hello
malgrer un aptitude -remove --purge ntop
j’ai pas mal de truc qui reste sure le disque.
petit aperçus (je colle pas tout la liste est longue)
/etc/default/ntop
/etc/init.d/ntop
/etc/logcheck/ignore.d.paranoid/ntop
/etc/logcheck/ignore.d.server/ntop
/etc/logcheck/ignore.d.workstation/ntop
/etc/logrotate.d/ntop
/etc/ntop
/etc/ntop/AS-list.txt
/etc/ntop/etter.finger.os
/etc/ntop/ntop-cert.pem
/etc/ntop/oui.txt
/etc/ntop/p2c.opt.table
/etc/ntop/protocol.list
/etc/ntop/specialMAC.txt
/etc/rc0.d/K20ntop
/etc/rc1.d/K20ntop
/etc/rc2.d/S20ntop
/etc/rc3.d/S20ntop
/etc/rc4.d/S20ntop
/etc/rc5.d/S20ntop
/etc/rc6.d/K20ntop
/home/www_filepubic/ntop
/home/www_filepubic/ntop/n0.jpg
/home/www_filepubic/ntop/n1.png
/home/www_filepubic/ntop/n2.png
/home/www_filepubic/ntop/n3.png
/home/www_filepubic/ntop/n4.png
/home/www_filepubic/ntop/n5.png
/home/www_filepubic/ntop/n6.png
/usr/share/man/fr/man3/hasmntopt.3.gz
/usr/share/man/fr/man3/inet_ntop.3.gz
/usr/share/selinux/refpolicy-targeted/ntop.pp
/var/lib/dpkg/info/ntop.list
/var/lib/dpkg/info/ntop.postrm
/var/lib/ntop
/var/lib/ntop/addressQueue.db
/var/lib/ntop/dnsCache.db
/var/lib/ntop/fingerprint.db
/var/lib/ntop/init.cfg
/var/lib/ntop/LsWatch.db
/var/lib/ntop/macPrefix.db
/var/lib/ntop/ntop.pid
/var/lib/ntop/ntop_pw.db
/var/lib/ntop/prefsCache.db
/var/lib/ntop/rrd
/var/lib/ntop/rrd/flows
/var/lib/ntop/rrd/flows/Host Last Seen
/var/lib/ntop/rrd/flows/Host Last Seen/bytes.rrd
/var/lib/ntop/rrd/flows/Host Last Seen/packets.rrd
/var/lib/ntop/rrd/flows/ICMP Watch
/var/lib/ntop/rrd/flows/Round-Robin Databases
/var/lib/ntop/rrd/graphics
/var/lib/ntop/rrd/interfaces
/var/lib/ntop/rrd/interfaces/eth1
/var/lib/ntop/rrd/interfaces/eth1/activeHostSendersNum.rrd
/var/lib/ntop/rrd/interfaces/eth1/arpRarpBytes.rrd
/var/lib/ntop/rrd/interfaces/eth1/broadcastPkts.rrd
/var/lib/ntop/rrd/interfaces/eth1/domains
/var/lib/ntop/rrd/interfaces/eth1/domains/freenode.net
/var/lib/ntop/rrd/interfaces/eth1/domains/freenode.net/bytesRcvd.rrd
/var/lib/ntop/rrd/interfaces/eth1/domains/freenode.net/bytesSent.rrd
/var/lib/ntop/rrd/interfaces/eth1/domains/freenode.net/tcpRcvd.rrd
une idée pour tout virer,et sans tout casser
Merci d’avance
