Je suis patient mais là, ça commence à faire.
J’ai tt essayé au niveau du xorg.conf pour ce qui concerne la souris.
J’ai copié/collé celui de la Sid d’où je tape en ce moment.
Je vs passe le log qui semble ne rien trouver d’anormal sauf les 3 Erreurs de la fin concernant cette p… de souris.
Quelles sont les commandes qui permettent de configurer ce mulot de M… ?
Bien sûr, tt tenté avec dpkg-reconfigure xserver-xorg mais sans plus de succès.
Au secours ou je RÉINSTALLE cette Etch de m…
[code]X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux debian-etch 2.6.12-1-686 #1 Tue Sep 27 12:52:50 JST 2005 i686
Build Date: 16 March 2006
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jul 16 00:46:23 2006
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Écran générique”
() | |–>Device “Carte vidéo générique”
() |–>Input Device “Generic Keyboard”
() Option “XkbRules” “xorg”
() XKB: rules: “xorg”
() Option “XkbModel” “pc105”
() XKB: model: “pc105”
() Option “XkbLayout” “fr”
() XKB: layout: “fr”
(==) Keyboard: CustomKeycode disabled
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/lib/X11/fonts/cyrillic” does not exist.
(WW) fonts.dir' not found (or not valid) in "/usr/lib/X11/fonts/100dpi/". Entry deleted from font path. (Run 'mkfontdir' on "/usr/lib/X11/fonts/100dpi/"). (WW)
fonts.dir’ not found (or not valid) in “/usr/lib/X11/fonts/75dpi/”.
(Run ‘mkfontdir’ on “/usr/lib/X11/fonts/75dpi/”).
(WW) The directory “/usr/share/fonts/X11/CID” does not exist.
(WW) The directory “/usr/lib/X11/fonts/CID” does not exist.
(WW) fonts.dir' not found (or not valid) in "/usr/lib/X11/fonts/100dpi". Entry deleted from font path. (Run 'mkfontdir' on "/usr/lib/X11/fonts/100dpi"). (WW)
fonts.dir’ not found (or not valid) in “/usr/lib/X11/fonts/75dpi”.
(Run ‘mkfontdir’ on “/usr/lib/X11/fonts/75dpi”).
(**) FontPath set to “/usr/share/fonts/X11/misc,/usr/lib/X11/fonts/misc,/usr/share/fonts/X11/Type1,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/usr/share/fonts/X11/misc/,/usr/share/fonts/X11/TTF/,/usr/share/fonts/X11/OTF,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/CID/,/usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/”
(==) RgbPath set to “/usr/share/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(–) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1039,0648 card 1043,8086 rev 02 class 06,00,00 hdr 80
(II) PCI: 00:01:0: chip 1039,0001 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1039,0963 card 0000,0000 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:02:1: chip 1039,0016 card 0000,0000 rev 00 class 0c,05,00 hdr 00
(II) PCI: 00:02:3: chip 1039,7007 card ffff,ffff rev 00 class 0c,00,10 hdr 00
(II) PCI: 00:02:5: chip 1039,5513 card 1043,8087 rev 00 class 01,01,80 hdr 00
(II) PCI: 00:03:0: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 80
(II) PCI: 00:03:1: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:2: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:3: chip 1039,7002 card 1043,8087 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:04:0: chip 1039,0900 card 1043,80a7 rev 91 class 02,00,00 hdr 00
(II) PCI: 00:0b:0: chip 1102,0002 card 1102,8066 rev 0a class 04,01,00 hdr 80
(II) PCI: 00:0b:1: chip 1102,7002 card 1102,0020 rev 0a class 09,80,00 hdr 80
(II) PCI: 00:0c:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:0e:0: chip 105a,3376 card 1043,809e rev 02 class 01,04,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0221 card 1554,11b1 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd6000000 - 0xd7ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xdff00000 - 0xfebfffff (0x1ed00000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) nVidia Corporation GeForce 6200 rev 161, Mem @ 0xd7000000/24, 0xe0000000/28, 0xd6000000/24, BIOS @ 0xdffe0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd8000000 from 0xdbffffff to 0xd7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xd1800000 - 0xd181ffff (0x20000) MX[B]
[1] -1 0 0xd2000000 - 0xd2000fff (0x1000) MX[B]
[2] -1 0 0xd2800000 - 0xd28000ff (0x100) MX[B]
[3] -1 0 0xd3000000 - 0xd3000fff (0x1000) MX[B]
[4] -1 0 0xd3800000 - 0xd3800fff (0x1000) MX[B]
[5] -1 0 0xd4000000 - 0xd4000fff (0x1000) MX[B]
[6] -1 0 0xd4800000 - 0xd4800fff (0x1000) MX[B]
[7] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[8] -1 0 0xd5800000 - 0xd5800fff (0x1000) MX[B]
[9] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]O
[10] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MXB
[11] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MXB
