voici ce que tu veut :
[code]# XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "GeForce 6600GT"
Driver "nv"
VideoRam 131072
EndSection
Section "Monitor"
Identifier "peacock"
HorizSync 28-49
VertRefresh 43-72
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "GeForce 6600GT"
Monitor "peacock"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
AMD 2200+ DD IDE 512 DDR GeForce 6600GT
voici une pitite question j’ai mi les depo unstable et pendant l’install il me dit :
[code]Name Service Switch update in the C Library: pre-installation question.
Running services and programs that are using NSS need to be restarted,
otherwise they might not be able to do lookup or authentication any more.
The installation process is able to restart some services (such as ssh or
telnetd), but other programs cannot be restarted automatically. One such
program that needs manual stopping and restart after the glibc upgrade by
yourself is xdm - because automatic restart might disconnect your active
X11 sessions.
Known packages that need to be stopped before the glibc upgrade are:
xdm kdm gdm postgresql xscreensaver
This script detected the following installed services which must be
stopped before the upgrade:
xdm
postgresql
xscreensaver
If you want to interrupt the upgrade now and continue later, please
answer No to the question below.
Do you want to upgrade glibc now? [Y/n]
je repond quoi ?!
