Vl’a aut’chose maintenant…
Je remarque que je ne suis même plus foutu de compiler un kernel… sob !
burp:/usr/src/linux# make-kpkg --append-to-version "-perso.`date +"%y%m%d"`" --initrd buildpackage Warning: You are using the initrd option, that may not
work, depending on your kernel version and architecture,
unless you have applied the initrd cramfs patch to
the kernel, or modified mkinitrd not to use cramfs by
default. The cramfs initrd patch, is included in the
Debian supplied kernel sources. New kernels on most
architectures do work fine.
By default, I assume you know what you are doing, and I
apologize for being so annoying. Should I abort[Ny]?
N
/usr/share/kernel-package/rules:1637: *** Error. I do not know where the kernel image goes to [kimagedest undefined] The usual case for this is that I could not determine which arch or subarch tihs machine belongs to. Please specify a subarch, and try again.. Arr\ufffft.
J’ai passé les packages suivants en testing:
[code]burp:/usr/src/linux# dpkg -l binutils cpp cpp-4.0 g++ g+±4.0 gcc gcc-4.0 gcc-4.0-base gcc-4.1-base libgcc1 debconf-utils dpkg-dev debhelper build-essential kernel-package libncurses5-dev linux-source*
Souhait=inconnU/Install\uffff/suppRim\uffff/Purg\uffff/H=\uffff garder
| \ufffftat=Non/Install\uffff/fichier-Config/d\uffffpaqUet\uffff/\uffffchec-conFig/H=semi-install\uffff
|/ Err?=(aucune)/H=\uffff garder/besoin R\uffffinstallation/X=les deux (\ufffftat,Err: majuscule=mauvais)
||/ Nom Version Description
ii binutils 2.17-1 The GNU assembler, linker and binary utilities
ii build-essential 11.2 informational list of build-essential packages
ii cpp 4.0.3-4 The GNU C preprocessor (cpp)
ii cpp-4.0 4.0.3-3 The GNU C preprocessor
ii debconf-utils 1.4.30.13 debconf utilities
ii debhelper 5.0.37.3 helper programs for debian/rules
ii dpkg-dev 1.13.21 package building tools for Debian
ii g++ 4.0.3-4 The GNU C++ compiler
ii g+±4.0 4.0.3-3 The GNU C++ compiler
ii gcc 4.0.3-4 The GNU C compiler
ii gcc-4.0 4.0.3-3 The GNU C compiler
ii gcc-4.0-base 4.0.3-3 The GNU Compiler Collection (base package)
ii gcc-4.1-base 4.1.1-5 The GNU Compiler Collection (base package)
ii kernel-package 8.135 A utility for building Linux kernel related Debian packages.
ii libgcc1 4.1.1-5 GCC support library
ii libncurses5-dev 5.4-4 Developer’s libraries and docs for ncurses
un linux-source <n\uffffant> (aucune description n’est disponible)
un linux-source-2.6 <n\uffffant> (aucune description n’est disponible)
ii linux-source-2.6.16 2.6.16-17 Linux kernel source for version 2.6.16 with Debian patches
burp:/usr/src/linux#[/code]
Il me manque quelque chose ?
Pour info, je veux passer du 2.6.14 au 2.6.16. Ca sera plus facile de compiler le module de ma webcam flambant neuve…
(voilà ce que c’est que de faire du BSD pendant 2 mois sans plus toucher Debian… )
