[Résolu] K3b ne veux pas graver de cd audio !?
hello :slightly_smiling:
ca fait 2 jours que j’essaye de graver avec k3b sous debian SiD et kde3.3 mais a chaque fois il y a une erreur il ne sais pas decoder les fichiers audio
error while decoding audio tracks
arf …! j’ai essayé de voir si il n’y avai pas des libs mp3 sur les ftp debian mais je n’ai rien vu …
quelqu’un sait t’il pourquoi il me dit ca ?
merci.
ps voila le log :
[quote]System
K3b Version:0.11.17
KDE Version: 3.3.1
QT Version: 3.3.3
cdrecord
scsidev: 'ATAPI:/dev/hdd’
devname: 'ATAPI:/dev/hdd’
scsibus: -2 target: -2 lun: -2
Warning: Using ATA Packet interface.
Warning: The related Linux kernel interface code seems to be unmaintained.
Warning: There is absolutely NO DMA, operations thus are slow.
SCSI buffer size: 64512
/usr/bin/cdrecord: This version of cdrecord does not include DVD-R/DVD-RW support code.
/usr/bin/cdrecord: See /usr/share/doc/cdrecord/README.DVD.Debian for details on DVD support.
Cdrecord-Clone 2.01a38 (i686-pc-linux-gnu) Copyright © 1995-2004 Jörg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to cdrtools@packages.debian.org.
The original author should not be bothered with problems of this version.
TOC Type: 0 = CD-DA
Using libscg version ‘schily-0.8’.
Driveropts: 'burnfree’
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : '_NEC '
Identifikation : 'DVD_RW ND-1300A '
Revision : '1.07’
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0009
Profile: 0x001B
Profile: 0x001A
Profile: 0x0014
Profile: 0x0013
Profile: 0x0011
Profile: 0x0010
Profile: 0x000A
Profile: 0x0009 (current)
Profile: 0x0008 (current)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 1345536 = 1314 KB
FIFO size : 4194304 = 4096 KB
/usr/bin/cdrecord: Drive needs to reload the media to return to proper status.
/usr/bin/cdrecord: Cannot get next writable address for ‘invisible’ track.
/usr/bin/cdrecord: This means that we are checking recorded media.
/usr/bin/cdrecord: This media cannot be written in streaming mode anymore.
/usr/bin/cdrecord: If you like to write to ‘preformatted’ RW media, try to blank the media first.
pregap1: -1
Track 01: audio 36 MB (03:37.26) no preemp swab copy
Track 02: audio 35 MB (03:31.14) no preemp swab copy
Track 03: audio 39 MB (03:55.12) no preemp swab copy
Track 04: audio 48 MB (04:48.92) no preemp swab copy
Track 05: audio 38 MB (03:47.20) no preemp swab copy
Track 06: audio 37 MB (03:42.16) no preemp swab copy
Track 07: audio 37 MB (03:45.40) no preemp swab copy
Track 08: audio 41 MB (04:09.61) no preemp swab copy
Track 09: audio 31 MB (03:07.52) no preemp swab copy
Track 10: audio 46 MB (04:33.56) no preemp swab copy
Track 11: audio 31 MB (03:04.72) no preemp swab copy
Track 12: audio 38 MB (03:48.58) no preemp swab copy
Track 13: audio 53 MB (05:18.00) no preemp swab copy
Total size: 516 MB (51:09.21) = 230191 sectors
Lout start: 516 MB (51:11/16) = 230191 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 5
Is not unrestricted
Is not erasable
Disk sub type: Medium Type B, low Beta category (B-) (4)
ATIP start of lead in: -11524 (97:28/26)
ATIP start of lead out: 359849 (79:59/74)
Disk type: Short strategy type (Phthalocyanine or similar)
Manuf. index: 13
Manufacturer: Multi Media Masters & Machinary SA
Trying to clear drive status.
Starting to write CD/DVD at speed 16 in real SAO mode for single session.
