Wheezy: impossible d'installer libreoffice
Voici le final de la dist-upgrade:
[code]dpkg: dependency problems prevent configuration of sysvinit-utils:
startpar (0.59-3) breaks sysvinit-utils (<< 2.88dsf-52) and is installed.
Version of sysvinit-utils to be configured is 2.88dsf-41+deb7u1.
dpkg: error processing sysvinit-utils (–configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
sysvinit-utils
E: Sub-process /usr/bin/dpkg returned an error code (1)[/code]
Je pense que je n’ai pas intérêt à rebooter?
Mieux vaudrait pas.
[quote=“isterios”] startpar (0.59-3) breaks sysvinit-utils (<< 2.88dsf-52) and is installed.
Version of sysvinit-utils to be configured is 2.88dsf-41+deb7u1.[/quote]
[mono]$ apt-cache policy sysvinit-utils systemd startpar[/mono] ?
[mono]$ dpkg -l | grep sysvinit-utils[/mono] ?
[08:17:42] ~ # apt-cache policy sysvinit-utils systemd startpar sysvinit-utils: Installé : 2.88dsf-41+deb7u1 Candidat : 2.88dsf-41+deb7u1 Table de version : 2.88dsf-55 0 93 http://ftp.de.debian.org/debian/ experimental/main i386 Packages 2.88dsf-53 0 97 http://ftp.fr.debian.org/debian/ testing/main i386 Packages 95 http://ftp.fr.debian.org/debian/ unstable/main i386 Packages *** 2.88dsf-41+deb7u1 0 990 http://ftp.fr.debian.org/debian/ stable/main i386 Packages 100 /var/lib/dpkg/status 2.88dsf-13.1+squeeze1 0 500 http://ftp.fr.debian.org/debian/ squeeze/main i386 Packages systemd: Installé : (aucun) Candidat : 44-11+deb7u4 Table de version : 208-1 0 93 http://ftp.de.debian.org/debian/ experimental/main i386 Packages 204-10 0 95 http://ftp.fr.debian.org/debian/ unstable/main i386 Packages 204-8 0 97 http://ftp.fr.debian.org/debian/ testing/main i386 Packages 204-8~bpo70+1 0 100 http://ftp.debian.org/debian/ wheezy-backports/main i386 Packages 44-11+deb7u4 0 990 http://ftp.fr.debian.org/debian/ stable/main i386 Packages 990 http://security.debian.org/ stable/updates/main i386 Packages startpar: Installé : (aucun) Candidat : 0.59-3 Table de version : 0.59-3 0 97 http://ftp.fr.debian.org/debian/ testing/main i386 Packages 95 http://ftp.fr.debian.org/debian/ unstable/main i386 Packages [08:17:47] ~ #
$ apt-cache policy systemd startpar systemd: Installed: 204-8 Candidate: 44-11+deb7u4 Version table: *** 204-8 0 100 /var/lib/dpkg/status 44-11+deb7u4 0 1001 http://ftp.fr.debian.org/debian/ wheezy/main amd64 Packages 500 http://security.debian.org/ wheezy/updates/main amd64 Packages startpar: Installed: 0.59-3 Candidate: 0.59-3 Version table: *** 0.59-3 0 100 /var/lib/dpkg/status
$ dpkg -l | grep sysvinit-utils iU sysvinit-utils 2.88dsf-41+deb7u1 amd64 System-V-like utilities
$ aptitude search ~i -F"%p %t "| grep debports Rien trouvé...
[quote=“isterios”]startpar:
Installed: 0.59-3
Candidate: 0.59-3
Version table:
*** 0.59-3 0
100 /var/lib/dpkg/status[/quote]
[mono]$ aptitude -s remove --purge startpar[/mono] ?
[mono]$ aptitude search ~c[/mono] ?
[mono]$ aptitude -s reinstall sysvinit-utils[/mono] ?
Re,
Petite correction.
[mono]$ aptitude search ~i -F"%p %t "| grep debian-ports[/mono]
Il est grand temps de jouer carte sur table ! :mrgreen:
À savoir :
Quel est l’origine des paquets [mono]libreoffice[/mono] et consort ? ([mono]1:4.1.6~rc2-1[/mono] par exemple.)
L’ajout d’un dépôt ?
