[RÉSOLU] Problèmes pendant/après l'installation
Tags: #<Tag:0x00007f46aeaf05b8> #<Tag:0x00007f46aeaf0478>
  Sep 30 16:26:47 pc kernel: [    1.758195] serio: i8042 KBD port at 0x60,0x64 irq 1
    Sep 30 16:26:47 pc kernel: [    1.758217] serio: i8042 AUX0 port at 0x60,0x64 irq 12
    Sep 30 16:26:47 pc kernel: [    1.758296] serio: i8042 AUX1 port at 0x60,0x64 irq 12
    Sep 30 16:26:47 pc kernel: [    1.758361] serio: i8042 AUX2 port at 0x60,0x64 irq 12
    Sep 30 16:26:47 pc kernel: [    1.758429] serio: i8042 AUX3 port at 0x60,0x64 irq 12
    Sep 30 16:26:47 pc kernel: [    1.759303] mousedev: PS/2 mouse device common for all mice
    Sep 30 16:26:47 pc kernel: [    1.759569] rtc_cmos 00:01: RTC can wake from S4
    Sep 30 16:26:47 pc kernel: [    1.759974] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
    Sep 30 16:26:47 pc kernel: [    1.760017] rtc_cmos 00:01: alarms up to one day, 114 bytes nvram, hpet irqs
    Sep 30 16:26:47 pc kernel: [    1.760059] ledtrig-cpu: registered to indicate activity on CPUs
    Sep 30 16:26:47 pc kernel: [    1.760639] TCP: cubic registered
    Sep 30 16:26:47 pc kernel: [    1.760775] NET: Registered protocol family 10
    Sep 30 16:26:47 pc kernel: [    1.761520] mip6: Mobile IPv6
    Sep 30 16:26:47 pc kernel: [    1.761536] NET: Registered protocol family 17
    Sep 30 16:26:47 pc kernel: [    1.761551] mpls_gso: MPLS GSO support
    Sep 30 16:26:47 pc kernel: [    1.762108] Using IPI No-Shortcut mode
    Sep 30 16:26:47 pc kernel: [    1.762697] registered taskstats version 1
    Sep 30 16:26:47 pc kernel: [    1.762783] AppArmor: AppArmor sha1 policy hashing enabled
    Sep 30 16:26:47 pc kernel: [    1.763756] rtc_cmos 00:01: setting system clock to 2016-09-30 14:26:29 UTC (1475245589)
    Sep 30 16:26:47 pc kernel: [    1.764022] PM: Hibernation image not present or could not be loaded.
    Sep 30 16:26:47 pc kernel: [    1.764576] Freeing unused kernel memory: 660K (c1675000 - c171a000)
    Sep 30 16:26:47 pc kernel: [    1.764732] Write protecting the kernel text: 4628k
    Sep 30 16:26:47 pc kernel: [    1.764871] Write protecting the kernel read-only data: 1456k
    Sep 30 16:26:47 pc kernel: [    1.764873] NX-protecting the kernel data: 3564k
    Sep 30 16:26:47 pc kernel: [    1.776034] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
    Sep 30 16:26:47 pc kernel: [    1.798427] random: systemd-udevd urandom read with 0 bits of entropy available
    Sep 30 16:26:47 pc kernel: [    1.874442] SCSI subsystem initialized
    Sep 30 16:26:47 pc kernel: [    1.877485] thermal LNXTHERM:00: registered as thermal_zone0
    Sep 30 16:26:47 pc kernel: [    1.877495] ACPI: Thermal Zone [THRM] (55 C)
    Sep 30 16:26:47 pc kernel: [    1.880454] libata version 3.00 loaded.