Last chance to quit, starting real write in 2 seconds.
1 seconds.
0 seconds. Operation starts.
Waiting for reader process to fill input buffer … input buffer ready.
BURN-Free is OFF.
Turning BURN-Free on
Performing OPC…
Sending CUE sheet…
/usr/bin/cdrecord: Input/output error. read track info: scsi sendcmd: no error
CDB: 52 01 00 00 00 FF 00 00 1C 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 02
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x24 Qual 0x00 (invalid field in cdb) Fru 0x0
Sense flags: Blk 0 (not valid) error refers to command part, bit ptr 0 (not valid) field ptr 2
cmd finished after 0.054s timeout 240s
/usr/bin/cdrecord: WARNING: Drive returns wrong startsec (0) using -150
/usr/bin/cdrecord: Input/output error. write_g1: scsi sendcmd: no error
CDB: 2A 00 FF FF FF 6A 00 00 1B 00
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 27 00 00 00 00 00
Sense Code: 0x27 Qual 0x00 (write protected) Fru 0x0
cmd finished after 0.001s timeout 200s
CDB: 2A 00 00 00 00 00 00 00 1B 00
/usr/bin/cdrecord: A write error occured.
/usr/bin/cdrecord: Please properly read the error message above.
Writing pregap for track 14 at -150
write track pad data: error after 0 bytes
BFree: 0 K BSize: 1509 K
Starting new track at sector: 0
Track 14: 0 of 36 MB written.
write track data: error after 0 bytes
Writing time: 9.510s
Average write speed 612.2x.
Fixating…
Fixating time: 0.003s
BURN-Free was never needed.
/usr/bin/cdrecord: fifo had 64 puts and 1 gets.
/usr/bin/cdrecord: fifo was 0 times empty and 0 times full, min fill was 100%.
cdrecord comand:
/usr/bin/cdrecord.mmap -v gracetime=2 dev=ATAPI:/dev/hdd speed=16 -dao driveropts=burnfree -eject -useinfo -pad -shorttrack -audio /tmp/kde-boomslang/k3b_audio_0_01.inf /tmp/kde-boomslang/k3b_audio_0_02.inf /tmp/kde-boomslang/k3b_audio_0_03.inf /tmp/kde-boomslang/k3b_audio_0_04.inf /tmp/kde-boomslang/k3b_audio_0_05.inf /tmp/kde-boomslang/k3b_audio_0_06.inf /tmp/kde-boomslang/k3b_audio_0_07.inf /tmp/kde-boomslang/k3b_audio_0_08.inf /tmp/kde-boomslang/k3b_audio_0_09.inf /tmp/kde-boomslang/k3b_audio_0_10.inf /tmp/kde-boomslang/k3b_audio_0_11.inf /tmp/kde-boomslang/k3b_audio_0_12.inf /tmp/kde-boomslang/k3b_audio_0_13.inf[/quote]
et ca fonctionne pour du gravage data ?
as tu essayé en root ?
oui ca fonctione pour le gravage data, je n’ai pas essayé en root mais je ne crois pas que ca change grand chose lol
détrompes toi, il y a des problémes de gravage en simple user avec un noyau récent (lu sur les faqs redhat, mais je ne sais plus lequel). En tout cas, ca ne coute rien d’essayer, si j’ai bien compris, il ne grave pas du tout, donc tu peux toujours faire l’éssai… :slightly_smiling:
non je viens d’essayer :frowning:
le log en root
[quote]System
K3b Version:0.11.17
KDE Version: 3.3.1
QT Version: 3.3.3
cdrecord
TOC Type: 0 = CD-DA
atapi: 1
Version : 0
Response Format: 2
Capabilities :
Revision : '1.07’
Current: 0x0009
Profile: 0x001B
Profile: 0x001A
Profile: 0x0014
Profile: 0x0013
Profile: 0x0011
Profile: 0x0010
Profile: 0x000A
pregap1: -1
Is not unrestricted
Is not erasable
Manuf. index: 13
Blocks total: 359849 Blocks current: 359849 Blocks remaining: 129658
1 seconds.