Téléchargement (Où ?) .deb ? (dpkg -i .deb* ?)
Tar.gz ?
Autre ?
Les paquets pré-installés nativement avaient-ils été supprimés avant cette bidouille ?
As-tu gardé une trace (console) quelconque ? Commande et blabla ?
Dans le cas contraire, [size=85]nous[/size] n’irons … pas très loin. :snooty:
Déjà un grand merci pour votre aide, dont toi Belzebuth :wink:
J’ai un soupçon sur le depot deb-multimedia de Christian Marillat. En voulant installer avidemux.
Je confirme ça ce soir.
Mais je n’ai pas vu venir la galère (pô fait exprès :wink: )
Maintenant si ma distrib sent trop le sapin, je me ferai une raison et réinstallerai le bignou.
[mono]startpar[/mono] est un composant de Jessie, pas de Wheezy.
Désinstalle-le pour débloquer la situation avant de reprendre le downgrade.
Hum … :shhh:
[quote=“vv222”][mono]startpar[/mono] est un composant de Jessie, pas de Wheezy.
Désinstalle-le pour débloquer la situation avant de reprendre le downgrade.[/quote]
[quote=“BelZébuth”][quote=“isterios”]startpar:
Installed: 0.59-3
Candidate: 0.59-3
Version table:
*** 0.59-3 0
[mono]$ aptitude -s reinstall sysvinit-utils[/mono] ?[/quote]
:whistle:
Re,
Corriges moi si je me trompe … :wink:
Quel rapport avec le [mono]depot deb-multimedia de Christian Marillat[/mono] ?
Ci-dessous, je n’ai relevé aucun dépôt concernant [mono]libreoffice[/mono] émanant de ce dernier. Me fourvoierai-je ?
[mono][…][/mono] j’ai dû tronquer le retour, mais crois sur parole. :wink:
[18:13:25] ~ # divi libreoffice browser-plugin-libreoffice - suite de productivité bureautique - greffon Mozilla Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental docvert-libreoffice - converts word processor files to HTML using LibreOffice Homepage: http://www.docvert.org 4.0+dfsg-1 testing unstable 4.0-7 stable libreoffice - office productivity suite Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-accessodf - extension Libreoffice pour vérifier l'accessibilité des documents ODF Homepage: http://sourceforge.net/p/accessodf 0.1-4 unstable libreoffice-avmedia-backend-gstreamer - GStreamer backend for LibreOffice Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-avmedia-backend-vlc - VLC backend for LibreOffice Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-base - suite de productivité bureautique - base de données Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-base-core - suite de productivité bureautique - bibliothèques partagées Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-base-drivers - Database connectivity drivers for LibreOffice Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-calc - suite de productivité bureautique - tableur Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-common - suite de productivité bureautique -- fichiers indépendants de l'architecture Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-core - suite de productivité bureautique -- fichiers dépendants de l'architecture Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-dbg - office productivity suite -- debug symbols Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-dev - office productivity suite -- SDK Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-dev-doc - office productivity suite -- SDK documentation Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-dmaths - Formula editor improvements for LibreOffice Homepage: http://www.dmaths.org 3.4+dfsg1-1 stable testing unstable libreoffice-draw - suite de productivité bureautique - dessin Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-emailmerge - office productivity suite -- email mail merge Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-evolution - office productivity suite -- Evolution addressbook support Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-filter-binfilter - suite bureautique - filtres standards (p. ex. StarOffice 5.2) Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 installed [...] libreoffice-help-pt-br - office productivity suite -- Portuguese_brazilian help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-ru - office productivity suite -- Russian help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-sk - office productivity suite -- Slovak help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-sl - office productivity suite -- Slovenian help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-sv - office productivity suite -- Swedish help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-tr - office productivity suite -- Turkish help Homepage: http://www.libreoffice.org 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-vi - office productivity suite -- Vietnamese help Homepage: http://www.libreoffice.org 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-zh-cn - office productivity suite -- Chinese_simplified help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-help-zh-tw - office productivity suite -- Chinese_traditional help Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-impress - suite de productivité bureautique - présentation Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-java-common - suite de productivité bureautique - fichiers indépendants de l'architecture pour la gestion de Java Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-kde - office productivity suite -- KDE integration Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-l10n-af - office productivity suite -- Afrikaans language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ar - office productivity suite -- Arabic language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-as - office productivity suite -- Assamese language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ast - office productivity suite -- Asturian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-be - suite de productivité bureautique - gestion de la langue biélorusse Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-be-by - office productivity suite -- Belarussian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports libreoffice-l10n-bg - office productivity suite -- Bulgarian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-bn - office productivity suite -- Bengali language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-br - office productivity suite -- Breton language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-bs - office productivity suite -- Bosnian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ca - office productivity suite -- Catalan language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-cs - office productivity suite -- Czech language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-cy - office productivity suite -- Welsh language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-da - office productivity suite -- Danish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-de - office productivity suite -- German language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-dz - office productivity suite -- Dzongkha language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-el - office productivity suite -- Greek language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-en-gb - office productivity suite -- English_british language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-en-za - office productivity suite -- English_southafrican language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-eo - office productivity suite -- Esperanto language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-es - office productivity suite -- Spanish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-et - office productivity suite -- Estonian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-eu - office productivity suite -- Basque language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-fa - office productivity suite -- Farsi language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-fi - office productivity suite -- Finnish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-fr - office productivity suite -- French language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-l10n-ga - office productivity suite -- Gaelic language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-gd - office productivity suite -- Scottish_gaelic language package Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-gl - office productivity suite -- Galician language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-gu - office productivity suite -- Gujarati language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-he - office productivity suite -- Hebrew language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-hi - office productivity suite -- Hindi language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-hr - office productivity suite -- Croatian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-hu - office productivity suite -- Hungarian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-id - office productivity suite -- Indonesian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-in - suite de productivité bureautique - gestion des langues indo-aryennes Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-is - office productivity suite -- Icelandic language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-it - office productivity suite -- Italian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ja - office productivity suite -- Japanese language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ka - office productivity suite -- Georgian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-kk - office productivity suite -- Kazakh language package Homepage: http://www.libreoffice.org 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-km - office productivity suite -- Khmer language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-kmr - office productivity suite -- Kurmanji language package Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ko - office productivity suite -- Korean language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ku - office productivity suite -- Kurdish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-lt - office productivity suite -- Lithuanian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-lv - office productivity suite -- Latvian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-mk - office productivity suite -- Macedonian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ml - office productivity suite -- Malayalam language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-mn - office productivity suite -- Mongolian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-mr - office productivity suite -- Marathi language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-nb - office productivity suite -- Norwegian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ne - office productivity suite -- Nepalese language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-nl - office productivity suite -- Dutch language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-nn - office productivity suite -- Norwegian_nynorsk language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-nr - office productivity suite -- Ndebele language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ns - office productivity suite -- Northernsotho language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports libreoffice-l10n-nso - office productivity suite -- Northern_sotho language package Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-oc - office productivity suite -- Occitan