Bonjour.
Voila chez moi pour : apt list systemd -a
alain@Host-002:~$ apt list systemd -a
En train de lister… Fait
systemd/jessie-backports 230-7~bpo8+2 amd64
systemd/stable,now 215-17+deb8u5 amd64 [installé]
Et pour: systemctl status mount Avec une clé ubs branchée.
[code]`alain@Host-002:~$ systemctl status mount
● systemd-remount-fs.service - Remount Root and Kernel File Systems
Loaded: loaded (/lib/systemd/system/systemd-remount-fs.service; static)
Active: active (exited) since lun. 2016-11-28 08:03:22 CET; 13min ago
Docs: man:systemd-remount-fs.service(8)
http://www.freedesktop.org/wiki/Software/systemd/APIFileSystems
Process: 266 ExecStart=/lib/systemd/systemd-remount-fs (code=exited, status=0/SUCCESS)
Main PID: 266 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/systemd-remount-fs.service
● mountkernfs.service
Loaded: masked (/dev/null)
Active: inactive (dead)
Warning: Unit file changed on disk, ‘systemctl daemon-reload’ recommended.
● mountdevsubfs.service
alain@Host-002:~$
`[/code]
Je ne comprends pas grand chose, mais il me semble que les services concernés ne soient pas actifs…
Et enfin voici pour : apt-cache showpkg systemd
[code]`alain@Host-002:~$ apt-cache showpkg systemd
Package: systemd
Versions:
230-7~bpo8+2 (/var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie-backports_main_binary-amd64_Packages)
Description Language:
File: /var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie-backports_main_binary-amd64_Packages
MD5: daa2c3e0044c2c2f5adc47475a3d6969
Description Language: en
File: /var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie-backports_main_i18n_Translation-en
215-17+deb8u5 (/var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie_main_binary-amd64_Packages) (/var/lib/dpkg/status)
File: /var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie_main_binary-amd64_Packages
MD5: b7cab5335af47ff49cf666299f5ca607
Description Language: fr
File: /var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie_main_i18n_Translation-fr
File: /var/lib/apt/lists/ftp.fr.debian.org_debian_dists_jessie_main_i18n_Translation-en
Reverse Depends:
systemd-coredump,systemd 229-2
dbus-user-session,systemd
iio-sensor-proxy,systemd
udev,systemd 224-2
udev,systemd 224-2
systemd-sysv,systemd
systemd-journal-remote,systemd 230-7~bpo8+2
systemd-container,systemd 224-2
systemd-coredump,systemd 230-7~bpo8+2
libnss-myhostname,systemd 222-1
systemd-container,systemd 230-7~bpo8+2
libsystemd-dev,systemd 204-8
libpam-systemd,systemd 230-7~bpo8+2
libnss-resolve,systemd 227-3
libnss-mymachines,systemd 222-1
ifupdown,systemd 228-3~
libpam-cgfs,systemd
liblxc1,systemd
libguestfs0,systemd
knot,systemd
tuxonice-userui,systemd 208-6
udev,systemd 215-1
systemd-ui,systemd
systemd-shim,systemd 209
systemd-sysv,systemd 215-17+deb8u5
systemd-dbg,systemd 215-17+deb8u5
libpam-systemd,systemd 215-17+deb8u5
solaar,systemd 44
lighttpd,systemd 29.1
sogo,systemd
pcscd,systemd
mate-power-manager,systemd
lxsession,systemd
live-config-systemd,systemd
init-system-helpers,systemd 44-12
libvirt-daemon-system,systemd
libguestfs0,systemd
knot,systemd
gummiboot,systemd
Dependencies:
230-7~bpo8+2 - libc6 (2 2.8) libacl1 (2 2.2.51-8) libapparmor1 (2 2.9.0-3+exp2) libaudit1 (2 1:2.2.1) libblkid1 (2 2.19.1) libc6 (2 2.17) libcap2 (2 1:2.10) libcryptsetup4 (2 2:1.4.3) libgcrypt20 (2 1.6.1) libgpg-error0 (2 1.14) libidn11 (2 1.13) libkmod2 (2 5~) liblzma5 (2 5.1.1alpha+20120614) libmount1 (2 2.20.1) libpam0g (2 0.99.7.1) libseccomp2 (2 2.1.0) libselinux1 (2 2.1.9) libsystemd0 (5 230-7~bpo8+2) util-linux (2 2.25.2-6) mount (2 2.25.2-6) adduser (0 (null)) libcap2-bin (0 (null)) klogd (0 (null)) apparmor (3 2.9.2-1) ifupdown (3 0.8.5~) laptop-mode-tools (3 1.68~) lsb-base (3 4.1+Debian4) lvm2 (3 2.02.104-1) systemd-shim (3 8-2) udev (3 228-5) libpam-systemd (0 (null)) dbus (0 (null)) systemd-ui (0 (null)) systemd-container (0 (null)) policykit-1 (0 (null)) udev (3 228-5)
215-17+deb8u5 - libc6 (2 2.17) libgcrypt20 (2 1.6.1) liblzma5 (2 5.1.1alpha+20120614) libselinux1 (2 1.32) libacl1 (2 2.2.51-8) libaudit1 (2 1:2.2.1) libblkid1 (2 2.19.1) libcap2 (2 1:2.10) libcryptsetup4 (2 2:1.4.3) libkmod2 (2 5~) libpam0g (2 0.99.7.1) libselinux1 (2 2.1.9) libsystemd0 (5 215-17+deb8u5) util-linux (2 2.19.1-2) mount (2 2.21) initscripts (2 2.88dsf-53.2) sysv-rc (0 (null)) udev (2 208-8) acl (0 (null)) adduser (0 (null)) libcap2-bin (0 (null)) klogd (0 (null)) lsb-base (3 4.1+Debian4) lvm2 (3 2.02.104-1) systemd-shim (3 8-2) libpam-systemd (0 (null)) dbus (0 (null)) systemd-ui (0 (null))
Provides:
230-7~bpo8+2 -
215-17+deb8u5 -
Reverse Provides:
alain@Host-002:~$
`[/code]
Il y a bien dépendance entre systemd et mount, désolé, il faut scroler en bas pour la voir.
Que dois-je déduire de tout cela?