BURN-Free is OFF.
Performing OPC…
Sending CUE sheet…
Writing pregap for track 1 at -150
Track 01: 0 of 36 MB written.
Track 01: 1 of 36 MB written (fifo 75%) [buf 92%] 21.8x.
CDB: 2A 00 00 00 02 01 00 00 1B 00
status: 0x0 (GOOD STATUS)
cmd finished after 10.242s timeout 200s
write track data: error after 1206576 bytes
Writing time: 30.259s
Average write speed 119.1x.
Fixating…
Fixating time: 0.002s
/usr/bin/cdrecord: fifo had 83 puts and 20 gets.
/usr/bin/cdrecord: fifo was 0 times empty and 1 times full, min fill was 70%.
cdrecord comand:
/usr/bin/cdrecord.mmap -v gracetime=2 dev=ATAPI:/dev/hdd speed=16 -dao driveropts=burnfree -eject -useinfo -pad -shorttrack -audio /tmp/kde-root/k3b_audio_0_01.inf /tmp/kde-root/k3b_audio_0_02.inf /tmp/kde-root/k3b_audio_0_03.inf /tmp/kde-root/k3b_audio_0_04.inf /tmp/kde-root/k3b_audio_0_05.inf /tmp/kde-root/k3b_audio_0_06.inf /tmp/kde-root/k3b_audio_0_07.inf /tmp/kde-root/k3b_audio_0_08.inf /tmp/kde-root/k3b_audio_0_09.inf /tmp/kde-root/k3b_audio_0_10.inf /tmp/kde-root/k3b_audio_0_11.inf /tmp/kde-root/k3b_audio_0_12.inf /tmp/kde-root/k3b_audio_0_13.inf
arf c’est embetant
ici il me met une erreur d’entree / sorti et une erreur pdt l’encodage des piste audio :unamused: puis il arrete
Pis ce coup ci, il a commencé à graver. Mais dans tes logs, il semblerait que ta galette soit de basse qualité
je ne suis franchement pas pecialiste de gravage, et j’interprete peut etre mal le log, mais il me semble que pour de l’audio, il vaut mieux prendre de la galette de qualité.
Par ailleurs, tu as essayé de graver moins vite ?
heu quece que tu appelle la galette ? :laughing:
CD vierge ? :unamused:
CD vierge ? :unamused:[/quote]
ben oui :confused:
Parce que moi, comme galettes, j’aime bien les complètes, ou à la rigueur jambon-fromage :slightly_smiling:
lol
nan m’ais d’abitude ca passes, je vai essayer de tester en gravant moins vite, merci de votre aide :slightly_smiling:
ca change rien non plus :frowning: gravé en 4x avec un autre media
l’erreur avec Ecplipt roaster :
[quote]Traceback (most recent call last):
File “/usr/lib/eroaster/Application.py”, line 755, in BurnWriterOptions
successfull = self.ConvertMp3ToWav()
File “/usr/lib/eroaster/Application.py”, line 2388, in ConvertMp3ToWav
result = listmatch(output, “Playing”)
UnboundLocalError: local variable ‘output’ referenced before assignment[/quote]
c’est enervant jvous jure :unamused:
question, est ce que tu pratiques l’overclock ?
oui :confused: pourquoi ca aurait qualque a voir ?
d’habitude je n’ai pas de probleme … :confused:
ben essayes sans overclock juste pour voir :slightly_smiling:
hé bien mon gars je crois que je n’aurai jamais trouvé :laughing: tu a s vu juste, en enlevant l’overcloacking ca fonctionne, je dois avouer que je n’aurai jamais trouvé seul :unamused: c’est bizzare car d’habitude ca ne fait pas ca :unamused:
enfin bref, merci a toi :wink:
ca cause aussi des problèmes sur la compression. Il faut le savoir, effectivement…