language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-om - office productivity suite -- Oromo language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-or - office productivity suite -- Odia language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-pa-in - office productivity suite -- Punjabi language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-pl - office productivity suite -- Polish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-pt - office productivity suite -- Portuguese language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-pt-br - office productivity suite -- Portuguese_brazilian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ro - office productivity suite -- Romanian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ru - office productivity suite -- Russian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-rw - office productivity suite -- Kinarwanda language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-si - office productivity suite -- Sinhala language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-sk - office productivity suite -- Slovak language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-sl - office productivity suite -- Slovenian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-sr - office productivity suite -- Serbian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ss - office productivity suite -- Swazi language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-st - office productivity suite -- Southern_sotho language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-sv - office productivity suite -- Swedish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ta - office productivity suite -- Tamil language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-te - office productivity suite -- Telugu language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-tg - office productivity suite -- Tajik language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-th - office productivity suite -- Thai language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-tn - office productivity suite -- Tswana language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-tr - office productivity suite -- Turkish language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ts - office productivity suite -- Tsonga language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-ug - office productivity suite -- Uighur language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-uk - office productivity suite -- Ukrainian language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-uz - office productivity suite -- Uzbek language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental [...] libreoffice-l10n-xh - office productivity suite -- Xhosa language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-za - suite de productivité bureautique - gestion des langues sud-africaines Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-zh-cn - office productivity suite -- Chinese_simplified language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-zh-tw - office productivity suite -- Chinese_traditional language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-l10n-zu - office productivity suite -- Zulu language package Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-librelogo - Logo-like progamming language for LibreOffice Homepage: http://librelogo.org 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-lightproof-en - Lightproof grammar checker for LibreOffice (English) 0.4.2+1.5~b3-3 stable 0.4.3+1.5+git20140515-1 testing unstable libreoffice-lightproof-hu - Lightproof grammar checker for LibreOffice (Hungarian) 1.4.3+1.5~b3-3 stable 1.5+1.5+git20140515-1 testing unstable libreoffice-lightproof-ru-ru - Lightproof grammar checker for LibreOffice (Russian) 0.3.1+1.5~b3-3 stable 0.3.2+1.5+git20140515-1 testing unstable libreoffice-math - suite bureautique - éditeur d'équations Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-mysql-connector - MariaDB/MySQL Connector extension for LibreOffice Homepage: http://extensions.services.openoffice.org/en/project/mysql_connector 1.0.1+LibO3.5.4+dfsg2-0+deb7u2 stable 1.0.1+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1.0.2+LibO4.2.4-3~bpo70+1 wheezy-backports 1.0.2+LibO4.2.4-4 testing unstable 1.0.2+LibO4.3.0~beta1-1 experimental libreoffice-nlpsolver - "Solver for Nonlinear Programming" extension for LibreOffice 0.9~beta1-9 stable unstable libreoffice-officebean - office productivity suite -- Java bean Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-ogltrans - LibreOffice Impress extension for transitions using OpenGL Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-pdfimport - LibreOffice extension for importing PDF documents Homepage: http://extensions.services.openoffice.org/project/pdfimport 1.0.5+LibO3.5.4+dfsg2-0+deb7u2 stable 1.0.5+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-presentation-minimizer - LibreOffice extension for size-efficient presentations Homepage: http://extensions.services.openoffice.org/project/PresentationMinimizer 1.0.3+LibO3.5.4+dfsg2-0+deb7u2 stable 1.0.3+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1.0.4+LibO4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-presenter-console - LibreOffice Impress extension for a separate presenter's console Homepage: http://extensions.services.openoffice.org/project/presenter-screen 1.1.0+LibO3.5.4+dfsg2-0+deb7u2 stable 1.1.0+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-report-builder - LibreOffice component for building database reports Homepage: http://extensions.services.openoffice.org/project/reportdesign 1:1.2.1+LibO3.3.3-4~bpo60+1 squeeze-backports 1:1.2.1+LibO3.5.4+dfsg2-0+deb7u2 stable 