Bonsoir, toujours dans mes mails …
[quote]# Performing system specific checks…
Performing checks for Linux/2…
Checking for single user-mode password…
Checking boot loader file permissions…
–WARN-- [boot06] The Grub bootloader does not have a password configured.
Checking for vulnerabilities in inittab configuration…
–FAIL-- [lin007w] Normal users can reboot the system through ctrl+alt+del in runlevels 12345
Checking for correct umask settings for init scripts…
–FAIL-- [misc017f] The umask setting in /etc/csh.login for the init scripts is insecure
–FAIL-- [misc017f] The umask setting in /etc/profile for the init scripts is insecure
Checking Logins not used on the system …
Checking network configuration
–WARN-- [lin012w] The system accepts ICMP redirection messages
–WARN-- [lin017w] The system is not configured to log suspicious (martian) packets
Verifying system specific password checks…
Checking OS release…
–WARN-- [osv004w] Unreleased Debian GNU/Linux version `testing/unstable’
Checking installed packages vs Debian Security Advisories…
Checking md5sums of installed files
Checking installed files against packages…
–WARN-- [lin001w] File /usr/X11R6/bin/bashbug' does not belong to any package. --WARN-- [lin001w] File
/usr/X11R6/bin/script’ does not belong to any package.
… à peu prés 20 pages de pkg /usr/X11R6/bin/* comme ça …
–WARN-- [lin001w] File /lib/modules/2.6.8-2-386/modules.ofmap' does not belong to any package. --WARN-- [lin001w] File
/lib/modules/2.6.8-2-386/modules.seriomap’ does not belong to any package.
–WARN-- [lin001w] File /sbin/apdbg' does not belong to any package. --WARN-- [lin001w] File
/usr/bin/gnome-clipboard-daemon’ does not belong to any package.[/quote]
le # Checking network configuration m’embête un peu, comment faire ?
ps: les autres warnings aussi d’ailleurs …
