Alors; merci pour cette commande, je ne connaissais pas.
Je capte pas tout les messages; je copie donc un peu avant le “buffer copy”
Voila le Topo aprés un:
strace dpkg -i /home/joe/app/dpkg_1.13.25_i386.deb 2> VoilaLeTopo
open("/var/lib/dpkg/info/apt.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=9631, ...}) = 0
read(7, "/.\n/usr\n/usr/lib\n/usr/lib/apt\n/u"..., 9631) = 9631
close(7) = 0
open("/var/lib/dpkg/info/kde-i18n-fr.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=120529, ...}) = 0
brk(0x86be000) = 0x86be000
read(7, "/.\n/usr\n/usr/share\n/usr/share/ap"..., 32768) = 32768
read(7, "ate/highlighting.docbook\n/usr/sh"..., 32768) = 32768
read(7, "docbook\n/usr/share/doc/kde/HTML/"..., 32768) = 32768
read(7, "le/fr/LC_MESSAGES/htmlsearch.mo\n"..., 22225) = 22225
close(7) = 0
brk(0x86e0000) = 0x86e0000
open("/var/lib/dpkg/info/libexchange-storage1.2-1.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=419, ...}) = 0
read(7, "/.\n/usr\n/usr/share\n/usr/share/do"..., 419) = 419
close(7) = 0
open("/var/lib/dpkg/info/libarts1c2a.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=2537, ...}) = 0
read(7, "/.\n/usr\n/usr/share\n/usr/share/do"..., 2537) = 2537
close(7) = 0
open("/var/lib/dpkg/info/openoffice.org-impress.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=3647, ...}) = 0
read(7, "/.\n/usr\n/usr/lib\n/usr/lib/openof"..., 3647) = 3647
close(7) = 0
open("/var/lib/dpkg/info/libegroupwise1.2-10.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=379, ...}) = 0
read(7, "/.\n/usr\n/usr/share\n/usr/share/do"..., 379) = 379
close(7) = 0
open("/var/lib/dpkg/info/sgml-base.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=816, ...}) = 0
read(7, "/.\n/usr\n/usr/share\n/usr/share/sg"..., 816) = 816
close(7) = 0
open("/var/lib/dpkg/info/libxslt1.1.list", O_RDONLY|O_LARGEFILE) = 7
fstat64(7, {st_mode=S_IFREG|0644, st_size=17592186044954, ...}) = 0
read(7, "/.\n/usr\n/usr/share\n/usr/share/do"..., 32768) = 538
read(7, "", 32768) = 0
write(2, "dpkg\240: erreur de traitement de a"..., 167dpkg : erreur de traitement de app/dpkg_1.13.25_i386.deb (--install) :
lecture courte (short read) dans « buffer_copy » (liste des fichiers du paquet « libxslt1.1 »)
) = 167
close(2) = 0
rmdir("/var/lib/dpkg/tmp.ci") = -1 ENOTEMPTY (Directory not empty)
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0xb7e3b708) = 3255
--- SIGCHLD (Child exited) @ 0 (0) ---
waitpid(3255, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0) = 3255
rmdir("/var/lib/dpkg/reassemble.deb") = -1 ENOENT (No such file or directory)
umask(022) = 022
