Suite à une mise à jour, la résolution de mon écran a changé. J’ai essayé de regarder dans le fichier Xorg.conf, mais sans succès. (pour le fichier xorg.conf, je n’en avais pas. j’en ai créé un avec la commande X -configure). Voici mon fichier Xorg.conf :
[code]Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 “Screen0” 0 0
Screen 1 “Screen1” RightOf "Screen0"
InputDevice “Mouse0” "CorePointer"
InputDevice “Keyboard0” "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "built-ins"
EndSection
Section "Module"
Load "glx"
Load "extmod"
Load "dri"
Load "record"
Load "dri2"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Monitor"
Identifier "Monitor1"
EndSection
Section “Device”
### Available Driver options are:-
### Values: : integer, : float, : “True”/“False”,
### : “String”, : " Hz/kHz/MHz",
### [arg]: arg optional
#Option “ShadowFB” # []
#Option “Rotate” #
#Option “fbdev” #
#Option “debug” # []
Identifier "Card0"
Driver "fbdev"
BusID "PCI:1:0:0"
EndSection
Section “Device”
#Option “DefaultRefresh” # []
#Option “ModeSetClearScreen” # []
Identifier "Card1"
Driver "vesa"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Dans les paramètres d’xfce4, pour l’affichage je n’ai que le choix entre les résolutions : 1024x768 et 800x600.
voici le résultat de la commande xrandr :$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 800 x 600, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
1024x768 61.0*
800x600 61.0
Pour ma carte graphique, c’est une carte nvidia, mais je n’ai pas installé de driver propriétaire suplémentaire.
Si vous aviez des solutions pour que je puisse améliorer la résolution de mon écran, n’hésitez pas.
En vous remerciant d’avance.