1:1.2.1+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-report-builder-bin - LibreOffice component for building database reports -- libraries Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-script-provider-bsh - BeanShell script support provider for LibreOffice scripting framework Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental [...] libreoffice-sdbc-firebird - Firebird SDBC driver for LibreOffice Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-sdbc-hsqldb - HSQLDB SDBC driver for LibreOffice Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-sdbc-postgresql - PostgreSQL SDBC driver for LibreOffice Homepage: http://wiki.documentfoundation.org/PostgreSQL-SDBC 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-style-andromeda - office productivity suite -- Andromeda (Classic) symbol style Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports libreoffice-style-crystal - suite bureautique - icônes du style Crystal Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-style-galaxy - suite de productivité bureautique - style Galaxy (défaut) Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-style-hicontrast - office productivity suite -- Hicontrast symbol style Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-style-oxygen - office productivity suite -- Oxygen symbol style Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-style-sifr - office productivity suite -- Sifr symbol style Homepage: http://www.libreoffice.org 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-style-tango - office productivity suite -- Tango symbol style Homepage: http://www.libreoffice.org 1:3.3.3-4~bpo60+1 squeeze-backports 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-subsequentcheckbase - LibreOffice java test libraries Homepage: http://www.libreoffice.org 1:4.1.4-2~bpo70+1 wheezy-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental libreoffice-voikko - Finnish language tools for LibreOffice Homepage: http://voikko.sourceforge.net/ 3.3-3 stable 4.0-1 testing unstable libreoffice-wiki-publisher - LibreOffice extension for working with MediaWiki articles Homepage: http://extensions.services.openoffice.org/project/wikipublisher 1.1.1+LibO3.3.3-4~bpo60+1 squeeze-backports 1.1.1+LibO3.5.4+dfsg2-0+deb7u2 stable 1.1.1+LibO3.5.4+dfsg-3~bpo60+2 squeeze-backports 1.1.2+LibO4.1.4-2~bpo70+1 wheezy-backports 1.1.2+LibO4.2.4-3~bpo70+1 wheezy-backports 1.1.2+LibO4.2.4-4 testing unstable 1.1.2+LibO4.3.0~beta1-1 experimental libreoffice-writer - suite de productivité bureautique - traitement de texte Homepage: http://www.libreoffice.org 1:3.5.4+dfsg2-0+deb7u2 stable 1:3.5.4+dfsg-3~bpo60+2 squeeze-backports 1:4.2.4-3~bpo70+1 wheezy-backports 1:4.2.4-4 testing unstable 1:4.3.0~beta1-1 experimental 1:3.5.4+dfsg2-0+deb7u2 installed libreoffice-writer2latex - Writer/Calc to LaTeX converter extension for LibreOffice Homepage: http://writer2latex.sourceforge.net 1.0.2-8 stable 1.0.2-10 testing unstable libreoffice-writer2xhtml - Writer/Calc to XHTML converter extension for LibreOffice Homepage: http://writer2latex.sourceforge.net 1.0.2-8 stable 1.0.2-10 testing unstable libreoffice-zemberek - Turkish spell checker extension for LibreOffice Homepage: http://code.google.com/p/zemberek/ 1.0~rc2-10.4 stable testing unstable libreoffice-zotero-integration - module LibreOffice pour organiser et partager des sources de recherche Homepage: http://www.zotero.org/ 4.0.17-2~bpo70+1 wheezy-backports 4.0.17-2 testing 4.0.20-1 unstable openclipart2-libreoffice - clip art for OpenOffice.org/LibreOffice gallery Homepage: http://openclipart.org 2.0+dfsg-1 stable testing unstable openclipart-libreoffice - clip art for OpenOffice.org/LibreOffice gallery Homepage: http://www.openclipart.org 1:0.18+dfsg-14 stable testing unstable [18:14:55] ~ #
Libreoffice je n’ai jamais réussi à installer quoi que ce soit, donc la vérole que j’ai amenée n’est pas liée à libreoffice.
Je pense plus à une tentative très laide d’installation d’avidemux, au travers de ce dépôt.
$ aptitude -s remove --purge startpar The following packages will be REMOVED: startpar The following partially installed packages will be configured: sysvinit-utils 0 packages upgraded, 0 newly installed, 1 to remove and 745 not upgraded. Need to get 0 B of archives. After unpacking 97,3 kB will be freed. Would download/install/remove packages.
$ aptitude search ~c rien trouvé...
[code]$ aptitude -s reinstall sysvinit-utils
The following packages will be REINSTALLED:
sysvinit-utils
0 packages upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 745 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
The following packages have unmet dependencies:
startpar : Breaks: sysvinit-utils (< 2.88dsf-52) but 2.88dsf-41+deb7u1 is installed.
The following actions will resolve these dependencies:
 Remove the following packages:
  1. startpar
Accept this solution? [Y/n/q/?]
Je brise les pattes à startpar?
J’adore :005
Oui … :wink:
C’est parti:
[code]$ aptitude remove --purge startpar
startpar
sysvinit-utils
(Reading database … 83462 files and directories currently installed.)
Removing startpar …
Processing triggers for man-db …
Setting up sysvinit-utils (2.88dsf-41+deb7u1) …
Current status: 0 broken [-1].[/code]
$ apt-get dist-upgrade You are running a kernel (version 3.13-1-amd64) and attempting to remove │ │ the same version. │ │ │ │ This can make the system unbootable as it will remove │ │ /boot/vmlinuz-3.13-1-amd64 and all modules under the directory │ │ /lib/modules/3.13-1-amd64. This can only be fixed with a copy of the │ │ kernel image and the corresponding modules. │ │ │ │ It is highly recommended to abort the kernel removal unless you are │ │ prepared to fix the system after removal. │ │ │ │ Abort kernel removal?
