je voudrais déporter mon affichage de ma debian via internet sur une machine win.
J’ai trouvé des tutos, ils utilisent xming comme serveur graphique coté win. Mais l’installeur de xming date de 2007.
Savez vous si ce projet est toujours actif, et si il fonctionne sur un win7 ?
straightrunning.com/XmingNot … p#head-298
[quote]
Xming 7.5.0.87 (x86 & x64 Released 23 Oct 2014)
Update FreeType2 from its project git repository, and Mesa from X.Org git.
Add Windows 10 to the OS detector and extend the manifest files compatibility/application/supportedOS entries.
In XLaunch warn against some colliding options when they are entered in 'Additional parameters for plink or ssh'. Also warn against use of xserver option -ac.
In Plink's 'PuTTY Link: Enter Credentials' dialog: display clear text (not substitute asterisks) for the 'Username required...' entry.
Build both Plink(s) from PuTTY project SVN source at revision 10291 (Simon's canonical source now moved to git).
Update the OpenGL extension headers and specifications from the canonical [WWW]OpenGL Registry for use in the X server build (Khronos SVN at revision 28692).
Xming 7.5.0.86 (Released 11 Oct 2014). [/quote]
Je n’ai pas testé l’installer Microsoft de Xming, d’une part parce qu’il faut un OS Microsoft pour l’installer et d’autre part parce que c’est la croix et la bannière de télécharger depuis sourceforge.
Il semblerait qu’il soit plus facile d’installer cygwin/X.
x.cygwin.com/docs/ug/setup.html# … installing
[quote]On the next screen you will select the packages that will be downloaded and installed. A listing of the Cygwin/X packages is given below; a listing of the general Cygwin packages would be beyond the scope of this document.
Cygwin/X packages are located in the X11 category.
xorg-server (required, the Cygwin/X X Server)
xinit (required, scripts for starting the X server: xinit, startx, startwin (and a shortcut on the Start Menu to run it), startxdmcp.bat )
xorg-docs (optional, man pages)
xlaunch (optional, a wizard for starting X sessions)
You may also select any X client programs you want to use, and any fonts you would like to have available.
You may also want to ensure that the openssh package is selected if you wish to use ssh connections to run remote X clients.
You may also want to ensure that the inetutils or rsh packages are selected if you wish to use telnet or rsh connections to run remote X clients. (not recommended) [/quote]
Merci pour le lien vers la derniére version de xming.
Cygwin, j’ai testé sur un xp. Ca rendait l’ensemble assez peu stable (augmentation du nb d’écran bleu aprés install de cygwin, mais difficile de trouver le lien de cause à effet).
En fait, le téléchargement est payant depuis 2007 (donation).
La version de 2007 serait compatible W7.
en.wikipedia.org/wiki/Xming
Je vais me remettre à cygwin/X
Il y a des versions “public” disponible, mais en effet assez ancienne (4 May 2007) :
sourceforge.net/projects/xming/
straightrunning.com/XmingNotes/#head-12
j’ai installé cygwin et w-win, mais pour l’instant, ça ne fonctionne pas (pas de fenêtre de serveur X qui apparaît).
Je ne peux pas encore avoir le déport d’affichage de ma machine debian!
