Bjr,
Après un erreur au boot de ufw (j’utilise gufw qui ne démarrait pas), je l’ai désinstallé. J’ai voulu voir ce qui se passait dans iptables :
root@Bureau:~# iptables -L #### exécuté après suppression de ufw et gufw #####
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT udp -- anywhere anywhere udp dpt:19859
ufw-before-logging-input all -- anywhere anywhere
ufw-before-input all -- anywhere anywhere
ufw-after-input all -- anywhere anywhere
ufw-after-logging-input all -- anywhere anywhere
ufw-reject-input all -- anywhere anywhere
ufw-track-input all -- anywhere anywhere
Chain FORWARD (policy DROP)
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ufw-before-logging-forward all -- anywhere anywhere
ufw-before-forward all -- anywhere anywhere
ufw-after-forward all -- anywhere anywhere
ufw-after-logging-forward all -- anywhere anywhere
ufw-reject-forward all -- anywhere anywhere
ufw-track-forward all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- anywhere anywhere
ufw-before-output all -- anywhere anywhere
ufw-after-output all -- anywhere anywhere
ufw-after-logging-output all -- anywhere anywhere
ufw-reject-output all -- anywhere anywhere
ufw-track-output all -- anywhere anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere icmp destination-unreachable
ACCEPT icmp -- anywhere anywhere icmp source-quench
ACCEPT icmp -- anywhere anywhere icmp time-exceeded
ACCEPT icmp -- anywhere anywhere icmp parameter-problem
ACCEPT icmp -- anywhere anywhere icmp echo-request
ufw-user-forward all -- anywhere anywhere
Chain ufw-before-input (1 references)
ufw-logging-deny all -- anywhere anywhere ctstate INVALID
DROP all -- anywhere anywhere ctstate INVALID
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ufw-not-local all -- anywhere anywhere
ACCEPT udp -- anywhere 224.0.0.251 udp dpt:mdns
ACCEPT udp -- anywhere 239.255.255.250 udp dpt:1900
ufw-user-input all -- anywhere anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all -- anywhere anywhere
Chain ufw-logging-allow (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all -- anywhere anywhere ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all -- anywhere anywhere ADDRTYPE match dst-type LOCAL
RETURN all -- anywhere anywhere ADDRTYPE match dst-type MULTICAST
RETURN all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all -- anywhere anywhere limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp -- anywhere anywhere ctstate NEW
ACCEPT udp -- anywhere anywhere ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT udp -- anywhere anywhere udp dpt:10263
ACCEPT udp -- anywhere anywhere udp dpt:10298
ACCEPT tcp -- anywhere anywhere tcp dpt:10478
ACCEPT tcp -- anywhere anywhere tcp dpt:15487
ACCEPT udp -- anywhere anywhere udp dpt:15487
ACCEPT tcp -- anywhere anywhere tcp dpt:ipp
ACCEPT udp -- anywhere anywhere udp dpt:ipp
ACCEPT udp -- anywhere anywhere udp dpt:1900
ACCEPT tcp -- anywhere anywhere tcp dpt:47896
ACCEPT udp -- anywhere anywhere udp dpt:47896
ACCEPT tcp -- anywhere anywhere tcp dpt:14896
ACCEPT udp -- anywhere anywhere multiport dports netbios-ns,netbios-dgm
ACCEPT udp -- anywhere Bureau multiport sports netbios-ns,netbios-dgm
ACCEPT tcp -- anywhere anywhere multiport dports netbios-ssn,microsoft-ds
ACCEPT tcp -- anywhere anywhere tcp dpt:mysql
ACCEPT udp -- anywhere anywhere udp dpt:19866
Chain ufw-user-limit (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT all -- anywhere anywhere reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
On voit que iptables fait encore référence à ufw (y compris les ports ouverts par moi grâce à ufw), et ce même après désinstallation. Soit, je “réinitialise” iptables :
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t mangle -F
iptables -t mangle -X
iptables -P INPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -P OUTPUT ACCEPT
Résultat ok (enfin je crois…) :
Chain INPUT (policy ACCEPT)
Chain FORWARD (policy ACCEPT)
MAIS, après redémarrage, iptables fait de nouveau référence à ufw (iptables -L identique au premier). J’ai pourtant bien tout nettoyer…
Comment se débarrasser de ufw une fois pour toute ?
PS : je ne manipule jamais iptables car je n’en ai pas l’utilité ni les compétences d’ailleurs
Merci.
