Je suis sous debian etch, fraîchement installée. Ma carte graphique (Nvidia Geforce4 MX440) n’est pas detectée, quelque soit le driver employée (nvidia installée avec module-assistant, vesa ou nv n’ont pas fonctionnée). Voici le type d’erreur obtenue :
[code]X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux Cartman 2.6.18-4-686 #1 SMP Mon Mar 26 17:17:36 UTC 2007 i686
Build Date: 04 April 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Apr 28 13:37:11 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Televiseur Samsung HD Ready”
() | |–>Device “Nvidia Geforce4 MX440”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/share/fonts/X11/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(**) FontPath set to:
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(WW) xf86OpenConsole: setpgid failed: Operation not permitted
(WW) xf86OpenConsole: setsid failed: Operation not permitted
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7124 card 1631,7124 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7125 card 1631,1003 rev 03 class 03,00,00 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 11 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,2440 card 0000,0000 rev 11 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,244b card 1631,244b rev 11 class 01,01,80 hdr 00
(II) PCI: 00:1f:2: chip 8086,2442 card 1631,244b rev 11 class 0c,03,00 hdr 00
(II) PCI: 00:1f:3: chip 8086,2443 card 1631,244b rev 11 class 0c,05,00 hdr 00
(II) PCI: 00:1f:4: chip 8086,2444 card 1631,244b rev 11 class 0c,03,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,2445 card 1631,2002 rev 11 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10ec,8139 card 1429,d010 rev 10 class 02,00,00 hdr 00
(II) PCI: 01:05:0: chip 10de,0181 card 0000,0000 rev a4 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x000b (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xedd00000 - 0xefdfffff (0x2100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xddb00000 - 0xe5bfffff (0x8100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI: (0:1:0) Intel Corporation 82810E DC-133 CGC [Chipset Graphics Controller] rev 3, Mem @ 0xe8000000/26, 0xeff80000/19
(–) PCI:*(1:5:0) nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x] rev 164, Mem @ 0xee000000/24, 0xe0000000/26, BIOS @ 0xefde0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xefddff00 - 0xefddffff (0x100) MX[B]
[1] -1 0 0xddb00000 - 0xddb1ffff (0x20000) MXB
[2] -1 0 0xe0000000 - 0xe3ffffff (0x4000000) MXB
[3] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[4] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
[5] -1 0 0x0000dc80 - 0x0000dcbf (0x40) IX[B]
[6] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B]
[7] -1 0 0x0000dd80 - 0x0000dd9f (0x20) IX[B]
[8] -1 0 0x00000540 - 0x0000054f (0x10) IX[B]
[9] -1 0 0x0000dd00 - 0x0000dd1f (0x20) IX[B]
[10] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
(II) Inactive PCI resource ranges:
[0] -1 0 0xeff80000 - 0xefffffff (0x80000) MXB
[1] -1 0 0xe8000000 - 0xebffffff (0x4000000) MXB
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xefddff00 - 0xefddffff (0x100) MX[B]
[5] -1 0 0xddb00000 - 0xddb1ffff (0x20000) MXB
[6] -1 0 0xe0000000 - 0xe3ffffff (0x4000000) MXB
[7] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[8] -1 0 0xeff80000 - 0xefffffff (0x80000) MXB
[9] -1 0 0xe8000000 - 0xebffffff (0x4000000) MXB
[10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[12] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
[13] -1 0 0x0000dc80 - 0x0000dcbf (0x40) IX[B]
[14] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B]
[15] -1 0 0x0000dd80 - 0x0000dd9f (0x20) IX[B]
[16] -1 0 0x00000540 - 0x0000054f (0x10) IX[B]
[17] -1 0 0x0000dd00 - 0x0000dd1f (0x20) IX[B]
[18] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “v4l”
(WW) Warning, couldn’t open module v4l
(II) UnloadModule: “v4l”
(EE) Failed to load module “v4l” (module does not exist, 0)
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “vesa”
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.3.0
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) VESA: driver for VESA chipsets: vesa
(II) Primary Device is: PCI 01:05:0
(WW) VESA: No matching Device section for instance (BusID PCI:0:1:0) found
(WW) VESA: No matching Device section for instance (BusID PCI:1:5:0) found
(EE) No devices detected.
Fatal server error:
no screens found[/code]
Pourtant, la carte graphique est bien là : (attention, j’ai deux cartes graphiques !!, un intégrée, une intel, et celle que j’utilise et qui est reliée à ma télé, la Nvidia Geforce4 MX440) :
00:00.0 Host bridge: Intel Corporation 82810E DC-133 GMCH [Graphics Memory Controller Hub] (rev 03)
00:01.0 VGA compatible controller: Intel Corporation 82810E DC-133 CGC [Chipset Graphics Controller] (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 11)
00:1f.0 ISA bridge: Intel Corporation 82801BA ISA Bridge (LPC) (rev 11)
00:1f.1 IDE interface: Intel Corporation 82801BA IDE U100 (rev 11)
00:1f.2 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #1) (rev 11)
00:1f.3 SMBus: Intel Corporation 82801BA/BAM SMBus (rev 11)
00:1f.4 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #2) (rev 11)
00:1f.5 Multimedia audio controller: Intel Corporation 82801BA/BAM AC'97 Audio (rev 11)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
01:05.0 VGA compatible controller: nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x] (rev a4)
Quelques informations complémentaires :
*Linux Cartman 2.6.18-4-686 #1 SMP Mon Mar 26 17:17:36 UTC 2007 i686 GNU/Linux
*Processeur : Pentium 3 Coppermine
*reliée à un téléviseur samsung HD Ready (résolution max 1366x768)
Et mon xorg.conf lorsque j’utilise le drive nv
[code]Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load “freetype”
Load “glx”
Load "int10"
Load "record"
Load "v4l"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
EndSection
Section "Device"
Identifier "Nvidia Geforce4 MX440"
Driver "vesa"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Televiseur Samsung HD Ready"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Nvidia Geforce4 MX440"
Monitor "Televiseur Samsung HD Ready"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