    Sep 30 16:26:47 pc kernel: [    1.882035] ahci 0000:00:11.0: version 3.0
    Sep 30 16:26:47 pc kernel: [    1.882448] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
    Sep 30 16:26:47 pc kernel: [    1.882456] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio ccc
    Sep 30 16:26:47 pc kernel: [    1.883628] scsi0 : ahci
    Sep 30 16:26:47 pc kernel: [    1.884149] scsi1 : ahci
    Sep 30 16:26:47 pc kernel: [    1.884379] ACPI: bus type USB registered
    Sep 30 16:26:47 pc kernel: [    1.884401] ata1: SATA max UDMA/133 abar m1024@0xf044f000 port 0xf044f100 irq 19
    Sep 30 16:26:47 pc kernel: [    1.884408] ata2: SATA max UDMA/133 abar m1024@0xf044f000 port 0xf044f180 irq 19
    Sep 30 16:26:47 pc kernel: [    1.884494] usbcore: registered new interface driver usbfs
    Sep 30 16:26:47 pc kernel: [    1.884540] usbcore: registered new interface driver hub
    Sep 30 16:26:47 pc kernel: [    1.886835] usbcore: registered new device driver usb
    Sep 30 16:26:47 pc kernel: [    1.888077] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Sep 30 16:26:47 pc kernel: [    1.888607] ehci-pci: EHCI PCI platform driver
    Sep 30 16:26:47 pc kernel: [    1.888965] QUIRK: Enable AMD PLL fix
    Sep 30 16:26:47 pc kernel: [    1.889101] ehci-pci 0000:00:12.2: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.889119] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
    Sep 30 16:26:47 pc kernel: [    1.889130] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    Sep 30 16:26:47 pc kernel: [    1.889132] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
    Sep 30 16:26:47 pc kernel: [    1.889225] ehci-pci 0000:00:12.2: debug port 1
    Sep 30 16:26:47 pc kernel: [    1.889303] ehci-pci 0000:00:12.2: irq 17, io mem 0xf044d000
    Sep 30 16:26:47 pc kernel: [    1.906326] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
    Sep 30 16:26:47 pc kernel: [    1.906466] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    Sep 30 16:26:47 pc kernel: [    1.906473] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    1.906478] usb usb1: Product: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.906482] usb usb1: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
    Sep 30 16:26:47 pc kernel: [    1.906487] usb usb1: SerialNumber: 0000:00:12.2
    Sep 30 16:26:47 pc kernel: [    1.907653] hub 1-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    1.907696] hub 1-0:1.0: 5 ports detected
    Sep 30 16:26:47 pc kernel: [    1.916182] ehci-pci 0000:00:13.2: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.916200] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
    Sep 30 16:26:47 pc kernel: [    1.916211] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
    Sep 30 16:26:47 pc kernel: [    1.916297] ehci-pci 0000:00:13.2: debug port 1
    Sep 30 16:26:47 pc kernel: [    1.916356] ehci-pci 0000:00:13.2: irq 17, io mem 0xf044b000
    Sep 30 16:26:47 pc kernel: [    1.927888] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
    Sep 30 16:26:47 pc kernel: [    1.928049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    Sep 30 16:26:47 pc kernel: [    1.928056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    1.928061] usb usb2: Product: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.928065] usb usb2: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
    Sep 30 16:26:47 pc kernel: [    1.928069] usb usb2: SerialNumber: 0000:00:13.2
    Sep 30 16:26:47 pc kernel: [    1.928416] hub 2-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    1.928440] hub 2-0:1.0: 5 ports detected
    Sep 30 16:26:47 pc kernel: [    1.931289] atl1c 0000:07:00.0: version 1.0.1.1-NAPI
    Sep 30 16:26:47 pc kernel: [    1.932821] ehci-pci 0000:00:16.2: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.932840] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 3
    Sep 30 16:26:47 pc kernel: [    1.932850] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
    Sep 30 16:26:47 pc kernel: [    1.932931] ehci-pci 0000:00:16.2: debug port 1
    Sep 30 16:26:47 pc kernel: [    1.932987] ehci-pci 0000:00:16.2: irq 17, io mem 0xf0448000
    Sep 30 16:26:47 pc kernel: [    1.943806] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
