Bonsoir,
Effectivement, tu avais raison, il a suffit de ressaisir les lignes pour que le compilation se termine.
Donc, compil’ OK mais résultat KO…
J’essais de lancer un download,en raccourcis clavier ou via le menu de la souris, (d’une page web ou d’un fichier) et rien ne se passe, rien ne se lance.
Voici mon config.h :
[code]/* modifier 0 means no modifier */
static char *useragent = “Mozilla/5.0 (X11; U; Linux; en-us) AppleWebKit/531.2+ (KHTML, like Gecko, surf-“VERSION”) Safari/531.2+”;
static char *progress = “#FF0000”;
static char *progress_trust = “#00FF00”;
static char *stylefile = “.surf/style.css”;
static char *scriptfile = “.surf/script.js”;
static char *cookiefile = “.surf/cookies.txt”;
static char *dldir = “/home/m3t4linux/temp/”;
static time_t sessiontime = 3600;
static int indicator_thickness = 4;
#define SETPROP§ { .v = (char *[]){ “/bin/sh”, “-c”,
“prop=”dmenu < /dev/null
“xprop -id $1 -f $0 8s -set $0 “$prop””,
p, winid, NULL } }
#define MODKEY GDK_CONTROL_MASK
#define DLOAD { .v = (char *[]){ “/bin/sh”, “-c”,
“~/.surf/dmenudl.sh $0”, winid, NULL } }
#define CLIVE { .v = (char *[]){ “/bin/zsh”, “-c”,
“~/.surf/clivesurf.sh $0”, winid, NULL } }
static Key keys[] = {
/* modifier keyval function arg Focus */
{ MODKEY|GDK_SHIFT_MASK,GDK_r, reload, { .b = TRUE } },
{ MODKEY, GDK_r, reload, { .b = FALSE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_p, print, { 0 } },
{ MODKEY, GDK_p, clipboard, { .b = TRUE } },
{ MODKEY, GDK_y, clipboard, { .b = FALSE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_j, zoom, { .i = -1 } },
{ MODKEY|GDK_SHIFT_MASK,GDK_k, zoom, { .i = +1 } },
{ MODKEY|GDK_SHIFT_MASK,GDK_i, zoom, { .i = 0 } },
{ MODKEY, GDK_l, navigate, { .i = +1 } },
{ MODKEY, GDK_h, navigate, { .i = -1 } },
{ MODKEY, GDK_j, scroll, { .i = +1 } },
{ MODKEY, GDK_k, scroll, { .i = -1 } },
{ 0, GDK_Escape, stop, { 0 } },
{ MODKEY, GDK_o, source, { 0 } },
{ MODKEY, GDK_g, spawn, SETPROP("_SURF_URI") },
{ MODKEY, GDK_colon, spawn, SETPROP("_SURF_FIND") },
{ MODKEY, GDK_n, find, { .b = TRUE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_n, find, { .b = FALSE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_v, spawn, CLIVE },
{ MODKEY, GDK_d, download, { 0 } },
{ MODKEY, GDK_w, newwindow, { .v = NULL } },
{ MODKEY, GDK_a, spawn, DLOAD },
static Item items[] = {
{ “Back”, navigate, { .i = -1 } },
{ “Forward”, navigate, { .i = +1 } },
{ “New Window”, newwindow, { .v = NULL } },
{ “Reload”, reload, { .b = FALSE } },
{ “Stop”, stop, { 0 } },
{ “Paste URI”, clipboard, { .b = TRUE } },
{ “Copy URI”, clipboard, { .b = FALSE } },
{ “Download”, download, { 0 } },
{ “Cclive”, spawn, CLIVE },
{ “Dmenuload”, spawn, DLOAD },
static SearchEngine searchengines[] = {
{ “g”, “http://www.google.fr/search?q=%s” },
{ “s”, “http://www.seeks-project.info/search.php/search?q=%s&qknowm=%s&expansion=1&action=expand” },
Sinon, j’ai resaisi le script de Thuban
Qu’ais je pu louper??