Oups…
/boot$ ls config-3.13-1-amd64 initrd.img-3.13-1-amd64 System.map-3.13-1-amd64 grub lost+found vmlinuz-3.13-1-amd64
ps : $:017
À quoi bon vouloir confronter ces deux belligérants en tant que gestionnaire de paquet que sont respectivement aptitude et apt ?
ps : $:017
D’autant plus qu’aptitude est de très loin, bien plus causant … :violin: (entre autres :083 )
ps ; je ne sais plus trop où nous en sommes et pour l’heure …
[mono]# aptitude -s upgrade[/mono] ?
[mono]# aptitude -s full-upgrade[/mono] ?
# aptitude -s upgrade Resolving dependencies... Unable to resolve dependencies for the upgrade: no solution found. Unable to safely resolve dependencies, try running with --full-resolver.
[code]# aptitude -s full-upgrade
libee0{u} libestr0{u} liblogging-stdlog0{u} liblognorm0{u} systemd{u}
anacron avahi-daemon bzip2 dbus gir1.2-gnomebluetooth-1.0{b}
gnome-bluetooth{b} libdbus-1-3 libexpat1 libpam-systemd{b} libtirpc1
libwrap0 linux-image-amd64{b} modemmanager network-manager
network-manager-gnome{b} ppp rsyslog
0 packages upgraded, 0 newly installed, 5 to remove and 717 not upgraded.
Need to get 0 B of archives. After unpacking 5 335 kB will be freed.
libpam-systemd : Depends: systemd (= 44-11+deb7u4) but it is not going to be installed.
network-manager-gnome : Depends: libgnome-bluetooth10 (>= 2.91.2) but it is not going to be installed.
Depends: gconf2 (>= 2.28.1-2) but it is not going to be installed.
linux-image-amd64 : Depends: linux-image-3.2.0-4-amd64 but it is not going to be installed.
gnome-bluetooth : Depends: libgnome-bluetooth10 (>= 3.4.0) but it is not going to be installed.
gir1.2-gnomebluetooth-1.0 : Depends: libgnome-bluetooth10 (>= 3.4.0) but it is not going to be installed.
  1.  colord
  2.  gir1.2-gnomebluetooth-1.0
  3.  gnome-bluetooth
  4.  libpam-systemd
  5.  linux-image-amd64
  6.  network-manager-gnome
  7.  policykit-1
  8.  policykit-1-gnome
    Leave the following dependencies unresolved:
  9.  network-manager recommends policykit-1
  10. network-manager-gnome recommends gnome-bluetooth
  11. udisks recommends policykit-1
  12. synaptic recommends gksu | kdebase-bin | policykit-1
  13. lightdm-gtk-greeter recommends policykit-1
  14. udisks2 recommends policykit-1
  15. gvfs-daemons recommends policykit-1-gnome
  16. libcolord1 recommends colord
  17. task-xfce-desktop recommends network-manager-gnome  [/code]
[code]# aptitude -s upgrade --full-resolver
  1.  colord
  3.  gnome-bluetooth
  4.  libpam-systemd
  7.  policykit-1
Accept this solution? [Y/n/q/?] [/code]
Il semblerait qu’une lueur apparaisse au bout du tunnel … 8)
[quote=“isterios”] # aptitude -s upgrade --full-resolver
Accept this solution? [Y/n/q/?] n
etc …
Je commencerai par régler cette histoire de kernel.
Clous le bec à aptitude en lui répondant fermement non, à de multiples reprises.
On verra s’il propose à un moment où l’autre une solution digne de ce nom et sans se prendre le choux … :violin:
Dans le cas contraire et improbable, à la mano.