    Sep 30 16:26:47 pc kernel: [    1.943935] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    Sep 30 16:26:47 pc kernel: [    1.943941] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    1.943946] usb usb3: Product: EHCI Host Controller
    Sep 30 16:26:47 pc kernel: [    1.943950] usb usb3: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
    Sep 30 16:26:47 pc kernel: [    1.943954] usb usb3: SerialNumber: 0000:00:16.2
    Sep 30 16:26:47 pc kernel: [    1.944288] hub 3-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    1.944309] hub 3-0:1.0: 4 ports detected
    Sep 30 16:26:47 pc kernel: [    1.946322] ohci-pci: OHCI PCI platform driver
    Sep 30 16:26:47 pc kernel: [    1.946715] ohci-pci 0000:00:12.0: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    1.946733] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 4
    Sep 30 16:26:47 pc kernel: [    1.946813] ohci-pci 0000:00:12.0: irq 18, io mem 0xf044e000
    Sep 30 16:26:47 pc kernel: [    2.004252] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
    Sep 30 16:26:47 pc kernel: [    2.004262] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    2.004266] usb usb4: Product: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.004271] usb usb4: Manufacturer: Linux 3.16.0-4-686-pae ohci_hcd
    Sep 30 16:26:47 pc kernel: [    2.004275] usb usb4: SerialNumber: 0000:00:12.0
    Sep 30 16:26:47 pc kernel: [    2.004944] hub 4-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    2.004974] hub 4-0:1.0: 5 ports detected
    Sep 30 16:26:47 pc kernel: [    2.006728] ohci-pci 0000:00:13.0: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.006745] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
    Sep 30 16:26:47 pc kernel: [    2.006797] ohci-pci 0000:00:13.0: irq 18, io mem 0xf044c000
    Sep 30 16:26:47 pc kernel: [    2.064158] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
    Sep 30 16:26:47 pc kernel: [    2.064168] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    2.064172] usb usb5: Product: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.064177] usb usb5: Manufacturer: Linux 3.16.0-4-686-pae ohci_hcd
    Sep 30 16:26:47 pc kernel: [    2.064181] usb usb5: SerialNumber: 0000:00:13.0
    Sep 30 16:26:47 pc kernel: [    2.064841] hub 5-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    2.064871] hub 5-0:1.0: 5 ports detected
    Sep 30 16:26:47 pc kernel: [    2.066626] ohci-pci 0000:00:14.5: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.066644] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 6
    Sep 30 16:26:47 pc kernel: [    2.066701] ohci-pci 0000:00:14.5: irq 18, io mem 0xf044a000
    Sep 30 16:26:47 pc kernel: [    2.124118] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
    Sep 30 16:26:47 pc kernel: [    2.124129] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    2.124134] usb usb6: Product: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.124138] usb usb6: Manufacturer: Linux 3.16.0-4-686-pae ohci_hcd
    Sep 30 16:26:47 pc kernel: [    2.124142] usb usb6: SerialNumber: 0000:00:14.5
    Sep 30 16:26:47 pc kernel: [    2.124777] hub 6-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    2.124804] hub 6-0:1.0: 2 ports detected
    Sep 30 16:26:47 pc kernel: [    2.125352] ohci-pci 0000:00:16.0: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.125371] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 7
    Sep 30 16:26:47 pc kernel: [    2.125424] ohci-pci 0000:00:16.0: irq 18, io mem 0xf0449000
    Sep 30 16:26:47 pc kernel: [    2.184100] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
    Sep 30 16:26:47 pc kernel: [    2.184110] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Sep 30 16:26:47 pc kernel: [    2.184115] usb usb7: Product: OHCI PCI host controller
    Sep 30 16:26:47 pc kernel: [    2.184120] usb usb7: Manufacturer: Linux 3.16.0-4-686-pae ohci_hcd
    Sep 30 16:26:47 pc kernel: [    2.184124] usb usb7: SerialNumber: 0000:00:16.0
    Sep 30 16:26:47 pc kernel: [    2.184776] hub 7-0:1.0: USB hub found
    Sep 30 16:26:47 pc kernel: [    2.184804] hub 7-0:1.0: 4 ports detected
    Sep 30 16:26:47 pc kernel: [    2.243706] usb 2-3: new high-speed USB device number 2 using ehci-pci