[12] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[13] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MXB
[14] -1 0 0x00007800 - 0x0000787f (0x80) IX[B]
[15] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[16] -1 0 0x00008400 - 0x0000843f (0x40) IX[B]
[17] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
[18] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[19] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[20] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[21] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[22] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd1800000 - 0xd181ffff (0x20000) MX[B]
[6] -1 0 0xd2000000 - 0xd2000fff (0x1000) MX[B]
[7] -1 0 0xd2800000 - 0xd28000ff (0x100) MX[B]
[8] -1 0 0xd3000000 - 0xd3000fff (0x1000) MX[B]
[9] -1 0 0xd3800000 - 0xd3800fff (0x1000) MX[B]
[10] -1 0 0xd4000000 - 0xd4000fff (0x1000) MX[B]
[11] -1 0 0xd4800000 - 0xd4800fff (0x1000) MX[B]
[12] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[13] -1 0 0xd5800000 - 0xd5800fff (0x1000) MX[B]
[14] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]O
[15] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MXB
[16] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MXB
[17] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[18] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MXB
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x00007800 - 0x0000787f (0x80) IX[B]
[22] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[23] -1 0 0x00008400 - 0x0000843f (0x40) IX[B]
[24] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
[25] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[26] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[27] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[28] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[29] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.0.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “type1”
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.1.0
(II) LoadModule: “nv”
(II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.1
Module class: X.Org Video Driver
(II) LoadModule: “keyboard”
(II) Loading /usr/lib/xorg/modules/input/keyboard_drv.so
(II) Module keyboard: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.4
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro4 NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 280 NVS, Quadro4 380 XGL, Quadro NVS 50 PCI, GeForce4 448 Go,
GeForce4 MX Integrated GPU, GeForce3, GeForce3 Ti 200,
GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400,
0x0252, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, 0x0313, GeForce FX 5600SE,
0x0316, 0x0317, GeForce FX Go5600, GeForce FX Go5650,
Quadro FX Go700, 0x031D, 0x031E, 0x031F, GeForce FX 5200,
GeForce FX 5200 Ultra, GeForce FX 5200, GeForce FX 5200SE,
GeForce FX Go5200, GeForce FX Go5250, GeForce FX 5500,
GeForce FX 5100, GeForce FX Go5200 32M/64M, 0x0329,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, 0x032F,
GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900XT,
GeForce FX 5950 Ultra, Quadro FX 700, GeForce FX 5900ZT,
Quadro FX 3000, GeForce FX 5700 Ultra, GeForce FX 5700,
GeForce FX 5700LE, GeForce FX 5700VE, 0x0345, GeForce FX Go5700,
GeForce FX Go5700, 0x0349, 0x034B, Quadro FX Go1000, Quadro FX 1100,
0x034F, GeForce 6800 Ultra, GeForce 6800, GeForce 6800 LE, 0x0043,
GeForce 6800 GT, GeForce 6800 GT, GeForce 6800 XT, 0x0049,
Quadro FX 4000, 0x00C0, GeForce 6800, GeForce 6800 LE,
GeForce 6800 XT, GeForce Go 6800, GeForce Go 6800 Ultra,
Quadro FX Go1400, Quadro FX 3450/4000 SDI, Quadro FX 1400,
GeForce 6600 GT, GeForce 6600, GeForce 6600 LE, 0x0143,
GeForce Go 6600, GeForce 6610 XL, GeForce Go 6600 TE/6200 TE,
GeForce 6700 XL, GeForce Go 6600, GeForce Go 6600 GT, 0x014B, 0x014C,
0x014D, Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache™, GeForce 6200SE TurboCache™,
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, 0x016B, 0x016C,
0x016D, 0x016E, 0x0210, GeForce 6800, GeForce 6800 LE,
GeForce 6800 GT, 0x0220, GeForce 6200, 0x0222, 0x0228, 0x0090,
GeForce 7800 GTX, GeForce 7800 GT, 0x0093, 0x0094, GeForce Go 7800,
GeForce Go 7800 GTX, 0x009C, Quadro FX 4500, 0x009E
(II) Primary Device is: PCI 01:00:0
(–) Assigning device section with no busID to primary device
(–) Chipset GeForce 6200 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x00007800 - 0x0000787f (0x80) IX[B]
[25] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[26] -1 0 0x00008400 - 0x0000843f (0x40) IX[B]