ps : Conserves le mode simulation, hein … :wink:
Va falloir commencer à lui apprendre le respect, donc:
[code]sudo aptitude -s upgrade --full-resolver
  1.  colord
  3.  gnome-bluetooth
  4.  libpam-systemd
  7.  policykit-1
  17. task-xfce-desktop recommends network-manager-gnome[/code]
[code]Accept this solution? [Y/n/q/?] n
  1. libpam-systemd
    Install the following packages:
  2. firmware-linux-free [3.2 (stable)]
  3. gconf2 [3.2.5-1+build1 (stable)]
  4. libgnome-bluetooth10 [3.4.2-1 (stable)]
  5. linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
    Downgrade the following packages:
  6. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  7. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  8. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  9. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]  [/code]
  1. libpam-systemd
  2. gconf2 [3.2.5-1+build1 (stable)]
  3. libgnome-bluetooth10 [3.4.2-1 (stable)]
  4. linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
  5. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  6. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  7. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  8. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]
  9. linux-image-3.2.0-4-amd64 recommends firmware-linux-free (>= 3~)[/code]
  1. libpam-systemd
  2. linux-image-amd64
  8. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]  [/code]
  1. libpam-systemd
  2. network-manager-gnome
  3. firmware-linux-free [3.2 (stable)]
  6. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]
  1. libpam-systemd
  5. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]
  6. linux-image-3.2.0-4-amd64 recommends firmware-linux-free (>= 3~)
  1.  colord
  2.  libpam-systemd
  3.  network-manager-gnome
  4.  policykit-1
  5.  policykit-1-gnome
  6.  firmware-linux-free [3.2 (stable)]
  7.  gconf2 [3.2.5-1+build1 (stable)]
  8.  gksu [2.0.2-6 (stable)]
  9.  libgconf2-4 [3.2.5-1+build1 (stable)]
  10. libgksu2-0 [2.0.13~pre1-6 (stable)]
  11. libgnome-bluetooth10 [3.4.2-1 (stable)]
  12. linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
  13. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  14. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  15. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  16. network-manager recommends policykit-1
  17. udisks recommends policykit-1
  18. lightdm-gtk-greeter recommends policykit-1
  19. udisks2 recommends policykit-1
  20. gvfs-daemons recommends policykit-1-gnome
  21. libcolord1 recommends colord
  22. task-xfce-desktop recommends network-manager-gnome[/code]
  1.  colord
  2.  libpam-systemd
  4.  policykit-1
  8.  libgnome-bluetooth10 [3.4.2-1 (stable)]
  9.  linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
  10. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  11. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  12. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  13. network-manager recommends policykit-1
  14. udisks recommends policykit-1
  15. synaptic recommends gksu | kdebase-bin | policykit-1
  16. lightdm-gtk-greeter recommends policykit-1
  17. udisks2 recommends policykit-1
  18. gvfs-daemons recommends policykit-1-gnome
  19. libcolord1 recommends colord
  20. task-xfce-desktop recommends network-manager-gnome
Je mets ici les premières propositions, je ne sais pas combien de possibilités il y a.
C’est qui le boss … :016
Oui, continus si tu le peux et envois la suite … sur une proposition [mono]linux-image-version[/mono] (?!)
Sinon …
[mono]$ dpkg -l | grep linux-image[/mono]
* edit *
Allez soldons l’affaire de kernel.
[mono]$ dpkg -l | grep linux-image[/mono] ??
ps : sinon, dans l’ensemble c’est bien barré. :wink:
  1.  colord
  2.  libpam-systemd
  4.  policykit-1
  6.  gconf2 [3.2.5-1+build1 (stable)]
  7.  gksu [2.0.2-6 (stable)]
  8.  libgconf2-4 [3.2.5-1+build1 (stable)]
  9.  libgksu2-0 [2.0.13~pre1-6 (stable)]
  10. libgnome-bluetooth10 [3.4.2-1 (stable)]
  11. linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
  12. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  13. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  14. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  15. linux-image-3.2.0-4-amd64 recommends firmware-linux-free (>= 3~)
  22. task-xfce-desktop recommends network-manager-gnome [/code]
  1. libpam-systemd
  6. task-xfce-desktop recommends network-manager-gnome
  1.  colord
  2.  libpam-systemd
  4.  policykit-1
  7.  libgnome-bluetooth10 [3.4.2-1 (stable)]
  8.  linux-image-3.2.0-4-amd64 [3.2.57-3 (stable)]
  9.  gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  10. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  11. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  12. linux-image-3.2.0-4-amd64 recommends firmware-linux-free (>= 3~)
  20. task-xfce-desktop recommends network-manager-gnome [/code]
  1.  colord
  2.  libpam-systemd
  4.  policykit-1
  10. udisks recommends policykit-1
  11. synaptic recommends gksu | kdebase-bin | policykit-1
  12. lightdm-gtk-greeter recommends policykit-1
  13. udisks2 recommends policykit-1
  14. gvfs-daemons recommends policykit-1-gnome
  15. libcolord1 recommends colord
  16. task-xfce-desktop recommends network-manager-gnome[/code]
Je continue ce soir pour les propositions.