    Sep 30 16:26:47 pc kernel: [    2.323844] tsc: Refined TSC clocksource calibration: 1596.599 MHz
    Sep 30 16:26:47 pc kernel: [    2.375840] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    Sep 30 16:26:47 pc kernel: [    2.375893] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    Sep 30 16:26:47 pc kernel: [    2.380041] ata2.00: ATAPI: Slimtype DVD A  DS8A5SH, XA15, max UDMA/100
    Sep 30 16:26:47 pc kernel: [    2.381357] ata2.00: configured for UDMA/100
    Sep 30 16:26:47 pc kernel: [    2.388848] usb 2-3: New USB device found, idVendor=0bda, idProduct=0138
    Sep 30 16:26:47 pc kernel: [    2.388865] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Sep 30 16:26:47 pc kernel: [    2.388874] usb 2-3: Product: USB2.0-CRW
    Sep 30 16:26:47 pc kernel: [    2.388883] usb 2-3: Manufacturer: Generic
    Sep 30 16:26:47 pc kernel: [    2.388891] usb 2-3: SerialNumber: 20090516388200000
    Sep 30 16:26:47 pc kernel: [    2.399619] usbcore: registered new interface driver usb-storage
    Sep 30 16:26:47 pc kernel: [    2.400816] ums-realtek 2-3:1.0: USB Mass Storage device detected
    Sep 30 16:26:47 pc kernel: [    2.424493] scsi2 : usb-storage 2-3:1.0
    Sep 30 16:26:47 pc kernel: [    2.424742] usbcore: registered new interface driver ums-realtek
    Sep 30 16:26:47 pc kernel: [    2.431874] ata1.00: ATA-8: TOSHIBA MK7559GSXP, GN003J, max UDMA/100
    Sep 30 16:26:47 pc kernel: [    2.431884] ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
    Sep 30 16:26:47 pc kernel: [    2.432941] ata1.00: configured for UDMA/100
    Sep 30 16:26:47 pc kernel: [    2.433565] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MK7559GS 3J   PQ: 0 ANSI: 5
    Sep 30 16:26:47 pc kernel: [    2.439247] scsi 1:0:0:0: CD-ROM            Slimtype DVD A  DS8A5SH   XA15 PQ: 0 ANSI: 5
    Sep 30 16:26:47 pc kernel: [    2.459747] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
    Sep 30 16:26:47 pc kernel: [    2.459757] sd 0:0:0:0: [sda] 4096-byte physical blocks
    Sep 30 16:26:47 pc kernel: [    2.459950] sd 0:0:0:0: [sda] Write Protect is off
    Sep 30 16:26:47 pc kernel: [    2.459957] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    Sep 30 16:26:47 pc kernel: [    2.460024] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    Sep 30 16:26:47 pc kernel: [    2.475227] sr0: scsi3-mmc drive: 24x/8x writer dvd-ram cd/rw xa/form2 cdda tray
    Sep 30 16:26:47 pc kernel: [    2.475237] cdrom: Uniform CD-ROM driver Revision: 3.20
    Sep 30 16:26:47 pc kernel: [    2.475718] sr 1:0:0:0: Attached scsi CD-ROM sr0
    Sep 30 16:26:47 pc kernel: [    2.477951] sd 0:0:0:0: Attached scsi generic sg0 type 0
    Sep 30 16:26:47 pc kernel: [    2.478412] sr 1:0:0:0: Attached scsi generic sg1 type 5
    Sep 30 16:26:47 pc kernel: [    2.507735] usb 2-4: new high-speed USB device number 3 using ehci-pci
    Sep 30 16:26:47 pc kernel: [    2.527617]  sda: sda1 sda2 < sda5 >
    Sep 30 16:26:47 pc kernel: [    2.529095] sd 0:0:0:0: [sda] Attached SCSI disk
    Sep 30 16:26:47 pc kernel: [    2.689827] usb 2-4: New USB device found, idVendor=058f, idProduct=b002
    Sep 30 16:26:47 pc kernel: [    2.689844] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Sep 30 16:26:47 pc kernel: [    2.689853] usb 2-4: Product: 1.3M HD WebCam
    Sep 30 16:26:47 pc kernel: [    2.689862] usb 2-4: Manufacturer: AAB3X1GJJ
    Sep 30 16:26:47 pc kernel: [    2.695112] usb 2-3: USB disconnect, device number 2
    Sep 30 16:26:47 pc kernel: [    2.868420] psmouse serio2: synaptics: queried max coordinates: x [..5774], y [..5022]
    Sep 30 16:26:47 pc kernel: [    2.927642] psmouse serio2: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x240000/0xa0400, board id: 1694, fw id: 705179
    Sep 30 16:26:47 pc kernel: [    2.954208] PM: Starting manual resume from disk
    Sep 30 16:26:47 pc kernel: [    2.954222] PM: Hibernation image partition 8:5 present
    Sep 30 16:26:47 pc kernel: [    2.954225] PM: Looking for hibernation image.
    Sep 30 16:26:47 pc kernel: [    2.954762] PM: Image not found (code -22)
    Sep 30 16:26:47 pc kernel: [    2.954771] PM: Hibernation image not present or could not be loaded.
