Pas de chance aujourd’hui, mon scanner EPSON
est bien reconnus mais xsane
veux pas le détecter:
root@debian:/etc/udev/rules.d# /etc/init.d/udev restart
[ ok ] Restarting udev (via systemctl): udev.service.
root@debian:/etc/udev/rules.d# scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
root@debian:/etc/udev/rules.d# sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x04b8 [EPSON], product=0x013a [EPSON Scanner]) at libusb:001:004
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
J’ai testé mon user et root
, avec le même résultat.
Ce scanner fonctionne très bien sur mon laptop avec la même config debian
merci,