[27] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
[28] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[29] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[30] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[31] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[32] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
[33] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[34] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module “int10”
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) NV(0): Initializing int10
(WW) NV(0): Bad V_BIOS checksum
(II) NV(0): Primary V_BIOS segment is: 0xc000
(–) NV(0): Chipset: “GeForce 6200”
() NV(0): Depth 24, (–) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module “vgahw”
(II) LoadModule: “vgahw”
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 0.1.0
(==) NV(0): Using HW cursor
(–) NV(0): Linear framebuffer at 0xE0000000
(–) NV(0): MMIO registers at 0xD7000000
(II) Loading sub module “i2c”
(II) LoadModule: “i2c”
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.2.0
(II) Loading sub module “ddc”
(II) Reloading /usr/lib/xorg/modules/libddc.so
(II) NV(0): I2C bus “DDC” initialized.
(II) NV(0): Probing for analog device on output A…
(–) NV(0): …found one
(II) NV(0): Probing for analog device on output B…
(–) NV(0): …can’t find one
(II) NV(0): Probing for EDID on I2C bus A…
(II) NV(0): I2C device “DDC:ddc2” registered at address 0xA0.
(II) NV(0): I2C device “DDC:ddc2” removed.
(II) NV(0): … none found
(II) NV(0): Probing for EDID on I2C bus B…
(–) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: FUJ Model: 770 Serial#: 2142
(II) NV(0): Year: 1999 Week: 39
(II) NV(0): EDID Version: 1.2
(II) NV(0): Analog Display Input, Input Voltage Level: 0.714/0.286 V
(II) NV(0): Sync: Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 31 vert.: 23
(II) NV(0): Gamma: 1.35
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): redX: 0.609 redY: 0.342 greenX: 0.298 greenY: 0.588
(II) NV(0): blueX: 0.150 blueY: 0.063 whiteX: 0.280 whiteY: 0.311
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): Manufacturer’s mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) NV(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) NV(0): #2: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) NV(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 110.2 MHz Image Size: 306 x 230 mm
(II) NV(0): h_active: 1280 h_sync: 1344 h_sync_end 1508 h_blank_end 1728 h_border: 0
(II) NV(0): v_active: 1024 v_sync: 1026 v_sync_end 1029 v_blanking: 1067 v_border: 0
(II) NV(0): Ranges: V min: 50 V max: 120 Hz, H min: 30 H max: 72 kHz, PixClock max 110 MHz
(II) NV(0): Monitor name: FUJITSU TE770
(II) NV(0): Serial No: C991502142
(–) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(–) NV(0): VideoRAM: 131072 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): Écran générique: Using default hsync range of 30.00-72.00 kHz
(II) NV(0): Écran générique: Using default vrefresh range of 50.00-120.00 Hz
(II) NV(0): Clock range: 12.00 to 400.00 MHz
(WW) (1280x960,Écran générique) mode clock 148.5MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1280x960” (hsync out of range)
(II) NV(0): Not using default mode “640x480” (hsync out of range)
(WW) (1280x1024,Écran générique) mode clock 135MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1280x1024” (hsync out of range)
(II) NV(0): Not using default mode “640x512” (hsync out of range)
(WW) (1280x1024,Écran générique) mode clock 157.5MHz exceeds DDC maximum 110MHz
(WW) (1600x1200,Écran générique) mode clock 162MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1600x1200” (hsync out of range)
(II) NV(0): Not using default mode “800x600” (hsync out of range)
(WW) (1600x1200,Écran générique) mode clock 175.5MHz exceeds DDC maximum 110MHz
(WW) (1600x1200,Écran générique) mode clock 189MHz exceeds DDC maximum 110MHz
(WW) (1600x1200,Écran générique) mode clock 202.5MHz exceeds DDC maximum 110MHz
(WW) (1600x1200,Écran générique) mode clock 229.5MHz exceeds DDC maximum 110MHz
(WW) (800x600,Écran générique) mode clock 114.75MHz exceeds DDC maximum 110MHz
(WW) (1792x1344,Écran générique) mode clock 204.8MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1792x1344” (hsync out of range)
(II) NV(0): Not using default mode “896x672” (hsync out of range)
(WW) (1792x1344,Écran générique) mode clock 261MHz exceeds DDC maximum 110MHz
(WW) (896x672,Écran générique) mode clock 130.5MHz exceeds DDC maximum 110MHz
