Après un aptitude safe-upgrade la console me balance ça :
[code]jack-audio-connection-kit (0.118+svn3796-1) unstable; urgency=low
Upstream has replaced -L by -r, so in order to disable realtime mode,
specify -r or --no-realtime now. The reason is to have the same
commandline args for jackd1 and jackd2, but -L was already in use
by jackd2.
– Adrian Knoth adi@drcomp.erfurt.thur.de Wed, 18 Nov 2009 10:16:27 +0100
xserver-xorg-input-synaptics (1.2.0-1) unstable; urgency=low
- All the shared memory code has been removed from synclient and syndaemon.
The SHMConfig option is still available but the only use is for monitoring
the hardware state data.
If you have any script that changes the synaptics driver configuration
make sure that you don’t use the -s option to synclient. Or even better,
configure the driver via hal.
– Mattia Dongili malattia@debian.org Fri, 20 Nov 2009 00:32:58 +0900
Je doit m’inquiéter???
