Je viens d’acheter une clef usb pour bouter sur un live.
Voila ce que me retourne le syslog:
pour un Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.60-1+deb7u1 x86_64 GNU/Linux
Aug 22 12:11:48 localhost kernel: [ 2.623466] usbcore: registered new interface driver usbfs
Aug 22 12:11:48 localhost kernel: [ 2.623495] usbcore: registered new interface driver hub
Aug 22 12:11:48 localhost kernel: [ 2.623560] usbcore: registered new device driver usb
Aug 22 12:11:48 localhost kernel: [ 2.624226] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 22 12:11:48 localhost kernel: [ 2.624367] ehci_hcd 0000:00:1a.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.624373] ehci_hcd 0000:00:1a.0: EHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.624408] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
Aug 22 12:11:48 localhost kernel: [ 2.624445] ehci_hcd 0000:00:1a.0: debug port 2
Aug 22 12:11:48 localhost kernel: [ 2.625213] Adaptec aacraid driver 1.1-7[28000]-ms
Aug 22 12:11:48 localhost kernel: [ 2.625485] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
Aug 22 12:11:48 localhost kernel: [ 2.625489] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
Aug 22 12:11:48 localhost kernel: [ 2.628322] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
Aug 22 12:11:48 localhost kernel: [ 2.628350] ehci_hcd 0000:00:1a.0: irq 17, io mem 0xf3107000
Aug 22 12:11:48 localhost kernel: [ 2.632252] aacraid 0000:05:00.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.632944] e1000e 0000:07:00.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.633057] e1000e 0000:07:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Aug 22 12:11:48 localhost kernel: [ 2.633155] e1000e 0000:07:00.0: irq 77 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.633162] e1000e 0000:07:00.0: irq 78 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.633169] e1000e 0000:07:00.0: irq 79 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.636995] xhci_hcd 0000:09:00.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.637000] xhci_hcd 0000:09:00.0: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.637011] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 2
Aug 22 12:11:48 localhost kernel: [ 2.698097] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Aug 22 12:11:48 localhost kernel: [ 2.698129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 22 12:11:48 localhost kernel: [ 2.698132] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.698134] usb usb1: Product: EHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.698136] usb usb1: Manufacturer: Linux 3.2.0-4-amd64 ehci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.698137] usb usb1: SerialNumber: 0000:00:1a.0
Aug 22 12:11:48 localhost kernel: [ 2.698284] hub 1-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.698290] hub 1-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 2.698461] xhci_hcd 0000:09:00.0: irq 80 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698468] xhci_hcd 0000:09:00.0: irq 81 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698475] xhci_hcd 0000:09:00.0: irq 82 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698482] xhci_hcd 0000:09:00.0: irq 83 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698488] xhci_hcd 0000:09:00.0: irq 84 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698495] xhci_hcd 0000:09:00.0: irq 85 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698503] xhci_hcd 0000:09:00.0: irq 86 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698510] xhci_hcd 0000:09:00.0: irq 87 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.698651] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Aug 22 12:11:48 localhost kernel: [ 2.698654] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.698656] usb usb2: Product: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.698657] usb usb2: Manufacturer: Linux 3.2.0-4-amd64 xhci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.698659] usb usb2: SerialNumber: 0000:09:00.0
Aug 22 12:11:48 localhost kernel: [ 2.698693] ehci_hcd 0000:00:1d.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.698696] ehci_hcd 0000:00:1d.0: EHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.698769] xHCI xhci_add_endpoint called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.698771] xHCI xhci_check_bandwidth called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.698803] hub 2-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.698811] hub 2-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 2.698862] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
Aug 22 12:11:48 localhost kernel: [ 2.698887] ehci_hcd 0000:00:1d.0: debug port 2
Aug 22 12:11:48 localhost kernel: [ 2.702766] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
Aug 22 12:11:48 localhost kernel: [ 2.702790] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf3106000
Aug 22 12:11:48 localhost kernel: [ 2.702798] libata version 3.00 loaded.
