Too many HDMI devices
bonjour,
j’ai cela avec dmesg :
snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 8.216050] Too many HDMI devices
[ 8.216052] Too many HDMI devices
[ 8.216053] Too many HDMI devices
[ 8.216055] Too many HDMI devices
[ 8.216056] Too many HDMI devices
[ 8.216057] Too many HDMI devices
[ 8.216058] Too many HDMI devices
[ 8.216059] Too many HDMI devices
[ 8.216150] hda-codec: out of range cmd 0:0:de0c:707:40
[ 8.216199] hda-codec: out of range cmd 0:0:de0c:708:de8c
[ 8.216333] hda-codec: out of range cmd 0:0:f589:707:40
[ 8.216379] hda-codec: out of range cmd 0:0:f589:708:f589
[ 8.216494] HDMI status: Codec=0 Pin=2 Presence_Detect=0 ELD_Valid=0
[ 8.216512] hda-codec: out of range cmd 0:0:e0:f0d:0
[ 8.216582] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 8.216632] HDMI status: Codec=0 Pin=7 Presence_Detect=0 ELD_Valid=0
[ 8.216684] HDMI status: Codec=0 Pin=9 Presence_Detect=0 ELD_Valid=0
[ 8.216716] hda-codec: out of range cmd 0:0:de0c:f00:c
[ 8.216762] hda-codec: out of range cmd 0:0:de0c:709:0
[ 8.216808] hda-codec: out of range cmd 0:0:de0c:f09:0
[ 8.216854] HDMI status: Codec=0 Pin=56844 Presence_Detect=1 ELD_Valid=1
[ 8.216856] hda-codec: out of range cmd 0:0:de0c:f2e:8
[ 8.216903] hda-codec: out of range cmd 0:0:de0c:709:0
[ 8.216948] hda-codec: out of range cmd 0:0:de0c:f09:0
[ 8.217039] HDMI status: Codec=0 Pin=0 Presence_Detect=0 ELD_Valid=0
[ 8.217096] HDMI status: Codec=0 Pin=1 Presence_Detect=0 ELD_Valid=0
[ 8.217134] hda_codec: cannot build controls for #0 (error -16)
[ 8.217181] hda_codec: cannot revert codec
[ 8.217572] snd_hda_intel: probe of 0000:01:00.1 failed with error -16
[ 9.844433] Adding 976892k swap on /dev/sda5. Priority:-1 extents:1 across:976892k
[ 9.860418] EXT4-fs (sda6): re-mounted. Opts: (null)
[ 10.085516] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
avec niko@PC-de-nico:~$ aplay -l j’ai :
**** Liste des Périphériques Matériels PLAYBACK ****
carte 0: PCH [HDA Intel PCH], périphérique 0: VT1708S Analog [VT1708S Analog]
Sous-périphériques: 1/1
Sous-périphérique #0: subdevice #0
carte 0: PCH [HDA Intel PCH], périphérique 1: VT1708S Digital [VT1708S Digital]
carte 0: PCH [HDA Intel PCH], périphérique 2: VT1708S HP [VT1708S HP]
avec niko@PC-de-nico:~$ lspci | grep -i audio j’ai :
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Device aab0
J’ai regardé sur les forums je n’ai rien trouvé.
Je n’ai pas de matériel hdmi.
je ne comprend pas ces sorties du journal d’erreur.
Comme des fois le pc ce bloque au démarrage(clavier n’accepte pas les raccourci, il me marque des truc bizar lorsque je tape, donc obligée de reboot, j’aimerais avoir un dmesg clean .
J’ai exactement le même problème de messages au démarrage. Je ne sais si c’est lié, mais j’ai un problème de stabilité au boot à froid (avec parfois des traces de registre suite à un plantage).
Nous ne sommes pas les seuls. Un bug est ouvert : 708704 http://lists.debian.org/debian-kernel/2013/05/msg00424.html
Le problème est soulevé ici :
http://forums.debian.net/viewtopic.php?f=7&t=104462
http://forums.linuxmint.com/viewtopic.php?f=46&t=110690
Mais pas de solution à l’horizon :angry:
Voici mon log dmesg:
11 Mouse [Logitech Unifying Device. Wireless PID:101a] on usb-0000:00:12.0-3:1 [ 3.362029] Too many HDMI devices [ 3.362036] Too many HDMI devices [ 3.362041] Too many HDMI devices [ 3.362045] Too many HDMI devices [ 3.362048] Too many HDMI devices [ 3.362052] Too many HDMI devices [ 3.362055] Too many HDMI devices [ 3.362058] Too many HDMI devices [ 3.362172] hda-codec: out of range cmd 0:0:9e5c:707:40 [ 3.362271] hda-codec: out of range cmd 0:0:9e5c:708:9edc [ 3.362586] HDMI status: Codec=0 Pin=2 Presence_Detect=0 ELD_Valid=0 [ 3.362616] hda-codec: out of range cmd 0:0:e0:f0d:0 [ 3.362736] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0 [ 3.362808] HDMI status: Codec=0 Pin=7 Presence_Detect=0 ELD_Valid=0 [ 3.362889] HDMI status: Codec=0 Pin=9 Presence_Detect=0 ELD_Valid=0 [ 3.362948] hda-codec: out of range cmd 0:0:9e5c:f00:c [ 3.363038] hda-codec: out of range cmd 0:0:9e5c:709:0 [ 3.363127] hda-codec: out of range cmd 0:0:9e5c:f09:0 [ 3.363217] HDMI status: Codec=0 Pin=40540 Presence_Detect=1 ELD_Valid=1 [ 3.363223] hda-codec: out of range cmd 0:0:9e5c:f2e:8 [ 3.363313] hda-codec: out of range cmd 0:0:9e5c:709:0 [ 3.363402] hda-codec: out of range cmd 0:0:9e5c:f09:0 [ 3.363578] HDMI status: Codec=0 Pin=0 Presence_Detect=0 ELD_Valid=0 [ 3.363674] HDMI status: Codec=0 Pin=1 Presence_Detect=0 ELD_Valid=0 [ 3.363756] hda_codec: cannot build controls for #0 (error -16) [ 3.363858] hda_codec: cannot revert codec [ 3.364525] snd_hda_intel: probe of 0000:01:00.1 failed with error -16 [ 4.505430] Adding 1954444k swap on /dev/sdb3. Priority:-1 extents:1 across:
Si quelqu’un a une idée :slightly_smiling:
J’aimerai bien stabiliser le démarrage (Ma femme et mes enfants rales)…
Merci :slightly_smiling:
Je cite ton lien,
[quote]Conclusion HDMI-Audio isn’t working with the 3.2 kernel.
Aplay or /proc/asound/cards not show HDMI-Audio only the mainboard-audio.
Other kernel like 3.8 from unstable or 3.5 from an ubuntu-distribution are working fine.[/quote]
Si on s’y fie, il te suffirait d’utiliser un kernel plus récent, comme par exemple via les dépots backports.
isalo.org/wiki.debian-fr/So … _Backports
Bonjour Zbf, merci pour ta remarque.
Dans mon cas, j’utilise les sorties analogiques de la carte mère et son chip audio VT1708S. Et l’audio fonctionne ainsi.
Je n’utilise pas le port HDMI de la carte vidéo. J’ai choisi un chip GPU pas trop récent, pour la stabilité…
C’est aussi la raison pour laquelle je suis sur stable et pas testing.
En utilisant un backport pour le noyau, n’y a-t-il pas des risques d’introduire des régressions?
C’est justement un peu le principe des backports, de proposer un régime de stabilité “alternatif” tout en proposant des versions plus récentes pour des besoins spécifiques.