# dpkg -l | grep linux-image ri linux-image-3.13-1-amd64 3.13.10-1 amd64 Linux 3.13 for 64-bit PCs iU linux-image-amd64 3.2+46 amd64 Linux for 64-bit PCs (meta-package)
[quote]Je continue ce soir pour les propositions.
Inutiles (perte de temps) on réglera cela à grand coup de pompe dans le noyau … :wink:
À toute à …
<* edit *>
[quote] Sous réserve. À vérifié.
[quote][mono]ri linux-image-3.13-1-amd64[/mono]
r -le paquet va être réinstallé.
i -le paquet va être installé.[/quote]
[quote][mono]iU linux-image-amd64[/mono]
i -le paquet est installé et toutes ses dépendances sont satisfaites.
u -le paquet a été dépaqueté mais pas configuré.
[/quote][/quote]
Attention¹, sur une machine amd64, chez moi …
Te concernant, le retour suivant², stp.
[mono]$ aptitude search linux-image[/mono] ?
Chez moi¹, je balancerai en fonction de … ²
[mono]$ aptitude -s install linux-image-3.2.0-4-686-pae
etc …[/mono]
[mono]$ aptitude -s install linux-image-686-pae
etc …[/mono]
<* edit */>
$ aptitude search linux-image v linux-image - p linux-image-2.6-amd64 - Linux for 64-bit PCs (dummy package) id linux-image-3.13-1-amd64 - Linux 3.13 for 64-bit PCs p linux-image-3.2.0-4-amd64 - Linux 3.2 for 64-bit PCs p linux-image-3.2.0-4-amd64-dbg - Debugging symbols for Linux 3.2.0-4-amd64 p linux-image-3.2.0-4-rt-amd64 - Linux 3.2 for 64-bit PCs, PREEMPT_RT p linux-image-3.2.0-4-rt-amd64-dbg - Debugging symbols for Linux 3.2.0-4-rt-amd64 BB linux-image-amd64 - Linux for 64-bit PCs (meta-package) p linux-image-rt-amd64 - Linux for 64-bit PCs (meta-package), PREEMPT_RT
Donc chez moi la rebelle est hébergée sur un bignou 64 bits.
En 3.2.0-4
[code]# aptitude -s install linux-image-3.2.0-4-amd64
The following NEW packages will be installed:
firmware-linux-free{a} linux-image-3.2.0-4-amd64
anacron avahi-daemon bzip2 dbus gir1.2-gnomebluetooth-1.0{b} gnome-bluetooth{b} libdbus-1-3 libexpat1 libpam-systemd{b}
libtirpc1 libwrap0 linux-image-amd64 modemmanager network-manager network-manager-gnome{b} ppp rsyslog
0 packages upgraded, 2 newly installed, 5 to remove and 717 not upgraded.
Need to get 0 B/23,4 MB of archives. After unpacking 101 MB will be used.
  1.  colord
  3.  gnome-bluetooth
  4.  libpam-systemd
  5.  network-manager-gnome
  6.  policykit-1
  7.  policykit-1-gnome
  8.  network-manager recommends policykit-1
  9.  network-manager-gnome recommends gnome-bluetooth
  16. task-xfce-desktop recommends network-manager-gnome [/code]
  1. libpam-systemd
  4. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  5. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  6. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  7. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)] [/code]
  1. libpam-systemd
  4. policykit-1 [0.105-5 (now) -> 0.105-3 (stable)]
  5. task-xfce-desktop recommends network-manager-gnome[/code]
  1.  colord
  2.  libpam-systemd
  4.  policykit-1
  11. gconf-service [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  12. gconf2-common [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  13. libgconf-2-4 [3.2.6-2 (now) -> 3.2.5-1+build1 (stable)]
  14. network-manager recommends policykit-1
  15. udisks recommends policykit-1
et avec la 64 générique:
[code]$ aptitude -s install linux-image-amd64
firmware-linux-free{a} linux-image-3.2.0-4-amd64{a}
  1.  colord
  3.  gnome-bluetooth
  4.  libpam-systemd
  6.  policykit-1
  1. libpam-systemd
etc.
Quelle proposition dois-je attendre?