    Sep 30 16:26:47 pc kernel: [    2.964595] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input6
    Sep 30 16:26:47 pc kernel: [    3.323226] Switched to clocksource tsc
    Sep 30 16:26:47 pc kernel: [    3.368755] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    Sep 30 16:26:47 pc kernel: [    4.217662] random: nonblocking pool is initialized
    Sep 30 16:26:47 pc kernel: [    6.374935] lp: driver loaded but no devices found
    Sep 30 16:26:47 pc kernel: [    6.551866] ppdev: user-space parallel port driver
    Sep 30 16:26:47 pc kernel: [    6.645330] fuse init (API version 7.23)
    Sep 30 16:26:47 pc kernel: [    8.522328] ACPI: acpi_idle registered with cpuidle
    Sep 30 16:26:47 pc kernel: [    8.554096] acpi-cpufreq: overriding BIOS provided _PSD data
    Sep 30 16:26:47 pc kernel: [    8.643327] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input10
    Sep 30 16:26:47 pc kernel: [    8.643342] ACPI: Power Button [PWRB]
    Sep 30 16:26:47 pc kernel: [    8.643525] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0C:01/input/input11
    Sep 30 16:26:47 pc kernel: [    8.643533] ACPI: Power Button [PWRB]
    Sep 30 16:26:47 pc kernel: [    8.643652] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0E:00/input/input12
    Sep 30 16:26:47 pc kernel: [    8.643660] ACPI: Sleep Button [SLPB]
    Sep 30 16:26:47 pc kernel: [    8.643796] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input13
    Sep 30 16:26:47 pc kernel: [    8.652394] ACPI: Lid Switch [LID]
    Sep 30 16:26:47 pc kernel: [    8.652558] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input14
    Sep 30 16:26:47 pc kernel: [    8.652568] ACPI: Power Button [PWRF]
    Sep 30 16:26:47 pc kernel: [    8.680380] ACPI: Battery Slot [BAT0] (battery present)
    Sep 30 16:26:47 pc kernel: [    8.680603] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
    Sep 30 16:26:47 pc kernel: [    8.680747] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
    Sep 30 16:26:47 pc kernel: [    8.701002] acpi device:00: registered as cooling_device2
    Sep 30 16:26:47 pc kernel: [    8.701158] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15
    Sep 30 16:26:47 pc kernel: [    8.753960] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
    Sep 30 16:26:47 pc kernel: [    8.754141] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
    Sep 30 16:26:47 pc kernel: [    8.784617] ACPI: AC Adapter [AC0] (off-line)
    Sep 30 16:26:47 pc kernel: [    8.803154] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
    Sep 30 16:26:47 pc kernel: [    8.803292] sp5100_tco: PCI Revision ID: 0x42
    Sep 30 16:26:47 pc kernel: [    8.803410] sp5100_tco: Using 0xfed80b00 for watchdog MMIO address
    Sep 30 16:26:47 pc kernel: [    8.803424] sp5100_tco: Last reboot was not triggered by watchdog.
    Sep 30 16:26:47 pc kernel: [    8.803543] sp5100_tco: initialized (0xf7e3cb00). heartbeat=60 sec (nowayout=0)
    Sep 30 16:26:47 pc kernel: [    8.818319] wmi: Mapper loaded
    Sep 30 16:26:47 pc kernel: [    8.844594] [drm] Initialized drm 1.1.0 20060810
    Sep 30 16:26:47 pc kernel: [    8.849341] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    Sep 30 16:26:47 pc kernel: [    9.170366] snd_hda_intel 0000:00:01.1: irq 40 for MSI/MSI-X
    Sep 30 16:26:47 pc kernel: [    9.237582] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Sep 30 16:26:47 pc kernel: [    9.267863] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input16
    Sep 30 16:26:47 pc kernel: [    9.268222] cfg80211: Calling CRDA to update world regulatory domain
    Sep 30 16:26:47 pc kernel: [    9.470480] input: PC Speaker as /devices/platform/pcspkr/input/input17
    Sep 30 16:26:47 pc kernel: [    9.777425] sound hdaudioC1D2: autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
    Sep 30 16:26:47 pc kernel: [    9.777450] sound hdaudioC1D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
    Sep 30 16:26:47 pc kernel: [    9.777462] sound hdaudioC1D2:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
    Sep 30 16:26:47 pc kernel: [    9.777470] sound hdaudioC1D2:    mono: mono_out=0x0
    Sep 30 16:26:47 pc kernel: [    9.777478] sound hdaudioC1D2:    inputs:
    Sep 30 16:26:47 pc kernel: [    9.777488] sound hdaudioC1D2:      Internal Mic=0x1b
    Sep 30 16:26:47 pc kernel: [    9.777497] sound hdaudioC1D2:      Mic=0x18
    Sep 30 16:26:47 pc kernel: [    9.787502] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card1/hdaudioC1D2/input18
    Sep 30 16:26:47 pc kernel: [    9.788341] input: HDA ATI SB Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input19
    Sep 30 16:26:47 pc kernel: [    9.788683] input: HDA ATI SB Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input20
    Sep 30 16:26:47 pc kernel: [    9.918824] acer_wmi: Acer Laptop ACPI-WMI Extras
    Sep 30 16:26:47 pc kernel: [    9.918881] acer_wmi: Function bitmap for Communication Button: 0x1
    Sep 30 16:26:47 pc kernel: [    9.918903] acer_wmi: Brightness must be controlled by acpi video driver
    Sep 30 16:26:47 pc kernel: [    9.921044] input: Acer WMI hotkeys as /devices/virtual/input/input21
    Sep 30 16:26:47 pc kernel: [    9.922256] input: Acer BMA150 accelerometer as /devices/virtual/input/input22
    Sep 30 16:26:47 pc kernel: [    9.954667] rtl8192se: FW Power Save off (module option)
    Sep 30 16:26:47 pc kernel: [    9.954893] rtl8192se: Driver for Realtek RTL8192SE/RTL8191SE
    Sep 30 16:26:47 pc kernel: [    9.954893] Loading firmware rtlwifi/rtl8192sefw.bin
    Sep 30 16:26:47 pc kernel: [   10.031513] rtl8192se 0000:06:00.0: firmware: direct-loading firmware rtlwifi/rtl8192sefw.bin
    Sep 30 16:26:47 pc kernel: [   10.113374] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
    Sep 30 16:26:47 pc kernel: [   10.136589] [drm] radeon kernel modesetting enabled.
