[quote=“Desintegr”]Je pense.
Ensuite tu redémarres, et tu montres le résultat d’un dmesg complet et d’un ifconfig -a.[/quote]
Nickel iwconfig reconnait bien la carte pas besoin de redémarrer un rmmod p54pci et modprobe p54pci a suffit,
[ 1.868193] ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
[ 1.872188] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 1.876338] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
[ 1.880215] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000e700
[ 1.884329] usb usb1: configuration #1 chosen from 1 choice
[ 1.888206] hub 1-0:1.0: USB hub found
[ 1.892189] hub 1-0:1.0: 2 ports detected
[ 1.904239] libata version 3.00 loaded.
[ 1.970001] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[ 1.972191] via-rhine: Broken BIOS detected, avoid_D3 enabled.
[ 1.998848] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.000200] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.004190] usb usb1: Product: UHCI Host Controller
[ 2.008189] usb usb1: Manufacturer: Linux 2.6.25.10-10-amd64-perso uhci_hcd
[ 2.012189] usb usb1: SerialNumber: 0000:00:10.0
[ 2.016235] ACPI: PCI Interrupt 0000:00:10.1[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
[ 2.020198] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 2.024248] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
[ 2.028214] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000e800
[ 2.032301] usb usb2: configuration #1 chosen from 1 choice
[ 2.036212] hub 2-0:1.0: USB hub found
[ 2.040198] hub 2-0:1.0: 2 ports detected
[ 2.130808] Floppy drive(s): fd0 is 1.44M
[ 2.133251] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.136201] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.140214] usb usb2: Product: UHCI Host Controller
[ 2.144198] usb usb2: Manufacturer: Linux 2.6.25.10-10-amd64-perso uhci_hcd
[ 2.148200] usb usb2: SerialNumber: 0000:00:10.1
[ 2.152242] ACPI: PCI Interrupt 0000:00:10.2[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
[ 2.160216] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 2.164261] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
[ 2.168220] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000e900
[ 2.172316] usb usb3: configuration #1 chosen from 1 choice
[ 2.176223] hub 3-0:1.0: USB hub found
[ 2.180207] hub 3-0:1.0: 2 ports detected
[ 2.188983] FDC 0 is a post-1991 82077
[ 2.272278] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.272525] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.276524] usb usb3: Product: UHCI Host Controller
[ 2.280523] usb usb3: Manufacturer: Linux 2.6.25.10-10-amd64-perso uhci_hcd
[ 2.284525] usb usb3: SerialNumber: 0000:00:10.2
[ 2.288572] ACPI: PCI Interrupt 0000:00:10.3[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
[ 2.292533] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 2.296577] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
[ 2.300547] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000ea00
[ 2.308562] usb usb4: configuration #1 chosen from 1 choice
[ 2.312550] hub 4-0:1.0: USB hub found
[ 2.316532] hub 4-0:1.0: 2 ports detected
[ 2.428554] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.430379] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.434395] usb usb4: Product: UHCI Host Controller
[ 2.438377] usb usb4: Manufacturer: Linux 2.6.25.10-10-amd64-perso uhci_hcd
[ 2.442377] usb usb4: SerialNumber: 0000:00:10.3
[ 2.446435] sata_via 0000:00:0f.0: version 2.3
[ 2.446717] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
[ 2.450385] ACPI: PCI Interrupt 0000:00:0f.0[B] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 2.454428] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 2.458492] scsi0 : sata_via
[ 2.462437] scsi1 : sata_via
[ 2.466409] ata1: SATA max UDMA/133 cmd 0xe000 ctl 0xe100 bmdma 0xe400 irq 20
[ 2.470380] ata2: SATA max UDMA/133 cmd 0xe200 ctl 0xe300 bmdma 0xe408 irq 20