(WW) (1856x1392,Écran générique) mode clock 218.3MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1856x1392” (hsync out of range)
(II) NV(0): Not using default mode “928x696” (hsync out of range)
(WW) (1856x1392,Écran générique) mode clock 288MHz exceeds DDC maximum 110MHz
(WW) (928x696,Écran générique) mode clock 144MHz exceeds DDC maximum 110MHz
(WW) (1920x1440,Écran générique) mode clock 234MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1920x1440” (hsync out of range)
(WW) (960x720,Écran générique) mode clock 117MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “960x720” (hsync out of range)
(WW) (1920x1440,Écran générique) mode clock 297MHz exceeds DDC maximum 110MHz
(WW) (960x720,Écran générique) mode clock 148.5MHz exceeds DDC maximum 110MHz
(WW) (1152x864,Écran générique) mode clock 121.5MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1152x864” (hsync out of range)
(II) NV(0): Not using default mode “576x432” (hsync out of range)
(WW) (1400x1050,Écran générique) mode clock 122MHz exceeds DDC maximum 110MHz
(WW) (1400x1050,Écran générique) mode clock 151MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1400x1050” (hsync out of range)
(II) NV(0): Not using default mode “700x525” (hsync out of range)
(WW) (1400x1050,Écran générique) mode clock 155.8MHz exceeds DDC maximum 110MHz
(WW) (1400x1050,Écran générique) mode clock 184MHz exceeds DDC maximum 110MHz
(WW) (1680x1050,Écran générique) mode clock 147.14MHz exceeds DDC maximum 110MHz
(WW) (1920x1200,Écran générique) mode clock 193.16MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1920x1200” (hsync out of range)
(II) NV(0): Not using default mode “960x600” (hsync out of range)
(WW) (1920x1200,Écran générique) mode clock 230MHz exceeds DDC maximum 110MHz
(WW) (960x600,Écran générique) mode clock 115MHz exceeds DDC maximum 110MHz
(WW) (1920x1440,Écran générique) mode clock 341.35MHz exceeds DDC maximum 110MHz
(WW) (960x720,Écran générique) mode clock 170.675MHz exceeds DDC maximum 110MHz
(WW) (2048x1536,Écran générique) mode clock 266.95MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “2048x1536” (hsync out of range)
(WW) (1024x768,Écran générique) mode clock 133.475MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1024x768” (hsync out of range)
(WW) (2048x1536,Écran générique) mode clock 340.48MHz exceeds DDC maximum 110MHz
(WW) (1024x768,Écran générique) mode clock 170.24MHz exceeds DDC maximum 110MHz
(WW) (2048x1536,Écran générique) mode clock 388.04MHz exceeds DDC maximum 110MHz
(WW) (1024x768,Écran générique) mode clock 194.02MHz exceeds DDC maximum 110MHz
(II) NV(0): Not using default mode “1680x1050” (width too large for virtual size)
(II) NV(0): Not using default mode “1400x1050” (width too large for virtual size)
(II) NV(0): Not using default mode “1280x1024” (width too large for virtual size)
(II) NV(0): Not using default mode “1440x900” (width too large for virtual size)
(II) NV(0): Not using default mode “1280x960” (width too large for virtual size)
(II) NV(0): Not using default mode “1280x800” (width too large for virtual size)
(II) NV(0): Not using default mode “1280x768” (width too large for virtual size)
(–) NV(0): Virtual size is 1152x864 (pitch 1152)
() NV(0): *Default mode “1152x864”: 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline “1152x864” 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
() NV(0): *Default mode “1024x768”: 94.5 MHz, 68.7 kHz, 85.0 Hz
(II) NV(0): Modeline “1024x768” 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
() NV(0): *Default mode “800x600”: 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline “800x600” 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
() NV(0): *Default mode “640x480”: 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) NV(0): Modeline “640x480” 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
() NV(0): Default mode “1152x768”: 65.0 MHz, 44.2 kHz, 54.8 Hz
(II) NV(0): Modeline “1152x768” 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
() NV(0): Default mode “1024x768”: 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline “1024x768” 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
() NV(0): Default mode “1024x768”: 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline “1024x768” 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
() NV(0): Default mode “1024x768”: 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline “1024x768” 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
