Scripts pour Nautilus
Je sais pas si vous connaissez mais c’ est mortel: 125 scripts multimédias et systèmes, entièrement automatisés et accessibles d’ un seul clicque-droit en pointant sur n’ importe quel fichier.
Téléchager:
Déarchiver:
tar -zxvf nautilus-scripts.tar.gz
Ensuite il faut mettre ces dossiers dans nautilus-scripts qui se trouve dans le dossier .gnome2, ~/ .gnome2/nautilus-scripts
Voilà la liste:
[quote]nautilus-scripts/
nautilus-scripts/Archiving/
nautilus-scripts/Archiving/Compress__.bz2_
nautilus-scripts/Archiving/Compress__.gz_
nautilus-scripts/Archiving/Decompress
nautilus-scripts/Archiving/archiver-unarchiver
nautilus-scripts/Archiving/gnome-archive
nautilus-scripts/Archiving/super-extractor
nautilus-scripts/Archiving/unrar
nautilus-scripts/Execute/
nautilus-scripts/Execute/Open Terminal Here
nautilus-scripts/Execute/Play in XMMS
nautilus-scripts/Execute/XMMS
nautilus-scripts/Execute/command_prompt_here
nautilus-scripts/Execute/gedit
nautilus-scripts/Execute/ghex
nautilus-scripts/Execute/glimmer
nautilus-scripts/Execute/gnome2-terminal-here
nautilus-scripts/Execute/root-nautilus-here
nautilus-scripts/Execute/root-terminal-here
nautilus-scripts/Execute/run
nautilus-scripts/Execute/terminal-here
nautilus-scripts/Execute/xemacs
nautilus-scripts/Execute/xine
nautilus-scripts/Execute/xsu-terminal-here
nautilus-scripts/File Info/
nautilus-scripts/File Info/FileUsedBy
nautilus-scripts/File Info/Search Here
nautilus-scripts/File Info/Show MD5 Sum
nautilus-scripts/File Info/Show_Parameters
nautilus-scripts/File Info/filetype
nautilus-scripts/File Info/ggrep
nautilus-scripts/File Info/gtk-du
nautilus-scripts/File Info/gtk2-du
nautilus-scripts/File Info/gtk2-grep
nautilus-scripts/File Info/mimetype
nautilus-scripts/File Info/wordcount
nautilus-scripts/File Processing/
nautilus-scripts/File Processing/Mail In Evolution
nautilus-scripts/File Processing/New Text Document
nautilus-scripts/File Processing/concatenate
nautilus-scripts/File Processing/dos2unix
nautilus-scripts/File Processing/doublespace
nautilus-scripts/File Processing/latex
nautilus-scripts/File Processing/latex2ps
nautilus-scripts/File Processing/mail_file
nautilus-scripts/File Processing/mail_file2
nautilus-scripts/File Processing/maker
nautilus-scripts/File Processing/new-text-document
nautilus-scripts/File Processing/pdf2ps
nautilus-scripts/File Processing/pixdir2html.pl
nautilus-scripts/File Processing/pprint
nautilus-scripts/File Processing/print
nautilus-scripts/File Processing/print_with_openoffice
nautilus-scripts/File Processing/ps2pdf
nautilus-scripts/File Processing/scp2host
nautilus-scripts/File Processing/scp_to_host
nautilus-scripts/File Processing/search_n_replace
nautilus-scripts/File Processing/secure copy
nautilus-scripts/File Processing/superexec.py
nautilus-scripts/File System Management/
nautilus-scripts/File System Management/Get Photos
nautilus-scripts/File System Management/Junksorter.pl
nautilus-scripts/File System Management/Make Link
nautilus-scripts/File System Management/QuickBurn
nautilus-scripts/File System Management/Search Here
nautilus-scripts/File System Management/UnExec
nautilus-scripts/File System Management/burn_dir
nautilus-scripts/File System Management/burn_iso
nautilus-scripts/File System Management/change_name
nautilus-scripts/File System Management/chmod
nautilus-scripts/File System Management/chmog
nautilus-scripts/File System Management/copyhome
nautilus-scripts/File System Management/junksorter
nautilus-scripts/File System Management/linker
nautilus-scripts/File System Management/lowercase
nautilus-scripts/File System Management/mount_loopback
nautilus-scripts/File System Management/moveup
nautilus-scripts/File System Management/set_exec