[ 2.686299] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.856236] ata1.00: ATA-7: ST3250410AS, 3.AAC, max UDMA/133
[ 2.856239] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.877051] ata1.00: configured for UDMA/133
[ 3.086241] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 3.090363] scsi 0:0:0:0: Direct-Access ATA ST3250410AS 3.AA PQ: 0 ANSI: 5
[ 3.094389] ACPI: PCI Interrupt 0000:00:10.4[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
[ 3.102256] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 3.106302] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
[ 3.110290] ehci_hcd 0000:00:10.4: irq 21, io mem 0xfb004000
[ 3.126280] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.130378] usb usb5: configuration #1 chosen from 1 choice
[ 3.134278] hub 5-0:1.0: USB hub found
[ 3.138255] hub 5-0:1.0: 8 ports detected
[ 3.154208] Driver 'sd' needs updating - please use bus_type methods
[ 3.154379] sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB)
[ 3.159551] sd 0:0:0:0: [sda] Write Protect is off
[ 3.162271] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.162335] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.166409] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.170250] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.174249] usb usb5: Product: EHCI Host Controller
[ 3.178248] usb usb5: Manufacturer: Linux 2.6.25.10-10-amd64-perso ehci_hcd
[ 3.182248] usb usb5: SerialNumber: 0000:00:10.4
[ 3.186576] ACPI: PCI Interrupt Link [ALKD] enabled at IRQ 23
[ 3.190282] ACPI: PCI Interrupt 0000:00:12.0[A] -> Link [ALKD] -> GSI 23 (level, low) -> IRQ 23
[ 3.194495] eth0: VIA Rhine II at 0x1eb00, 00:13:d3:fb:3d:e4, IRQ 23.
[ 3.198958] eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 45e1.
[ 3.211763] Uniform Multi-Platform E-IDE driver
[ 3.214255] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 3.220385] sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB)
[ 3.222268] sd 0:0:0:0: [sda] Write Protect is off
[ 3.226261] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.226387] VP_IDE: IDE controller (0x1106:0x0571 rev 0x06) at PCI slot 0000:00:0f.1
[ 3.230290] ACPI: PCI Interrupt 0000:00:0f.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 3.234272] VP_IDE: not 100% native mode: will probe irqs later
[ 3.238259] VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
[ 3.242259] ide0: BM-DMA at 0xe600-0xe607, BIOS settings: hda:DMA, hdb:PIO
[ 3.246259] ide1: BM-DMA at 0xe608-0xe60f, BIOS settings: hdc:DMA, hdd:DMA
[ 3.250254] Probing IDE interface ide0...
[ 3.263451] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.266263] sda: sda1 sda2
[ 3.274412] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.613021] hda: Maxtor 6Y080L0, ATA DISK drive
[ 4.288911] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 4.288911] hda: UDMA/133 mode selected
[ 4.289034] Probing IDE interface ide1...
[ 5.154271] hdc: TSSTcorpCD/DVDW SH-S182M, ATAPI CD/DVD-ROM drive
[ 5.941714] hdd: HL-DT-ST GCE-8526B, ATAPI CD/DVD-ROM drive
[ 5.999964] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 5.999964] hdc: UDMA/33 mode selected
[ 6.000406] hdd: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 6.000494] hdd: UDMA/33 mode selected
[ 6.004107] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 6.028822] ide1 at 0x170-0x177,0x376 on irq 15
[ 6.065600] hda: max request size: 128KiB
[ 6.066633] hda: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63
[ 6.076038] hda: cache flushes supported
[ 6.078441] hda: hda1 hda2 hda3
[ 6.122786] hdc: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
[ 6.127355] Uniform CD-ROM driver Revision: 3.20
[ 6.138358] hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache
[ 6.717573] PM: Starting manual resume from disk
[ 6.847150] kjournald starting. Commit interval 5 seconds
[ 6.847175] EXT3-fs: mounted filesystem with ordered data mode.