() NV(0): Default mode “1024x768”: 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
(II) NV(0): Modeline “1024x768” 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync
() NV(0): Default mode “832x624”: 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline “832x624” 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
() NV(0): Default mode “800x600”: 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline “800x600” 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
() NV(0): Default mode “800x600”: 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline “800x600” 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
() NV(0): Default mode “800x600”: 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline “800x600” 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
() NV(0): Default mode “800x600”: 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline “800x600” 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
() NV(0): Default mode “840x525”: 73.6 MHz, 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “840x525” 73.57 840 892 984 1128 525 525 527 543 doublescan
() NV(0): Default mode “700x525”: 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “700x525” 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync
() NV(0): Default mode “640x512”: 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x512” 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync
() NV(0): Default mode “720x450”: 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline “720x450” 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync
() NV(0): Default mode “640x480”: 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline “640x480” 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
() NV(0): Default mode “640x480”: 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline “640x480” 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
() NV(0): Default mode “640x480”: 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline “640x480” 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
() NV(0): Default mode “640x480”: 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x480” 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync
() NV(0): Default mode “720x400”: 35.5 MHz, 37.9 kHz, 85.0 Hz
(II) NV(0): Modeline “720x400” 35.50 720 756 828 936 400 401 404 446 -hsync +vsync
() NV(0): Default mode “640x400”: 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline “640x400” 31.50 640 672 736 832 400 401 404 445 -hsync +vsync
() NV(0): Default mode “640x400”: 41.7 MHz, 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “640x400” 41.73 640 672 740 840 400 400 402 414 doublescan
() NV(0): Default mode “576x432”: 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline “576x432” 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync
() NV(0): Default mode “640x384”: 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “640x384” 40.07 640 672 740 840 384 384 386 397 doublescan
() NV(0): Default mode “640x350”: 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline “640x350” 31.50 640 672 736 832 350 382 385 445 +hsync -vsync
() NV(0): Default mode “576x384”: 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
(II) NV(0): Modeline “576x384” 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync
() NV(0): Default mode “512x384”: 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
(II) NV(0): Modeline “512x384” 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync
() NV(0): Default mode “512x384”: 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(II) NV(0): Modeline “512x384” 39.40 512 520 568 656 384 384 386 400 doublescan +hsync +vsync
() NV(0): Default mode “512x384”: 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline “512x384” 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync
() NV(0): Default mode “512x384”: 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline “512x384” 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync
() NV(0): Default mode “512x384”: 22.4 MHz, 35.5 kHz, 86.6 Hz (D)
(II) NV(0): Modeline “512x384” 22.45 512 516 604 632 384 384 388 409 interlace doublescan +hsync +vsync
() NV(0): Default mode “416x312”: 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline “416x312” 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync
() NV(0): Default mode “400x300”: 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(II) NV(0): Modeline “400x300” 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline “400x300” 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline “400x300” 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline “400x300” 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