nautilus-scripts/File System Management/set_read_only
nautilus-scripts/File System Management/shredder
nautilus-scripts/File System Management/uppercase
nautilus-scripts/Multimedia/
nautilus-scripts/Multimedia/Create_Thumbnail
nautilus-scripts/Multimedia/Naudilus
nautilus-scripts/Multimedia/Play_in_XMMS
nautilus-scripts/Multimedia/Queue to XMMS
nautilus-scripts/Multimedia/Show Digital Photo EXIF data
nautilus-scripts/Multimedia/XMMS_Enqueue
nautilus-scripts/Multimedia/convert_to_jpeg
nautilus-scripts/Multimedia/convert_to_png
nautilus-scripts/Multimedia/create-vcd
nautilus-scripts/Multimedia/dv_to_mpg
nautilus-scripts/Multimedia/mirror_jpg
nautilus-scripts/Multimedia/queue_to_xmms
nautilus-scripts/Multimedia/rotate
nautilus-scripts/Multimedia/rotate_image
nautilus-scripts/Multimedia/rotate_jpg_left
nautilus-scripts/Multimedia/rotate_jpg_right
nautilus-scripts/Multimedia/scale_image
nautilus-scripts/Multimedia/scale_image_to_sizes
nautilus-scripts/Multimedia/slideshow
nautilus-scripts/Multimedia/watermark
nautilus-scripts/Obsolete/
nautilus-scripts/Obsolete/RPM-install-update
nautilus-scripts/Obsolete/bzip2
nautilus-scripts/Obsolete/converter
nautilus-scripts/Obsolete/create-zip
nautilus-scripts/Obsolete/create_file
nautilus-scripts/Obsolete/create_targz
nautilus-scripts/Obsolete/gb-unzip
nautilus-scripts/Obsolete/gzip
nautilus-scripts/Obsolete/mail_image
nautilus-scripts/Obsolete/mailinbalsa
nautilus-scripts/Obsolete/to_upper
nautilus-scripts/Obsolete/uncompress_all
nautilus-scripts/System Configuration/
nautilus-scripts/System Configuration/Debian_Package
nautilus-scripts/System Configuration/Hide or Show Hidden Files
nautilus-scripts/System Configuration/Install to Palm
nautilus-scripts/System Configuration/Install_Galeon_Theme
nautilus-scripts/System Configuration/Query_RPM
nautilus-scripts/System Configuration/RPM-install-update
nautilus-scripts/System Configuration/RPM-tools
nautilus-scripts/System Configuration/Set image as Wallpaper
nautilus-scripts/System Configuration/Set_as_Directory_Icon
nautilus-scripts/System Configuration/Set_as_Wallpaper
nautilus-scripts/System Configuration/Show_Directory_Metafile
nautilus-scripts/System Configuration/archiver-config
nautilus-scripts/System Configuration/install_rpm
nautilus-scripts/System Configuration/make-nautilus-script
nautilus-scripts/System Configuration/make_launcher
nautilus-scripts/System Configuration/pseudo-nautilus
nautilus-scripts/System Configuration/pynautilus[/quote]
Il y a une petite coquille dans l’URL de l’archive : c’est g-scripts.sourceforge.net/ qu’il faut utiliser.
Sinon, intéressant comme lien. Il va falloir faire le tri parce que je trouve que c’est peu utilisable comme tel (il y a bien trop de choses), mais il y en a de très utiles.
GCaron dit:
:question: … Je viens de faire l’ essaie le téléchargement s’ effectue sans problème…
…peut être que wget n’ est pas installé chez toi
Je confirme la coquille, il n’y a pas de ‘s’ à sourceforge.
OK j’ ai corrigé. C’est curieux parce que le télé-chargement fonctionnait tout de même…enfin bon, merci de m’ avoir rectifier.
ouaip, j’ai testé pour voir, le téléchargement avait l’air de fonctionner, mais impossible d’ouvrir l’archive obtenue ou d’en extraire des fichiers : ça renvoi une erreur du genre “archive corrompue”.
Normal, ça télécharge une page HTML à la place :slightly_smiling:.
Tout à fait, c’était juste pour dire que même si le téléchargement à l’air de se faire, en fait ce n’est pas l’archive voulue qui arrive.
hello
j’ ai re-refait un télé-chargement et chez moi tout fonctionne, comme je l’ indique plus haut…
Je confirme:
wget g-scripts.sourceforge.net/nautil … pts.tar.gz
OK
Toujours d’actualité et fonctionne très bien. Je n’ai pas encore testé tout les scripts mais DL sans souci.
