bonjour
je viens de migrer de bullseye 11.7 vers bookworm, en suivant ce fil tout semble correct à part les dernières lignes
Traitement des actions différées (« triggers ») pour libvlc-bin:amd64 (3.0.18-2)
Traitement des actions différées (« triggers ») pour initramfs-tools (0.142) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-9-amd64
W: Possible missing firmware /lib/firmware/i915/tgl_huc_7.9.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cml_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/ehl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_dmc_ver2_12.bin for module i915
W: Possible missing firmware /lib/firmware/i915/rkl_dmc_ver2_03.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_dmc_ver2_16.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_dmc_ver2_07.bin for module i915
W: initramfs-tools configuration sets RESUME=UUID=2fbf09c2-5039-4091-8004-3615b0fca9ad
W: but no matching swap device is available.
I: The initramfs will attempt to resume from /dev/dm-1
I: (/dev/mapper/hp600--vg-swap_1)
I: Set the RESUME variable to override this.
Traitement des actions différées (« triggers ») pour dbus (1.14.6-1) ...
Traitement des actions différées (« triggers ») pour shim-signed:amd64 (1.39+15.7-1) ...
Traitement des actions différées (« triggers ») pour libgdk-pixbuf-2.0-0:amd64 (2.42.10+dfsg-1+b1) ...
ca-certificates-java
openjdk-17-jre-headless:amd64
openjdk-17-jre:amd64
default-jre
joel@hp600:~$
par ailleurs j’ai laissé le fichier /etc/pulse/default.pa tel que je l’avais modifié suite à problème de sauvegarde des paramètres alsamixer voir
