Bonsoir a tous, alors voila, ça fait quelque jours que j’ai un soucis sous mon serveur debian
j’utiliser avant proFTP , et j’avais 2 compte, qui été bloquer dans leur dossier respectif
mais ça fait quelque jour, ou les compte peuvent se balader partout sans restriction, j’ai donc penser que sa venez de prosftp, je les donc supprimé, et j’ai mis a la place Vsftpd
mais le soucis reste le même, pas de restriction :s
au niveaux config voici ce qu’il y as
[code]# Example config file /etc/vsftpd.conf
The default compiled in settings are fairly paranoid. This sample file
loosens things up a bit, to make the ftp daemon more usable.
Please see vsftpd.conf.5 for all compiled in defaults.
READ THIS: This example file is NOT an exhaustive list of vsftpd options.
Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd’s
capabilities.
Run standalone? vsftpd can run either from an inetd or as a standalone
daemon started from an initscript.
listen=YES
Run standalone with IPv6?
Like the listen parameter, except vsftpd will listen on an IPv6 socket
instead of an IPv4 one. This parameter and the listen parameter are mutually
exclusive.
#listen_ipv6=YES
Allow anonymous FTP? (Beware - allowed by default if you comment this out).
anonymous_enable=NO
Uncomment this to allow local users to log in.
local_enable=YES
Uncomment this to enable any form of FTP write command.
write_enable=YES
Default umask for local users is 077. You may wish to change this to 022,
if your users expect that (022 is used by most other ftpd’s)
local_umask=022
Uncomment this to allow the anonymous FTP user to upload files. This only
has an effect if the above global write enable is activated. Also, you will
obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
Uncomment this if you want the anonymous FTP user to be able to create
new directories.
#anon_mkdir_write_enable=YES
Activate directory messages - messages given to remote users when they
go into a certain directory.
dirmessage_enable=YES
If enabled, vsftpd will display directory listings with the time
in your local time zone. The default is to display GMT. The
times returned by the MDTM FTP command are also affected by this
option.
use_localtime=YES
Activate logging of uploads/downloads.
xferlog_enable=YES
Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
If you want, you can arrange for uploaded anonymous files to be owned by
a different user. Note! Using “root” for uploaded files is not
recommended!
#chown_uploads=YES
#chown_username=whoever
You may override where the log file goes if you like. The default is shown
below.
#xferlog_file=/var/log/vsftpd.log
If you want, you can have your log file in standard ftpd xferlog format.
Note that the default log file location is /var/log/xferlog in this case.
#xferlog_std_format=YES
You may change the default value for timing out an idle session.
#idle_session_timeout=600
You may change the default value for timing out a data connection.
#data_connection_timeout=120
It is recommended that you define on your system a unique user which the
ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
Enable this and the server will recognise asynchronous ABOR requests. Not
recommended for security (the code is non-trivial). Not enabling it,
however, may confuse older FTP clients.
#async_abor_enable=YES
By default the server will pretend to allow ASCII mode but in fact ignore
the request. Turn on the below options to have the server actually do ASCII
mangling on files when in ASCII mode.
Beware that on some FTP servers, ASCII support allows a denial of service
attack (DoS) via the command “SIZE /big/file” in ASCII mode. vsftpd
predicted this attack and has always been safe, reporting the size of the
raw file.
ASCII mangling is a horrible feature of the protocol.
#ascii_upload_enable=YES
#ascii_download_enable=YES
You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
You may specify a file of disallowed anonymous e-mail addresses. Apparently
useful for combatting certain DoS attacks.
#deny_email_enable=YES
(default follows)
#banned_email_file=/etc/vsftpd.banned_emails
You may restrict local users to their home directories. See the FAQ for
the possible risks in this before using chroot_local_user or
chroot_list_enable below.
#chroot_local_user=YES
You may specify an explicit list of local users to chroot() to their home
directory. If chroot_local_user is YES, then this list becomes a list of
users to NOT chroot().
(Warning! chroot’ing can be very dangerous. If using chroot, make sure that
the user does not have write access to the top level directory within the
chroot)
chroot_list_enable=YES
(default follows)
chroot_list_file=/etc/vsftpd.chroot_list
You may activate the “-R” option to the builtin ls. This is disabled by
default to avoid remote users being able to cause excessive I/O on large
sites. However, some broken FTP clients such as “ncftp” and “mirror” assume
the presence of the “-R” option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
Customization
Some of vsftpd’s settings don’t fit the filesystem layout by
default.
This option should be the name of a directory which is empty. Also, the
directory should not be writable by the ftp user. This directory is used
as a secure chroot() jail at times vsftpd does not require filesystem
access.
secure_chroot_dir=/var/run/vsftpd/empty
This string is the name of the PAM service vsftpd will use.
pam_service_name=vsftpd
This option specifies the location of the RSA certificate to use for SSL
encrypted connections.
rsa_cert_file=/etc/ssl/private/vsftpd.pem
et voici le contenue du fichier vsftpd.chroot_list
tarkhog
kenedjow
en ce qui concerne la parti :
[code]chroot_local_user=YES
(default follows)
chroot_list_file=/etc/vsftpd.chroot_list[/code]
si la configuration est comme ca, uniquement les comptes dans la liste peuvent se connecter
les autre ont ca : 500 OOPS: vsftpd: refusing to run with writable root inside chroot()
si je met :
chroot_list_enable=NO
personne ne peux se connecter, et voici le message : 500 OOPS: vsftpd: refusing to run with writable root inside chroot()
si je met :
chroot_local_user=NO
uniquement les comptes qui ne sont pas dans la liste, peuvent se connecter
même message pour les autre
si je met :
[code]chroot_local_user=NO
#chroot_list_enable=YES
(default follows)
#chroot_list_file=/etc/vsftpd.chroot_list[/code]
tout les compte peuvent se connecter
si je met :
(default follows)
aucun compte ne peux se connecter, est on le même message que les précédent
je ne sais plus trop quoi faire, du coup actuellement le FTP est stoppé, puisque plus sécurisé
si vous s’avez comment régler le soucis, ça serait super
merci de m’avoir lu, bonne soirée !
Debian 7.5 (Wheezy) (Oldstable) (64bits)
Noyau : Linux ns315026.ip-46-105-103.eu 3.14.32-xxxx-std-ipv6-64 #6 SMP Wed Jan 20 18:22:32 CET 2016 x86_64 GNU/Linux
Kernel Version
Debian 7.9 3.14.32-xxxx-std-ipv6-64
