pour la commande cité ci-dessus,
root@alpha30:~# systemctl -a
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-sys-fs-binfmt_misc.automount loaded failed failed Arbitrary Executable File Formats File System Automount Point
dev-disk-by\x2did-ata\...CZ\x2dVECTOR_OCZ\x2dH27R61OSGJ789D37.device loaded active plugged OCZ-VECTOR
dev-disk-by\x2did-ata\...TOR_OCZ\x2dH27R61OSGJ789D37\x2dpart1.device loaded active plugged OCZ-VECTOR
dev-d
atop.service loaded active running LSB: Monitor for system resources and process activity
auditd.service not-found inactive dead auditd.service
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
avahi.service not-found inactive dead avahi.service
bind9.service loaded active running BIND Domain Name Server
bindg
j’ai des “UNITS” not-found,
à priori ce n’est pas bloquant puisque je boote
A+
JB1