() NV(0): Default mode “400x300”: 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline “400x300” 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
() NV(0): Default mode “320x240”: 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(II) NV(0): Modeline “320x240” 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync
() NV(0): Default mode “320x240”: 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline “320x240” 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync
() NV(0): Default mode “320x240”: 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline “320x240” 15.75 320 332 352 416 240 244 245 260 doublescan -hsync -vsync
() NV(0): Default mode “320x240”: 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline “320x240” 12.60 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
() NV(0): Default mode “360x200”: 17.8 MHz, 37.9 kHz, 85.0 Hz (D)
(II) NV(0): Modeline “360x200” 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync
() NV(0): Default mode “320x200”: 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline “320x200” 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync
() NV(0): Default mode “320x175”: 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline “320x175” 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync
(++) NV(0): DPI set to (100, 100)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module “xaa”
(II) LoadModule: “xaa”
(II) Loading /usr/lib/xorg/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B]
[1] 0 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
[2] 0 0 0xd7000000 - 0xd7ffffff (0x1000000) MX[B]
[3] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1 0 0xd1800000 - 0xd181ffff (0x20000) MX[B]
[9] -1 0 0xd2000000 - 0xd2000fff (0x1000) MX[B]
[10] -1 0 0xd2800000 - 0xd28000ff (0x100) MX[B]
[11] -1 0 0xd3000000 - 0xd3000fff (0x1000) MX[B]
[12] -1 0 0xd3800000 - 0xd3800fff (0x1000) MX[B]
[13] -1 0 0xd4000000 - 0xd4000fff (0x1000) MX[B]
[14] -1 0 0xd4800000 - 0xd4800fff (0x1000) MX[B]
[15] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[16] -1 0 0xd5800000 - 0xd5800fff (0x1000) MX[B]
[17] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]O
[18] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MXB
[19] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MXB
[20] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[21] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MXB
[22] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[23] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[24] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[25] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[26] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[27] -1 0 0x00007800 - 0x0000787f (0x80) IX[B]
[28] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[29] -1 0 0x00008400 - 0x0000843f (0x40) IX[B]
[30] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
[31] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[32] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[33] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[34] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[35] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
[36] 0 0 0x000003b0 - 0x000003bb (0xc) ISB
[37] 0 0 0x000003c0 - 0x000003df (0x20) ISB
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
() Option “dpms”
() NV(0): DPMS enabled
(WW) NV(0): Option “NoLogo” is not used
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
() Generic Keyboard: Core Keyboard
() Option “Protocol” “standard”
() Generic Keyboard: Protocol: standard
() Option “AutoRepeat” “500 30”
() Generic Keyboard: XkbRules: “xorg”
() Generic Keyboard: XkbModel: “pc105”
() Generic Keyboard: XkbLayout: “fr”
() Option “CustomKeycodes” “off”
() Generic Keyboard: CustomKeycodes disabled
() Option “Protocol” “ImPS/2”
() Configured Mouse: Device: “/dev/psaux”
() Configured Mouse: Protocol: “ImPS/2”
() Option “CorePointer”
() Configured Mouse: Core Pointer
() Option “Device” “/dev/psaux”
(EE) xf86OpenSerial: Cannot open device /dev/psaux
No such device.
(EE) Configured Mouse: cannot open input device
(EE) PreInit failed for input device “Configured Mouse”
(II) UnloadModule: “mouse”
(WW) No core pointer registered
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
No core pointer
Fatal server error:
failed to initialize core devices
[/code][/code]
