Tas de problèmes de firmwares
Tags: #<Tag:0x00007f46a8345440> #<Tag:0x00007f46a8345300> #<Tag:0x00007f46a8345210> #<Tag:0x00007f46a83450d0>
Bonjour, je suis déjà sur debian testing, pourtant j’ai toujours des problèmes avec les drivers pour iwlwifi and bluetooth. Mon processeur est le intel R N100.
Que dois-je faire ?
[    5.394045] bluetooth hci0: firmware: failed to load intel/ibt-0040-1050.sfi (-2)
[    5.394089] bluetooth hci0: firmware: failed to load intel/ibt-0040-1050.sfi (-2)
[    5.395163] Bluetooth: hci0: Reading supported features failed (-56)
[    5.419515] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-83.ucode (-2)
[    5.419543] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-83.ucode (-2)
[    5.419554] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-83.ucode failed with error -2
[    5.419573] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-82.ucode (-2)
[    5.419593] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-82.ucode (-2)
[    5.419604] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-82.ucode failed with error -2
[    5.419615] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-81.ucode (-2)
[    5.419633] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-81.ucode (-2)
[    5.419644] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-81.ucode failed with error -2
[    5.419655] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-80.ucode (-2)
[    5.419674] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-80.ucode (-2)
[    5.419684] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-80.ucode failed with error -2
[    5.419694] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-79.ucode (-2)
[    5.419728] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-79.ucode (-2)
[    5.419740] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-79.ucode failed with error -2
[    5.419752] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-78.ucode (-2)
[    5.419771] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-78.ucode (-2)
[    5.419782] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-78.ucode failed with error -2
[    5.419793] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-77.ucode (-2)
[    5.419811] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-77.ucode (-2)
[    5.419822] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-77.ucode failed with error -2
[    5.419833] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-76.ucode (-2)
[    5.419851] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-76.ucode (-2)
[    5.419862] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-76.ucode failed with error -2
[    5.419875] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-75.ucode (-2)
[    5.419894] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-75.ucode (-2)
[    5.419905] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-75.ucode failed with error -2
[    5.419918] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-74.ucode (-2)
[    5.419939] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-74.ucode (-2)
[    5.419940] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-74.ucode failed with error -2
[    5.419950] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-73.ucode (-2)
[    5.419958] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-73.ucode (-2)
[    5.419990] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-73.ucode failed with error -2
[    5.431957] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    5.431967] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    5.667480] thermal thermal_zone2: failed to read out thermal zone (-61)
Comme toujours pour ce genre de demande, quel est le contenu du fichier /etc/apt/sources.list.
Éventuellement, fournir aussi la sortie de sudo lshw -c network et de sudo lshw -c communicationpour identifier tes 2 composants.
il semble que
iwlwifi-so-a0-hr-b0-82.ucode-82
et
iwlwifi-so-a0-hr-b0-82.ucode-83
ne soient pas dans les paquets debian
mais peut être sont-ils sur une autre distrib
Cependant d’après cette page , Bug#1062703: firmware-realtek: Direct firmware load for rtl_nic/rtl8125b-2.fw failed with error -2, ces erreurs signifient que , ne voyant pas le -83 ça cherche le -82 puis le -81 …
Mais le -79 existe déjà dans bookworm donc l’instalaltion de firmware-iwlwifi DOIT résoudre le problème ( les messages sur 82,81,80 resteront peut être)
SINON le problème vient d’ailleurs
drm@B8-97-5A-F9-E4-87 /> doas lshw -c network; doas lshw -c
  *-network
       description: Wireless interface
       product: CNVi: Wi-Fi
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlo1
       version: 00
       serial: ca:3a:2b:d9:57:6e
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=6.6.15-amd64 firmware=72.daa05125.0 so-a0-hr-b0-72.uc latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: iomemory:600-5ff irq:16 memory:6001134000-6001137fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: enp1s0
       version: 15
       serial: 7c:83:34:bc:ec:92
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.6.15-amd64 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.8.185 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:18 ioport:3000(size=256) memory:80504000-80504fff memory:80500000-80503fff
Hardware Lister (lshw) -
usage: lshw [-format] [-options ...]
       lshw -version
	-version        print program version ()
format can be
	-html           output hardware tree as HTML
	-xml            output hardware tree as XML
	-json           output hardware tree as a JSON object
	-short          output hardware paths
	-businfo        output bus information
options can be
	-class CLASS    only show a certain class of hardware
	-C CLASS        same as '-class CLASS'
	-c CLASS        same as '-class CLASS'
	-disable TEST   disable a test (like pci, isapnp, cpuid, etc. )
	-enable TEST    enable a test (like pci, isapnp, cpuid, etc. )
	-quiet          don't display status
	-sanitize       sanitize output (remove sensitive information like serial numbers, etc.)
	-numeric        output numeric IDs (for PCI, USB, etc.)
	-notime         exclude volatile attributes (timestamps) from output
deb http://deb.debian.org/debian testing main non-free non-free-firmware
deb-src http://deb.debian.org/debian testing main non-free non-free-firmware
deb http://deb.debian.org/debian-security/ testing-security main non-free  non-free-firmware
deb-src http://deb.debian.org/debian-security/ testing-security main non-free  non-free-firmware
deb http://deb.debian.org/debian testing-updates main non-free  non-free-firmware
deb-src http://deb.debian.org/debian testing-updates main non-free non-free-firmware
deb http://deb.debian.org/debian stable main non-free non-free-firmware
deb-src http://deb.debian.org/debian stable main non-free non-free-firmware
deb http://deb.debian.org/debian-security/ stable-security main non-free  non-free-firmware
deb-src http://deb.debian.org/debian-security/ stable-security main non-free  non-free-firmware
deb http://deb.debian.org/debian stable-updates main non-free  non-free-firmware
deb-src http://deb.debian.org/debian stable-updates main non-free non-free-firmware
Bon, ton sources.list contient à la fois la version stable et la version testing, je ne sais pas si c’est recommandé. Je laisse les experts répondre…
Sinon, ton wifi et ton bluetooth fonctionnent ou pas ? tu dis « j’ai des pbs avec les drivers », ce n’est pas clair. Est-ce que ce sont juste les messages qui te gênent ?
et tu n’as pas contrib
j’ai enlevé les doublons, et rajouter contrib.
Pour ce qui est du wifi, je n’ai pas de réseau là ou je suis donc je ne sais pas, rien n’apparait dans nmtui. Mais les interfaces semblent toutes là. Et ça a marché une fois donc ça doit être bon.
Par contre, bluetooth… Blueman crashes sans ouvrir, et blueberry est ininstallable. L’outil en ligne de commande dit qu’il n’y a pas d’adaptateur disponible. Je n’en sais pas pas plus et n’y comprend rien, bluetooth sur linux (comparé à son utilisation sur les téléphones) est un tas d’excrément puant.
Si vous voulez là-dessus il va falloir me donner les commandes une par une.
