Après l’installation de Debian Weezy 3.0.4, je voudrais mettre une adresse ip fixe sur mon serveur.
Par défaut le fichier “/etc/network/interface” est configuré comme ceci :
[code]auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet dhcp[/code]
J’ai m’y ceci dans mon fichier “/etc/network/interface”
[code]auto lo
auto eth0
iface eth0 inet static
address 192.168.0.1
netmask 255.255.255.0
broadcast 192.168.0.255
gateway 192.168.0.254
auto eth1
Puis j’ai redémarré le service réseau
[code]root@debian:~# /etc/init.d/networking restart
Running /etc/init.d/networking restart is deprecated because it may not enable again some interfaces … (warning).
Reconfiguring network interfaces…Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/eth1/f0:ad:4e:00:b2:43
Sending on LPF/eth1/f0:ad:4e:00:b2:43
Sending on Socket/fallback
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 18
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
done.
root@debian:~# [/code]
Et quand je me connecte en ssh sur la nouvelle adresse ip fixe 192.168.0.1 ça marche pas.
laurent@laurent-Bureau:~$ sshpass -p 'xxxxxx' ssh root@192.168.0.1
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
89:cd:d3:4a:50:bb:55:bf:43:b3:34:9d:50:90:19:a7.
Please contact your system administrator.
Add correct host key in /home/laurent/.ssh/known_hosts to get rid of this message.
Offending RSA key in /home/laurent/.ssh/known_hosts:1
remove with: ssh-keygen -f "/home/laurent/.ssh/known_hosts" -R 192.168.0.1
RSA host key for 192.168.0.1 has changed and you have requested strict checking.
Host key verification failed.
Et quand je me connecte sur l’ancienne adressse ip 192.168.1.1 ça marche
[code]laurent@laurent-Bureau:~$ sshpass -p ‘xxxxxx’ ssh root@192.168.1.1
Linux debian 3.0.4 #1 PREEMPT Tue Aug 30 19:56:02 MDT 2011 armv5tel
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jun 13 23:58:44 2014 from 192.168.1.140
Pourtant j’ai vérifié la configuration du réseau, l’ip est bien chargé ?
[code]root@debian:~# ifconfig eth0
eth0 Link encap:Ethernet HWaddr f0:ad:4e:00:b2:42
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::f2ad:4eff:fe00:b242/64 Scope:Link
RX packets:159 errors:0 dropped:0 overruns:0 frame:0
TX packets:166 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:23903 (23.3 KiB) TX bytes:22128 (21.6 KiB)
Interrupt:11
RX packets:199 errors:0 dropped:0 overruns:0 frame:0
TX packets:201 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:30337 (29.6 KiB) TX bytes:27739 (27.0 KiB)
Interrupt:11
eth1 Link encap:Ethernet HWaddr f0:ad:4e:00:b2:43
Interrupt:15
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
collisions:0 txqueuelen:0
uap0 Link encap:Ethernet HWaddr 00:24:23:45:0d:ac
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::224:23ff:fe45:dac/64 Scope:Link
RX packets:164 errors:0 dropped:0 overruns:0 frame:0
TX packets:85 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:20882 (20.3 KiB) TX bytes:10239 (9.9 KiB)
Pourquoi je n’arrive pas à me connecter en ssh sur 'ip 192.168.0.1 ?
Merci.
