[quote=“usinagaz”]Qu’est ce que ça veut dire c’est quoi ? (quelles dépendances ?).
ps: j’avais un peu lu la solution mondo, mais c’était payant encore à l’époque (quelsques mois).
Sur un système de fichier ext3 ??[/quote]OUI d’après ce qu’en dit Synaptic et je suis les essais de Matt car ça me semble être un soft intéressant.
[code]powerful disaster recovery suite
Mondo is reliable. It backs up your Debian GNU/Linux server or workstation to
tape, CD-R, CD-RW, NFS or hard disk partition. In the event of catastrophic
data loss, you will be able to restore all of your data [or as much as you
want], from bare metal if necessary. Mondo is in use by numerous blue-chip
enterprises and large organizations, dozens of smaller companies, and tens of
thousands of users.
Mondo is comprehensive. Mondo supports LVM, RAID, ext2, ext3, JFS, XFS,
ReiserFS, VFAT, and can support additional file systems easily. It supports
adjustments in disk geometry, including migration from non-RAID to RAID. Mondo
runs on all major Linux distributions and is getting better all the time. You
may even use it to backup non-Linux partitions, such as NTFS.
Homepage: http://www.mondorescue.org[/code]