    Sep 30 16:26:47 pc kernel: [   10.136718] [drm:radeon_pci_probe] *ERROR* radeon kernel modesetting for R600 or later requires firmware-linux-nonfree.
    Sep 30 16:26:47 pc kernel: [   10.352947] kvm: Nested Virtualization enabled
    Sep 30 16:26:47 pc kernel: [   10.352968] kvm: Nested Paging enabled
    Sep 30 16:26:47 pc kernel: [   11.532079] media: Linux media interface: v0.10
    Sep 30 16:26:47 pc kernel: [   11.593460] Linux video capture interface: v2.00
    Sep 30 16:26:47 pc kernel: [   11.643841] uvcvideo: Found UVC 1.00 device 1.3M HD WebCam (058f:b002)
    Sep 30 16:26:47 pc kernel: [   11.648924] input: 1.3M HD WebCam as /devices/pci0000:00/0000:00:13.2/usb2/2-4/2-4:1.0/input/input23
    Sep 30 16:26:47 pc kernel: [   11.649256] usbcore: registered new interface driver uvcvideo
    Sep 30 16:26:47 pc kernel: [   11.649265] USB Video Class driver (1.1.1)
    Sep 30 16:26:47 pc kernel: [   11.812923] cfg80211: World regulatory domain updated:
    Sep 30 16:26:47 pc kernel: [   11.812941] cfg80211:  DFS Master region: unset
    Sep 30 16:26:47 pc kernel: [   11.812948] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    Sep 30 16:26:47 pc kernel: [   11.812959] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.812967] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.812976] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.812986] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.812995] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    Sep 30 16:26:47 pc kernel: [   11.813004] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    Sep 30 16:26:47 pc kernel: [   11.813012] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.813020] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    Sep 30 16:26:47 pc kernel: [   11.824137] ip_tables: (C) 2000-2006 Netfilter Core Team
    Sep 30 16:26:47 pc kernel: [   12.437227] Adding 12010492k swap on /dev/sda5.  Priority:-1 extents:1 across:12010492k FS
    Sep 30 16:26:47 pc kernel: [   12.480074] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
    Sep 30 16:26:47 pc kernel: [   12.627600] audit: type=1400 audit(1475245600.364:2): apparmor="STATUS" operation="profile_load" name="/bin/netstat" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.718688] audit: type=1400 audit(1475245600.456:3): apparmor="STATUS" operation="profile_load" name="/{usr/,}bin/ping" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.850686] audit: type=1400 audit(1475245600.588:4): apparmor="STATUS" operation="profile_load" name="/etc/cron.daily/logrotate" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.864811] audit: type=1400 audit(1475245600.600:5): apparmor="STATUS" operation="profile_load" name="/etc/cron.daily/slocate.cron" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.911641] audit: type=1400 audit(1475245600.648:6): apparmor="STATUS" operation="profile_load" name="/etc/cron.daily/tmpwatch" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.967253] audit: type=1400 audit(1475245600.704:7): apparmor="STATUS" operation="profile_load" name="gst_plugin_scanner" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   12.995795] audit: type=1400 audit(1475245600.732:8): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   13.014158] audit: type=1400 audit(1475245600.752:9): apparmor="STATUS" operation="profile_load" name="/sbin/dhcpcd" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   13.073429] audit: type=1400 audit(1475245600.812:10): apparmor="STATUS" operation="profile_load" name="/sbin/klogd" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   13.123544] audit: type=1400 audit(1475245600.860:11): apparmor="STATUS" operation="profile_load" name="/sbin/portmap" pid=316 comm="apparmor_parser"
    Sep 30 16:26:47 pc kernel: [   14.065552] ip6_tables: (C) 2000-2006 Netfilter Core Team
    Sep 30 16:26:47 pc kernel: [   19.463367] audit_printk_skb: 399 callbacks suppressed
    Sep 30 16:26:47 pc kernel: [   19.463383] audit: type=1400 audit(1475245607.204:145): apparmor="DENIED" operation="open" profile="/usr/bin/freshclam" name="/etc/clamav/freshclam.conf" pid=482 comm="freshclam" requested_mask="r" denied_mask="r" fsuid=0 ouid=118
    Sep 30 16:26:50 pc kernel: [   22.323207] atl1c 0000:07:00.0: irq 41 for MSI/MSI-X
    Sep 30 16:26:50 pc kernel: [   22.344555] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Sep 30 16:26:50 pc kernel: [   22.516704] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    Sep 30 16:26:51 pc kernel: [   24.060029] wlan0: authenticate with b0:c5:54:86:0e:da
