Voilà, je n’arrive pas à installer libreoffice sur ma wheezy pourtant fraîche. Voici ce que j’obtiens:
The following NEW packages will be installed:
ant{a} ant-optional{a} ca-certificates-java{a} default-jre{a} default-jre-headless{a} fonts-sil-gentium{a}
fonts-sil-gentium-basic{a} icedtea-6-jre-cacao{a} icedtea-6-jre-jamvm{a} icedtea-netx{a} icedtea-netx-common{a}
java-common{a} libapache-pom-java{a} libatk-wrapper-java{a} libatk-wrapper-java-jni{a} libcolamd2.7.1{a}
libcommons-beanutils-java{a} libcommons-collections3-java{a} libcommons-compress-java{a} libcommons-digester-java{a}
libcommons-logging-java{a} libcommons-parent-java{a} libdb-java{a} libdb-je-java{a} libdb5.1-java{a}
libdb5.1-java-jni{a} libgif4{a} libhsqldb-java{a} libicu4j-java{a} libjaxp1.3-java{a} libjline-java{a} libjtidy-java{a}
liblucene2-java{a} libnss3-1d{ab} libregexp-java{a} libreoffice{b} libreoffice-base{ab} libreoffice-base-core{ab}
libreoffice-calc{ab} libreoffice-draw{ab} libreoffice-emailmerge{a} libreoffice-filter-binfilter{ab}
libreoffice-filter-mobiledev{a} libreoffice-impress{ab} libreoffice-java-common{a} libreoffice-math{ab}
libreoffice-report-builder-bin{a} libreoffice-writer{ab} libservlet2.5-java{a} libvisio-0.0-0{a} libwpd-0.9-9{a}
libwpg-0.2-2{a} libwps-0.2-2{a} libxalan2-java{a} libxerces2-java{a} libxml-commons-external-java{a}
libxml-commons-resolver1.1-java{a} libxz-java{a} lp-solve{a} openjdk-6-jre{a} openjdk-6-jre-headless{a}
openjdk-6-jre-lib{a} python-uno{ab} ttf-dejavu{a} ttf-dejavu-core{a} ttf-dejavu-extra{a} ttf-liberation{a}
ttf-sil-gentium-basic{a} tzdata-java{a}
Jusque là tout va bien. Puis:
[quote]The following packages have unmet dependencies:
libreoffice-base-core : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-filter-binfilter : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-writer : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-impress : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-base : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-draw : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-core : Conflicts: libreoffice-filter-binfilter but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
Breaks: libreoffice-base (< 1:4.1.6~rc2-1+b1) but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
Breaks: libreoffice-calc (< 1:4.1.6~rc2-1+b1) but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
Breaks: libreoffice-draw (< 1:4.1.6~rc2-1+b1) but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
Breaks: libreoffice-impress (< 1:4.1.6~rc2-1+b1) but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
Breaks: libreoffice-writer (< 1:4.1.6~rc2-1+b1) but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
python-uno : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libnss3-1d : Depends: libnss3 (= 2:3.14.5-1) but 2:3.16-1 is installed.
libreoffice-common : Conflicts: libreoffice-filter-mobiledev but 1:3.5.4+dfsg2-0+deb7u2 is to be installed.
fonts-dejavu-core : Breaks: ttf-dejavu-core (< 2.33+svn2514-2~) but 2.33-3 is to be installed.
libreoffice-math : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
libreoffice-calc : Depends: libreoffice-core (= 1:3.5.4+dfsg2-0+deb7u2) but 1:4.1.6~rc2-1+b1 is installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
ant [Not Installed]
ant-optional [Not Installed]
ca-certificates-java [Not Installed]
default-jre [Not Installed]
default-jre-headless [Not Installed]
icedtea-6-jre-cacao [Not Installed]
icedtea-6-jre-jamvm [Not Installed]
icedtea-netx [Not Installed]
9) libnss3-1d [Not Installed]
10) libreoffice [Not Installed]
11) libreoffice-base [Not Installed]
12) libreoffice-base-core [Not Installed]
13) libreoffice-calc [Not Installed]
14) libreoffice-draw [Not Installed]
15) libreoffice-emailmerge [Not Installed]
16) libreoffice-filter-binfilter [Not Installed]
17) libreoffice-filter-mobiledev [Not Installed]
18) libreoffice-impress [Not Installed]
19) libreoffice-math [Not Installed]
20) libreoffice-report-builder-bin [Not Installed]
21) libreoffice-writer [Not Installed]
22) openjdk-6-jre [Not Installed]
23) openjdk-6-jre-headless [Not Installed]
24) openjdk-6-jre-lib [Not Installed]
25) python-uno [Not Installed]
26) ttf-dejavu [Not Installed]
27) ttf-dejavu-core [Not Installed]
28) ttf-dejavu-extra [Not Installed]
Leave the following dependencies unresolved:
libjtidy-java recommends ant
libreoffice-writer recommends libreoffice-filter-binfilter
libreoffice-writer recommends libreoffice-math
[quote]Accept this solution? [Y/n/q/?] y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.[/quote]
Et donc, rien ne s’installe…
J’ai bien tenté de remettre mon sources.list d’équerre en suivant le post de ce forum mais ca ne change rien, le résultat est identique.
Qu’en pensez-vous?
Merci.
