ProBook 4520s (xx927ea) : erreur avec le kernel backports
Bonjour tout le monde.
Debian 7 Wheezy à jour utilisant lightdm et xfce
Kernels installés :
[ul]
[li]3.9.6-1~bpo70+1 (linux-image-3.9-0.bpo.1-amd64)[/li]
[li]3.10.5-1~bpo70+1 (linux-image-3.10-0.bpo.2-amd64)[/li][/ul]
Avec le kernel 3.9, aucun soucis mais avec le 3.10, j’ai 2 lignes d’erreurs dans dmesg dont je ne sais pas quel est réellement la source du problème :
[ 1.002096] pciehp 0000:00:1c.1:pcie04: pci_hp_register failed with error -16 [ 1.002204] pciehp 0000:00:1c.5:pcie04: pci_hp_register failed with error -16
En utilisant le kernel 3.9, voici les informations concernant les “1c.1” et “1c.5” :
[ 0.674355] pci 0000:00:1c.1: [8086:3b44] type 01 class 0x060400 [ 0.674453] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.674504] pci 0000:00:1c.1: System wakeup disabled by ACPI [ 0.676259] pci 0000:00:1c.1: PCI bridge to [bus 03-43] [ 0.676263] pci 0000:00:1c.1: bridge window [io 0x3000-0x4fff] [ 0.676268] pci 0000:00:1c.1: bridge window [mem 0xd0400000-0xd43fffff] [ 0.720786] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-43] add_size 200000 [ 0.720817] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.720822] pci 0000:00:1c.1: BAR 15: assigned [mem 0xd4800000-0xd49fffff 64bit pref] [ 0.720854] pci 0000:00:1c.1: PCI bridge to [bus 03-43] [ 0.720858] pci 0000:00:1c.1: bridge window [io 0x3000-0x4fff] [ 0.720864] pci 0000:00:1c.1: bridge window [mem 0xd0400000-0xd43fffff] [ 0.720868] pci 0000:00:1c.1: bridge window [mem 0xd4800000-0xd49fffff 64bit pref] [ 0.937164] pcieport 0000:00:1c.1: irq 42 for MSI/MSI-X [ 0.937582] pcieport 0000:00:1c.1: Signaling PME through PCIe PME interrupt [ 0.937587] pcie_pme 0000:00:1c.1:pcie01: service driver pcie_pme loaded [ 0.937718] pciehp 0000:00:1c.1:pcie04: HPC vendor_id 8086 device_id 3b44 ss_vid 103c ss_did 1411 [ 0.937742] pciehp 0000:00:1c.1:pcie04: service driver pciehp loaded
[ 0.674729] pci 0000:00:1c.5: [8086:3b4c] type 01 class 0x060400 [ 0.674827] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.674878] pci 0000:00:1c.5: System wakeup disabled by ACPI [ 0.694523] pci 0000:00:1c.5: PCI bridge to [bus 45] [ 0.694531] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff] [ 0.694539] pci 0000:00:1c.5: bridge window [mem 0xd0200000-0xd02fffff] [ 0.694550] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref] [ 0.720895] pci 0000:00:1c.5: PCI bridge to [bus 45] [ 0.720898] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff] [ 0.720904] pci 0000:00:1c.5: bridge window [mem 0xd0200000-0xd02fffff] [ 0.720909] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref] [ 0.937419] pcieport 0000:00:1c.5: irq 44 for MSI/MSI-X [ 0.937637] pcieport 0000:00:1c.5: Signaling PME through PCIe PME interrupt [ 0.937644] pcie_pme 0000:00:1c.5:pcie01: service driver pcie_pme loaded [ 0.937757] pciehp 0000:00:1c.5:pcie04: HPC vendor_id 8086 device_id 3b4c ss_vid 103c ss_did 1411 [ 0.937777] pciehp 0000:00:1c.5:pcie04: service driver pciehp loaded
Utilisant énormément nfs et ayant des disques durs en btrfs (l’interne du laptop et d’autres externes), je préfère avoir un kernel “un peu récent”.
De plus, le kernel 3.9 étant marqué EOL (End Of Life) sur le site kernel.org, je me tournais vers le 3.10.
Est-il possible de résoudre ces problèmes sans devoir compiler soi-même un kernel ?
Merci et bonne journée
C’est un retour de bug (regression) qui dispose au moins d’un fil https://bugzilla.redhat.com/show_bug.cgi?id=963991 mais en anglais. Le premier intervenant à proposer une solution donne (traduction rapide) :
Pour résumer : c’est juste le module pciehp qui se plaint mais c’est pas grave vu que acpi prend le relais. La ligne de commande du noyau n’a sans doute pas besoin d’être modifiée.