    Sep 30 16:26:51 pc kernel: [   24.070205] wlan0: send auth to b0:c5:54:86:0e:da (try 1/3)
    Sep 30 16:26:51 pc kernel: [   24.071697] wlan0: authenticated
    Sep 30 16:26:51 pc kernel: [   24.075525] wlan0: associate with b0:c5:54:86:0e:da (try 1/3)
    Sep 30 16:26:51 pc kernel: [   24.078734] wlan0: RX AssocResp from b0:c5:54:86:0e:da (capab=0x431 status=0 aid=15)
    Sep 30 16:26:51 pc kernel: [   24.080392] wlan0: associated
    Sep 30 16:26:51 pc kernel: [   24.080502] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    Sep 30 16:26:52 pc kernel: [   24.591150] audit: type=1400 audit(1475245612.336:146): apparmor="DENIED" operation="open" profile="/sbin/dhclient" name="/var/lib/NetworkManager/dhclient-wlan0.conf" pid=824 comm="dhclient" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
    Sep 30 16:26:52 pc kernel: [   24.591193] audit: type=1400 audit(1475245612.336:147): apparmor="DENIED" operation="open" profile="/sbin/dhclient" name="/var/lib/NetworkManager/dhclient-ecd1a08a-cc0e-46ff-ad58-deb8cb1ab06b-wlan0.lease" pid=824 comm="dhclient" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
    Sep 30 16:26:52 pc kernel: [   24.591225] audit: type=1400 audit(1475245612.336:148): apparmor="DENIED" operation="open" profile="/sbin/dhclient" name="/var/lib/NetworkManager/dhclient-ecd1a08a-cc0e-46ff-ad58-deb8cb1ab06b-wlan0.lease" pid=824 comm="dhclient" requested_mask="wc" denied_mask="wc" fsuid=0 ouid=0
    Sep 30 16:26:52 pc kernel: [   24.612954] audit: type=1400 audit(1475245612.356:149): apparmor="DENIED" operation="exec" profile="/sbin/dhclient" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=825 comm="dhclient" requested_mask="x" denied_mask="x" fsuid=0 ouid=0
    Sep 30 16:26:52 pc kernel: [   24.620636] audit: type=1400 audit(1475245612.364:150): apparmor="DENIED" operation="capable" profile="/sbin/dhclient" pid=824 comm="dhclient" capability=13  capname="net_raw"
    Sep 30 16:28:09 pc kernel: [  102.091752] wlan0: deauthenticating from b0:c5:54:86:0e:da by local choice (Reason: 3=DEAUTH_LEAVING)
    Sep 30 16:28:09 pc kernel: [  102.127605] cfg80211: Calling CRDA to update world regulatory domain
Impossible de répondre pour le moment car aujourd’hui, il démarre normalement (c’est la première fois que cela arrive!).
Bonjour,[quote=“PascalHambourg, post:34, topic:71041”]
Elle ne concerne pas le clavier mais le touchpad, connecté au même contrôleur PS/2 (i8042). Mais c’est peut-être juste une coïncidence.
Une question que je n’ai pas encore posée : comment le touchpad se comporte-t-il dans les deux cas ?
Le touchpad fonctionne lorsque le démarrage se passe correctement par contre lorsqu’il ne se déroule pas convenablement celui-ci ne fonctionne pas.
J’ai remarqué aussi que lorsque le démarrage ne fonctionne pas, le curseur clignote mais quand je tape plusieurs fois sur des touches du clavier, celui-ci se fige.
Merci.
Donc ce n’est pas juste le clavier qui est affecté, c’est tout le PS/2.
Le pilote i8042 a un tas d’options mentionnées dans https://www.kernel.org/doc/Documentation/kernel-parameters.txt :
i8042.debug     [HW] Toggle i8042 debug mode
i8042.unmask_kbd_data
                [HW] Enable printing of interrupt data from the KBD port
                     (disabled by default, and as a pre-condition
                     requires that i8042.debug=1 be enabled)
i8042.direct    [HW] Put keyboard port into non-translated mode
i8042.dumbkbd   [HW] Pretend that controller can only read data from
                     keyboard and cannot control its state
                     (Don't attempt to blink the leds)
i8042.noaux     [HW] Don't check for auxiliary (== mouse) port
i8042.nokbd     [HW] Don't check/create keyboard port
i8042.noloop    [HW] Disable the AUX Loopback command while probing
                     for the AUX port
i8042.nomux     [HW] Don't check presence of an active multiplexing
                     controller
i8042.nopnp     [HW] Don't use ACPIPnP / PnPBIOS to discover KBD/AUX
                     controllers
i8042.notimeout [HW] Ignore timeout condition signalled by controller
i8042.reset     [HW] Reset the controller during init and cleanup
i8042.unlock    [HW] Unlock (ignore) the keylock
i8042.kbdreset  [HW] Reset device connected to KBD port
Il faudrait en essayer certaines, notamment dumbkbd, noaux, noloop, nomux, reset, kbdreset. Certaines auront pour effet de désactiver le touchpad, mais ce n’est pas gênant puisque tu utilises une souris USB.
