $5 }'`
echo -e "${GREEN} ${HOST}\t ${WHITE}$PING ms"
done
# Function : Disk space (top 5)
function disk_space()
HDD_TOP=`df -h | head -1 | sed s/^/" "/`
#HDD_DATA=`df -hl | grep -v "^Filesystem" | grep -v "^Sys. de fich." | sort -k5r | head -5 | sed s/^/" "/`
# HDD_DATA=`df -hl | sed "1 d" | grep -v "^Filesystem" | grep -v "^Sys. de fich." | sort | head -5 | sed s/^/" "/`
if [ ${DISK_SHOW_TMPFS} = true ] ; then
HDD_DATA=`df -hl | sed "1 d" | grep -iv "^Filesystem|Sys." | sort | head -5 | sed s/^/" "/`
else
HDD_DATA=`df -hl | sed "1 d" | grep -iv "^Filesystem|Sys." | grep -vE "^tmpfs|udev" | sort | head -5 | sed s/^/" "/`
fi
echo
makeTitle "Disk space (top 5)"
echo -e "${GREEN}$HDD_TOP"
echo -e "${WHITE}$HDD_DATA"
# Function : services
function services()
echo
makeTitle "Services"
for PORT in "${!SERVICES_NAME[@]}"
do
NAME=${SERVICES_NAME[$PORT]}
HOST=${SERVICES_HOST[$PORT]}
CHECK=`(exec 3<>/dev/tcp/$HOST/$PORT) &>/dev/null; echo $?`
if [ $CHECK = 0 ] ; then
CHECK_LABEL=${WHITE}ONLINE
else
CHECK_LABEL=${RED}OFFLINE
fi
echo -e "${GREEN} $NAME ($PORT) : ${CHECK_LABEL}"
done
# Function : hard drive temperatures
function hdd_temperatures()
if [ ${TEMP_ENABLED} = true ] ; then
echo
makeTitle "Hard drive Temperatures"
DISKS=`ls /sys/block/ | grep -E -i '^(s|h)d'`
# If hddtemp is installed
if [ -e "/usr/sbin/hddtemp" ] ; then
for DISK in $DISKS
do
TEMP_DISK=`hddtemp -n /dev/$DISK`"°C"
echo -e " ${GREEN}/dev/$DISK\t${WHITE}$TEMP_DISK"
done
else
echo -e "${WHITE}\nPlease, install hddtemp${WHITE}"
fi
fi
# Function : system temperatures
function system_temperatures()
echo
makeTitle "System Temperatures"
# If lm-sensors is installed
if [ -e "/usr/bin/sensors" ] ; then
TEMP_CPU=`/usr/bin/sensors | grep -E "^(CPU Temp|Core 0)" | cut -d '+' -f2 | cut -d '.' -f1`"°C"
TEMP_MB=`/usr/bin/sensors | grep -E "^(Sys Temp|Board Temp)" | cut -d '+' -f2 | cut -d '(' -f1`
echo -e " ${GREEN}CPU ${WHITE}$TEMP_CPU"
echo -e " ${GREEN}Motherboard ${WHITE}$TEMP_MB"
# Raspberry Pi
elif [ -f "/sys/class/thermal/thermal_zone0/temp" ] ; then
TEMP_CPU=`cat /sys/class/thermal/thermal_zone0/temp`
TEMP_CPU=$(( $TEMP_CPU / 1000 ))
echo -e " ${GREEN}CPU ${WHITE}$TEMP_CPU°C"
else
echo -e "${WHITE}\nPlease, install lm-sensors${WHITE}"
fi
fi
# Function : showAll
function showAll()
system
load_average
cpu
memory
network
ping
disk_space
services
hdd_temperatures
system_temperatures
# Function : showVersion
function showVersion()
echo "$ESM_VERSION"
# Function : showHelp
function showHelp()
echo
echo "-------"
echo -e "Name : $ESM_NAME\nVersion : $ESM_VERSION\nAuthor : $ESM_AUTHOR\nCreated : $ESM_CREATED"
echo
echo -e "$ESM_NAME is originally a PHP project allows you to display system's information of a Unix machine.\nThis is the bash version."
echo
echo -e "[USAGE]\n"
echo -e " -h, -u, --help, --usage print this help message \n"
echo -e " -v, --version print program version\n"
echo -e " -C, --clear clear console\n Must be inserted before any argument\n"
echo -e " -s, --system system information (OS and distro ; kernel ; hostname ; uptime ; users connected; last boot; datetime)\n"
echo -e " -e, --services checks port number\n"
echo -e " -n, --network network information (IP LAN ; IP WAN)\n"
echo -e " -p, --ping pings several hosts\n Can be configured in the file\n"
echo -e " -c, --cpu processor information (model ; frequency ; cache ; bogomips)\n"
echo -e " -m, --memory RAM information (free and total)\n"
echo -e " -l, --load system load ; processus\n"
echo -e " -t, --temperatures print CPU, system and HDD temperatures\n Can be configured in the file\n"
echo -e " -d, --disk disk space (top 5) ; sorted by alpha\n"
echo -e " -a, --all print all data\n"
echo; echo;
echo -e "More information on : $ESM_URL"
echo "-------"
echo
# * [ LET'S GO !! ] * #
if [ $# -ge 1 ] ; then
while getopts "Csenpcmltdavhu-:" option
do
case $option in
h | u) showHelp; exit ;;
v) showVersion; exit;;
C) clear ;;
s) system ;;
n) network ;;
p) ping ;;
c) cpu ;;
m) memory ;;
l) load_average ;;
t) hdd_temperatures; system_temperatures ;;
d) disk_space ;;
e) services ;;
a) showAll ;;
-) case $OPTARG in
help | usage) showHelp; exit ;;
version) showVersion; exit ;;
all) showAll; exit ;;
clear) clear ;;
system) system ;;
services) services ;;
load) load_average ;;
cpu) cpu ;;
memory) memory ;;
network) network ;;
ping) ping ;;
disk) disk_space ;;
temperatures) hdd_temperatures; system_temperatures ;;
*) exit ;;
esac ;;
?) echo "Option -$OPTARG inconnue"; exit ;;
*) exit ;;
esac
done
else
#showAll
showHelp;
exit;
fi
echo -e "${RESET}"
et voici le script une fois réduits du superflus
#!/bin/bash
# * [ CONFIG ] * #
# syntax :
SERVICES_NAME[53]="Unbound"
SERVICES_HOST[53]="localhost"
SERVICES_NAME[218]="Dnscrypt"
SERVICES_HOST[218]="localhost"
SERVICES_NAME[80]="SSH"
SERVICES_NAME[3306]="VPN"
# * [ VARS ] * #
# Colors
NC="\e[0m"
RED="\e[31;40m"
GREEN="\e[32;40m"
YELLOW="\e[33;40m"
WHITE="\e[37;40m"
# Styles
BOLD="\e[1m"
RESET="\e[0m"
function services()
echo
do
else
fi
done
a partir de là je n’arrive pas a faire en sort que echo affiche le resultat dans le terminal
Le script d’origine passe par l’appel de fonctions et je n’arrive pas a simplifier le truc. Help!