[ 9.715373] udevd version 125 started
[ 11.398362] input: PC Speaker as /class/input/input1
[ 11.996351] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 12.213629] pnp: the driver 'parport_pc' has been registered
[ 12.213650] parport_pc 00:0b: reported by Plug and Play ACPI
[ 12.214483] parport0: PC-style at 0x378, irq 7 [PCSPP]
[ 12.314524] parport_pc 00:0b: driver attached
[ 12.380715] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 12.528435] input: Power Button (FF) as /class/input/input2
[ 12.562527] ACPI: Power Button (FF) [PWRF]
[ 12.566551] input: Power Button (CM) as /class/input/input3
[ 12.599313] ACPI: Power Button (CM) [PWRB]
[ 12.616587] pnp: the driver 'rtc_cmos' has been registered
[ 12.616608] rtc_cmos 00:05: disabling not supported
[ 12.616613] rtc_cmos: probe of 00:05 failed with error -16
[ 12.775008] ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 18
[ 13.146417] 0000:00:0a.0 (prism54pci): cannot find firmware (isl3886)
[ 13.146441] ACPI: PCI interrupt for device 0000:00:0a.0 disabled
[ 13.150427] prism54pci: probe of 0000:00:0a.0 failed with error -2
[ 13.154494] ACPI: PCI Interrupt 0000:00:09.1[A] -> GSI 17 (level, low) -> IRQ 17
[ 13.158749] bt87x0: Using board 1, analog, digital (rate 32000 Hz)
[ 14.341721] Adding 2104504k swap on /dev/hda2. Priority:-1 extents:1 across:2104504k
[ 14.914487] EXT3 FS on hda3, internal journal
[ 15.433892] loop: module loaded
[ 15.464035] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 15.499219] ndiswrapper version 1.53 loaded (smp=yes, preempt=no)
[ 15.587669] usbcore: registered new interface driver ndiswrapper
[ 15.977791] fuse init (API version 7.9)
[ 16.275715] kjournald starting. Commit interval 5 seconds
[ 16.275742] EXT3-fs warning: mounting fs with errors, running e2fsck is recommended
[ 16.280206] EXT3 FS on sda1, internal journal
[ 16.287720] EXT3-fs: mounted filesystem with ordered data mode.
[ 16.331294] kjournald starting. Commit interval 5 seconds
[ 16.331303] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
[ 16.335460] EXT3 FS on sda2, internal journal
[ 16.339300] EXT3-fs: mounted filesystem with ordered data mode.
[ 18.320349] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 19.281964] NET: Registered protocol family 10
[ 19.282617] lo: Disabled Privacy Extensions
[ 45.207627] lp0: using parport0 (interrupt-driven).
[ 45.235275] ppdev: user-space parallel port driver
[ 56.694261] Bluetooth: Core ver 2.11
[ 56.702668] NET: Registered protocol family 31
[ 56.705401] Bluetooth: HCI device and connection manager initialized
[ 56.709366] Bluetooth: HCI socket layer initialized
[ 56.782394] Bluetooth: L2CAP ver 2.9
[ 56.785369] Bluetooth: L2CAP socket layer initialized
[ 56.872479] Bluetooth: RFCOMM socket layer initialized
[ 56.872513] Bluetooth: RFCOMM TTY layer initialized
[ 56.876483] Bluetooth: RFCOMM ver 1.8
[ 64.475323] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 64.475675] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 173.14.09 Wed Jun 4 23:40:50 PDT 2008
[ 64.846982] agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
[ 64.846996] agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
[ 64.847060] agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
[ 1200.003489] ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 18
[ 1200.064356] p54: LM86 firmware
[ 1200.064363] p54: FW rev 2.7.0.0 - Softmac protocol 4.1
[ 1201.002371] phy1: Selected rate control algorithm 'pid'
[ 1201.123820] phy1: hwaddr 00:07:ca:05:47:2a, isl3886
[code]SCOTTY:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:13:d3:fb:3d:e4
inet adr:192.168.0.1 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: 2a01:e35:8ab9:41f0:213:d3ff:fefb:3de4/64 Scope:Global
adr inet6: fe80::213:d3ff:fefb:3de4/64 Scope:Lien
RX packets:1183 errors:0 dropped:0 overruns:0 frame:0
TX packets:1533 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:144383 (140.9 KiB) TX bytes:234744 (229.2 KiB)
Interruption:23 Adresse de base:0xeb00
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:119 errors:0 dropped:0 overruns:0 frame:0
TX packets:119 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:70588 (68.9 KiB) TX bytes:70588 (68.9 KiB)
wlan0 Link encap:Ethernet HWaddr 00:07:ca:05:47:2a
BROADCAST MULTICAST MTU:1500 Metric:1
wmaster0 Link encap:UNSPEC HWaddr 00-07-CA-05-47-2A-00-00-00-00-00-00-00-00-00-00
Merci pour ton aide
