J’ai installer le pendant GNU de visual studio professionnel, mono, (oulala, j’espère que je ne vais pas m’attirer les foudres de la communauté…)… Je suis sensé pouvoir disposer d’un GUI, (c’est tout l’intérêt de cet IDE) mais, je ne le trouve nulle part.
Pour info :
# aptitude search mono
p kde-icons-mono - a monochromatic icons theme for KDE
p libapache2-mod-mono - Run ASP.NET Pages on UNIX with Apache 2 and Mono
p libggi-target-monotext - General Graphics Interface plain text target
p libmono-accessibility1.0-cil - Mono Accessibility library
i A libmono-accessibility2.0-cil - Mono Accessibility library
p libmono-addins-gui0.2-cil - GTK# frontend library for Mono.Addins
p libmono-addins0.2-cil - addin framework for creating extensible CLI applications/libraries
p libmono-bytefx0.7.6.1-cil - Mono ByteFX.Data library
p libmono-bytefx0.7.6.2-cil - Mono ByteFX.Data library
p libmono-c5-1.0-cil - Mono C5 library
i A libmono-cairo1.0-cil - Mono Cairo library
p libmono-cairo2.0-cil - Mono Cairo library
idA libmono-cecil0.5-cil - library to generate and inspect CIL assemblies
i A libmono-corlib1.0-cil - Mono core library (1.0)
i A libmono-corlib2.0-cil - Mono core library (2.0)
p libmono-cscompmgd7.0-cil - Mono cscompmgd library
p libmono-cscompmgd8.0-cil - Mono cscompmgd library
i A libmono-data-tds1.0-cil - Mono Data library
i A libmono-data-tds2.0-cil - Mono Data Library
p libmono-dev - libraries for the Mono JIT - Development files
p libmono-firebirdsql1.7-cil - Mono FirebirdSql library
p libmono-ldap1.0-cil - Mono LDAP library
p libmono-ldap2.0-cil - Mono LDAP library
i A libmono-microsoft-build2.0-cil - Mono Microsoft.Build libraries
p libmono-microsoft7.0-cil - Mono Microsoft libraries
p libmono-microsoft8.0-cil - Mono Microsoft libraries
p libmono-npgsql1.0-cil - Mono Npgsql library
p libmono-npgsql2.0-cil - Mono Npgsql library
p libmono-oracle1.0-cil - Mono Oracle library
p libmono-oracle2.0-cil - Mono Oracle library
i A libmono-peapi1.0-cil - Mono PEAPI library
i A libmono-peapi2.0-cil - Mono PEAPI library
i A libmono-relaxng1.0-cil - Mono Relaxng library
p libmono-relaxng2.0-cil - Mono Relaxng library
i A libmono-security1.0-cil - Mono Security library
i A libmono-security2.0-cil - Mono Security library
p libmono-sharpzip0.6-cil - Mono SharpZipLib library
i A libmono-sharpzip0.84-cil - Mono SharpZipLib library
p libmono-sharpzip2.6-cil - Mono SharpZipLib library
i A libmono-sharpzip2.84-cil - Mono SharpZipLib library
p libmono-sqlite1.0-cil - Mono Sqlite library
i A libmono-sqlite2.0-cil - Mono Sqlite library
i A libmono-system-data1.0-cil - Mono System.Data library
i A libmono-system-data2.0-cil - Mono System.Data Library
p libmono-system-ldap1.0-cil - Mono System.DirectoryServices library
p libmono-system-ldap2.0-cil - Mono System.DirectoryServices library
p libmono-system-messaging1.0-cil - Mono System.Messaging library
p libmono-system-messaging2.0-cil - Mono System.Messaging Library
i A libmono-system-runtime1.0-cil - Mono System.Runtime library
idA libmono-system-runtime2.0-cil - Mono System.Runtime Library
i A libmono-system-web1.0-cil - Mono System.Web library
i A libmono-system-web2.0-cil - Mono System.Web Library
i A libmono-system1.0-cil - Mono System libraries (1.0)
i A libmono-system2.0-cil - Mono System libraries (2.0)
p libmono-winforms1.0-cil - Mono System.Windows.Forms library
i A libmono-winforms2.0-cil - Mono System.Windows.Forms library
i A libmono0 - libraries for the Mono JIT
p libmono0-dbg - libraries for the Mono JIT, debugging symbols
i A libmono1.0-cil - Mono libraries (1.0)
i A libmono2.0-cil - Mono libraries (2.0)
i mono - Mono CLI (.NET) runtime
p mono-apache-server - backend for mod_mono Apache module
p mono-apache-server2 - backend for mod_mono2 Apache module
i mono-common - common files for Mono
p mono-dbg - Mono debugging symbols
i mono-debugger - Debugger for Mono
i mono-devel - Mono CLI runtime with development tools
i A mono-gac - Mono GAC tool
i A mono-gmcs - Mono C# 2.0 compiler
i A mono-jay - LALR(1) parser generator oriented to Java/CLI
i A mono-jit - fast CLI JIT/AOT compiler for Mono
p mono-jit-dbg - fast CLI JIT/AOT compiler for Mono, debugging symbols
i A mono-mcs - Mono C# compiler
p mono-mjs - Mono JScript compiler
i mono-runtime - Mono runtime
p mono-tools-devel - Various development tools for mono
p mono-tools-gui - Various GUI tools for mono
i A mono-utils - Mono utilities
p mono-xsp - simple web server to run ASP.NET applications
p mono-xsp-base - base libraries for XSP 1.1
i mono-xsp2 - simple web server to run ASP.NET applications
i A mono-xsp2-base - base libraries for XSP 2.0
i monodoc - Mono documentation viewer
p monodoc-avahi-manual - compiled XML documentation for the CLI bindings of avahi
i A monodoc-base - shared MonoDoc binaries
i A monodoc-browser - MonoDoc GTK+ based viewer
p monodoc-dbus-1-manual - compiled XML documentation for the D-BUS CLI bindings
p monodoc-gecko2.0-manual - compiled XML documentation for Gecko#2
i monodoc-gtk2.0-manual - compiled XML documentation for Gtk# 2.10
p monodoc-gtksourceview2.0-manual - compiled XML documentation for GtkSourceView#2
p monodoc-http - MonoDoc http based viewer
p monodoc-ipod-manual - compiled XML documentation for ipod-sharp
i A monodoc-manual - compiled XML documentation from the Mono project
p monodoc-njb-manual - compiled XML documentation for njb-sharp
p monodoc-nunit-manual - compiled XML documentation for Nunit
p monodoc-taglib-manual - compiled XML documentation for taglib-sharp
v monodoc-viewer
Parmi tous ces paquets, je me doute qu’il y a celui dont j’ai besoin pour avoir l’interface graphique. Je voudrais simplement savoir si quelqu’un s’est déjà lancé dans l’installation et l’utilisation de mono.
J’ai aussi tenté de lancer mono à la main:
[code]# mono
Usage is: mono [options] program [program-options]
Development:
–aot Compiles the assembly to native code
–debug Enable debugging support
–profile[=profiler] Runs in profiling mode with the specified profiler module
–trace[=EXPR] Enable tracing, use --help-trace for details
–help-devel Shows more options available to developers
Runtime:
–config FILE Loads FILE as the Mono config
–verbose, -v Increases the verbosity level
–help, -h Show usage information
–version, -V Show version information
–runtime=VERSION Use the VERSION runtime, instead of autodetecting
–optimize=OPT Turns on or off a specific optimization
Use --list-opt to get a list of optimizations
–security Turns on the security manager (unsupported, default is off)
… et là je ne vois pas trop…
infos, conseils bienvenus…
