J’ai un petit soucis avec ces paramètres de Clive
Le #make clean install
m’indique " [quote]error: ‘clive’ undeclared here (not in a function)[/quote]
A priori, le define est défaillant dans mon config.h
Voici ce que j’ai ajouté :
[code]/* modifier 0 means no modifier */
static char *useragent = “Mozilla/5.0 (X11; U; Linux; en-us) AppleWebKit/531.2+ (KHTML, like Gecko, surf-“VERSION”) Safari/531.2+”;
static char *progress = “#FF0000”;
static char *progress_trust = “#00FF00”;
static char *stylefile = “.surf/style.css”;
static char *scriptfile = “.surf/script.js”;
static char *cookiefile = “.surf/cookies.txt”;
static char *dldir = “/home/m3t4linux/temp”;
static time_t sessiontime = 3600;
#define SETPROP§ { .v = (char *[]){ “/bin/sh”, “-c”,
“prop=”xprop -id $1 $0 | cut -d '\"' -f 2 | dmenu
“xprop -id $1 -f $0 8s -set $0 “$prop””,
p, winid, NULL } }
#define MODKEY GDK_CONTROL_MASK
#define CLIVE { .v = (char []){ “/bin/zsh”, “-c”,
“~/.surf/clivesurf.sh $0”, winid, NULL } }
static Key keys[] = {
/ modifier keyval function arg Focus */
{ MODKEY|GDK_SHIFT_MASK,GDK_r, reload, { .b = TRUE } },
{ MODKEY, GDK_r, reload, { .b = FALSE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_p, print, { 0 } },
{ MODKEY, GDK_p, clipboard, { .b = TRUE } },
{ MODKEY, GDK_y, clipboard, { .b = FALSE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_j, zoom, { .i = -1 } },
{ MODKEY|GDK_SHIFT_MASK,GDK_k, zoom, { .i = +1 } },
{ MODKEY|GDK_SHIFT_MASK,GDK_i, zoom, { .i = 0 } },
{ MODKEY, GDK_l, navigate, { .i = +1 } },
{ MODKEY, GDK_h, navigate, { .i = -1 } },
{ MODKEY, GDK_j, scroll, { .i = +1 } },
{ MODKEY, GDK_k, scroll, { .i = -1 } },
{ 0, GDK_Escape, stop, { 0 } },
{ MODKEY, GDK_o, source, { 0 } },
{ MODKEY, GDK_g, spawn, SETPROP("_SURF_URI") },
{ MODKEY, GDK_colon, spawn, SETPROP("_SURF_FIND") },
{ MODKEY, GDK_n, find, { .b = TRUE } },
{ MODKEY|GDK_SHIFT_MASK,GDK_n, find, { .b = FALSE } },
{ MODKEY, GDK_v, clive, { 0 } }
};[/code]
Je n’ai peut être pas mis quelque chose au bon endroit…