Aug 22 12:11:48 localhost kernel: [ 2.704478] isci: Intel(R) C600 SAS Controller Driver - version 1.0.0
Aug 22 12:11:48 localhost kernel: [ 2.706711] xhci_hcd 0000:09:00.0: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.706718] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 4
Aug 22 12:11:48 localhost kernel: [ 2.706745] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
Aug 22 12:11:48 localhost kernel: [ 2.706747] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.706749] usb usb4: Product: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.706751] usb usb4: Manufacturer: Linux 3.2.0-4-amd64 xhci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.706753] usb usb4: SerialNumber: 0000:09:00.0
Aug 22 12:11:48 localhost kernel: [ 2.706863] xHCI xhci_add_endpoint called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.706865] xHCI xhci_check_bandwidth called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.706892] hub 4-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.706899] hub 4-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 2.706953] isci 0000:06:00.0: driver configured for rev: 6 silicon
Aug 22 12:11:48 localhost kernel: [ 2.706958] isci 0000:06:00.0: OEM parameter table found in OROM
Aug 22 12:11:48 localhost kernel: [ 2.706961] isci 0000:06:00.0: OEM SAS parameters (version: 1.0) loaded (platform)
Aug 22 12:11:48 localhost kernel: [ 2.707578] isci 0000:06:00.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.709887] scsi1 : isci
Aug 22 12:11:48 localhost kernel: [ 2.710561] isci 0000:06:00.0: irq 88 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.710570] isci 0000:06:00.0: irq 89 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.716200] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Aug 22 12:11:48 localhost kernel: [ 2.716229] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Aug 22 12:11:48 localhost kernel: [ 2.716232] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.716235] usb usb3: Product: EHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.716236] usb usb3: Manufacturer: Linux 3.2.0-4-amd64 ehci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.716238] usb usb3: SerialNumber: 0000:00:1d.0
Aug 22 12:11:48 localhost kernel: [ 2.716423] hub 3-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.716428] hub 3-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 2.716616] ahci 0000:00:1f.2: version 3.0
Aug 22 12:11:48 localhost kernel: [ 2.716706] ahci 0000:00:1f.2: irq 90 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.735163] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
Aug 22 12:11:48 localhost kernel: [ 2.735168] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
Aug 22 12:11:48 localhost kernel: [ 2.735172] ahci 0000:00:1f.2: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.735321] xhci_hcd 0000:0a:00.0: setting latency timer to 64
Aug 22 12:11:48 localhost kernel: [ 2.735326] xhci_hcd 0000:0a:00.0: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.735336] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 5
Aug 22 12:11:48 localhost kernel: [ 2.796559] xhci_hcd 0000:0a:00.0: irq 91 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796566] xhci_hcd 0000:0a:00.0: irq 92 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796573] xhci_hcd 0000:0a:00.0: irq 93 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796581] xhci_hcd 0000:0a:00.0: irq 94 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796588] xhci_hcd 0000:0a:00.0: irq 95 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796595] xhci_hcd 0000:0a:00.0: irq 96 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796602] xhci_hcd 0000:0a:00.0: irq 97 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796609] xhci_hcd 0000:0a:00.0: irq 98 for MSI/MSI-X
Aug 22 12:11:48 localhost kernel: [ 2.796761] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
Aug 22 12:11:48 localhost kernel: [ 2.796763] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.796765] usb usb5: Product: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.796767] usb usb5: Manufacturer: Linux 3.2.0-4-amd64 xhci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.796769] usb usb5: SerialNumber: 0000:0a:00.0
Aug 22 12:11:48 localhost kernel: [ 2.796885] xHCI xhci_add_endpoint called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.796887] xHCI xhci_check_bandwidth called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.796918] hub 5-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.796925] hub 5-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 2.797016] xhci_hcd 0000:0a:00.0: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.797021] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 6
Aug 22 12:11:48 localhost kernel: [ 2.797062] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
Aug 22 12:11:48 localhost kernel: [ 2.797065] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 12:11:48 localhost kernel: [ 2.797067] usb usb6: Product: xHCI Host Controller
Aug 22 12:11:48 localhost kernel: [ 2.797069] usb usb6: Manufacturer: Linux 3.2.0-4-amd64 xhci_hcd
Aug 22 12:11:48 localhost kernel: [ 2.797070] usb usb6: SerialNumber: 0000:0a:00.0
Aug 22 12:11:48 localhost kernel: [ 2.797161] xHCI xhci_add_endpoint called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.797163] xHCI xhci_check_bandwidth called for root hub
Aug 22 12:11:48 localhost kernel: [ 2.797200] hub 6-0:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 2.797207] hub 6-0:1.0: 2 ports detected
Aug 22 12:11:48 localhost kernel: [ 3.012137] usb 1-1: new high-speed USB device number 2 using ehci_hcd
Aug 22 12:11:48 localhost kernel: [ 3.144600] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
Aug 22 12:11:48 localhost kernel: [ 3.144604] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 22 12:11:48 localhost kernel: [ 3.144959] hub 1-1:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 3.145035] hub 1-1:1.0: 6 ports detected
Aug 22 12:11:48 localhost kernel: [ 3.392387] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
Aug 22 12:11:48 localhost kernel: [ 3.392391] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 22 12:11:48 localhost kernel: [ 3.392785] hub 3-1:1.0: USB hub found
Aug 22 12:11:48 localhost kernel: [ 3.392824] hub 3-1:1.0: 8 ports detected
Aug 22 12:11:48 localhost kernel: [ 3.564000] usb 5-1: new high-speed USB device number 2 using xhci_hcd
Aug 22 12:11:48 localhost kernel: [ 3.613053] usb 5-1: New USB device found, idVendor=1b1c, idProduct=1a09
Aug 22 12:11:48 localhost kernel: [ 3.613057] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 22 12:11:48 localhost kernel: [ 3.613059] usb 5-1: Product: Voyager GT 3.0
Aug 22 12:11:48 localhost kernel: [ 3.613061] usb 5-1: Manufacturer: Corsair
Aug 22 12:11:48 localhost kernel: [ 3.613063] usb 5-1: SerialNumber: 070847F6D87D2742
Aug 22 12:11:48 localhost kernel: [ 3.616416] Initializing USB Mass Storage driver...
Aug 22 12:11:48 localhost kernel: [ 3.616644] scsi16 : usb-storage 5-1:1.0
Aug 22 12:11:48 localhost kernel: [ 3.616746] usbcore: registered new interface driver usb-storage
Aug 22 12:11:48 localhost kernel: [ 3.616748] USB Mass Storage support registered.
Aug 22 12:11:48 localhost kernel: [ 3.684071] usb 1-1.2: new low-speed USB device number 3 using ehci_hcd
Aug 22 12:11:48 localhost kernel: [ 3.782690] usb 1-1.2: New USB device found, idVendor=046a, idProduct=c090
Aug 22 12:11:48 localhost kernel: [ 3.782694] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 22 12:11:48 localhost kernel: [ 3.782697] usb 1-1.2: Product: Wireless Destop
Aug 22 12:11:48 localhost kernel: [ 3.782698] usb 1-1.2: Manufacturer: cherry