Pour ajouter une option à la ligne de commande du noyau il faut l’ajouter dans la variable GRUB_CMDLINE_LINUX_DEFAULT du fichier /etc/default/grub, par exemple
GRUB_CMDLINE_LINUX_DEFAULT="quiet i8042.nomux"
et exécuter update-grub.
En cas de problème, les options de cette variable ne s’appliquent qu’au démarrage normal, pas au mode de dépannage. D’autre part il est possible d’effacer (temporairement) une option avec l’éditeur intégré du menu de GRUB (touche “e”).
Tu peux ajouter plusieurs de ces options à la fois.
Bon courage.
Merci beaucoup.
Le problème n’apparaît plus depuis 2 jours. Je croise les doigts:slight_smile:
C’est la commande GRUB_CMDLINE_LINUX_DEFAULT=“quiet i8042.noaux” qui a l’air de fonctionner.
A plus,
Donc en désactivant le touchpad ?
En as-tu essayées d’autres qui n’ont pas eu d’effet positif ?
Bonsoir,
Oui, c’était bien le touchpad.
J’ai essayé d’abord ceci mais cela n’a pas fonctionné.
GRUB_CMDLINE_LINUX_DEFAULT=“quiet i8042.dumbkbd”
Tu peux essayer les autres options. Il y en a peut-être une qui supprime le problème sans désactiver le touchpad.
@PascalHambourg
Juste une question pour Pascal, quand tu passes une telle option à “GRUB_CMDLINE_LINUX_DEFAULT”, comme dans ce cas où @Pauline1 a “mis en silence l’option i8042.noaux”, ça ne désactive pas le touchpad? Question de curiosité simplement, si jamais un jour je rencontre le même cas de figure…
“Mis en silence” ?
Un effet de cette option est effectivement de désactiver le touchpad PS/2 qui est connecté sur l’entrée AUX, je l’ai bien écrit.
J’ai traduit “quiet” littéralement…
Donc ça désactive bien le touchpad aussi bien au boot que pour la session courante à laquelle va se connecter l’utilisateur…?
Je pose la question parce que dans la doc https://www.kernel.org/doc/Documentation/kernel-parameters.txt je trouvais pas ça clair de mon point de vue :
Dans le sens où pour moi faire un check c’est rechercher le périphérique, pas forcément le désactiver complètement.
Ah, tu te méprends. “quiet” n’a rien à voir avec l’option qui suit, c’est juste une autre option passée au noyau dont le rôle est de supprimer l’affichage des messages “normaux” du noyau qui est présente par défaut dans l’entrée de démarrage normal.
L’option est prise en compte au démarrage suivant, pas dans la session en cours. On pourrait modifier le paramètre dans la session en cours s’il était présent dans /sys/module/i8042/parameters/, mais il n’y est pas (pas modifiable à chaud), seule l’option debug pour activer/désactiver le mode debug du pilote i8042 y est.
Certes, mais ne pas le rechercher c’est ne pas le trouver et ne pas le gérer, ce qui le rend indisponible et que j’ai appelé “désactiver”.
Oui laisse tomber… Après vérification du fichier /etc/default/grub, je me suis rendu compte que j’ai confondu les lignes “GRUB_CMDLINE_LINUX_DEFAULT” et “GRUB_CMDLINE_LINUX”, dans laquelle je n’ai jamais vu jusqu’à présent apparaître l’option “quiet”, c’est pour ça que je pensais qu’elle était liée au pilote, bref…
Oui évidemment.
Mais par contre c’est penible, parce que ça veut dire que si t’as pas une souris usb de secours, tu te retrouves sans souris/touchpad, et tu n’as que le clavier…
C’est pour cela que je me suis permis de la proposer, sachant qu’il y avait une souris USB et que le touchpad n’était pas utilisé.
C’est aussi pour cela que j’ai recommandé d’essayer d’autres options qui n’auront pas cet effet secondaire.
Bonsoir,
D’accord, je vais essayer les autres options.
Bonne soirée.
