Re,
Vérifies la présence de [mono]pm-utils[/mono].
Paquet : pm-utils
État: installé
Automatiquement installé: oui
Version : 1.4.1-9
Priorité : optionnel
Section : admin
Responsable : Tim Dijkstra <tim@famdijkstra.org>
Architecture : all
Taille décompressée : 343 k
Dépend: powermgmt-base
Recommande: vbetool, procps, hdparm, kbd | console-tools
Suggère: cpufrequtils, wireless-tools, ethtool, radeontool
Est en conflit: laptop-mode-tools (< 1.55), pm-utils-powersave-policy
Remplace: laptop-mode-tools (< 1.55), pm-utils-powersave-policy
Description : Utilitaires et scripts pour la gestion de l'énergie
Ce paquet fournit des outils simples en ligne de commande sous la forme d'un script shell pour suspendre et mettre en hibernation votre ordinateur.
Site : http://pm-utils.freedesktop.org/
Le group et l’user sont-ils en pôle position ?
[mono]$ man pm-suspend[/mono]
[quote]DESCRIPTION
This manual page documents briefly the pm-action, pm-hibernate, pm-suspend and pm-suspend-hybrid commands. This manual page was originally written for the Debian™
distribution and has been adopted by the pm-utils project.
These commands can be used to put the machine in a sleep state. The precise way how this is done can be influenced by installing executables and configuration
snippets. For some options external programs are needed.
These commands will usually be called by UPower or hald when triggered to do so by a program in a desktop session such as gnome-power-manager. Calling them from the
command line is also possible, but it is not guaranteed that all programs in your desktop session keep working as expected.
pm-suspend
During suspend most devices are shutdown, and system state is saved in RAM. The system still requires power in this state. Most modern systems require 3 to 5
seconds to enter and leave suspend, and most laptops can stay in suspend mode for 1 to 3 days before exhausting their battery.
pm-hibernate
During hibernate the system is fully powered off, and system state is saved to disk. The system does not require power, and can stay in hibernate mode
indefinitely. Most modern systems require 15 to 45 seconds to enter and leave hibernate, and entering and leaving hibernate takes longer when you have more memory.
pm-suspend-hybrid
Hybrid-suspend is the process where the system does everything it needs to hibernate, but suspends instead of shutting down. This means that your computer can wake
up quicker than for normal hibernation if you do not run out of power, and you can resume even if you run out of power. s2both(8) is an hybrid-suspend
implementation.
[code][17:57:11] ~ # tail -n45 /var/log/pm-suspend.log
/usr/lib/pm-utils/sleep.d/99video suspend suspend: success.
Sat Jun 28 17:32:52 CEST 2014: performing suspend
Sat Jun 28 17:33:44 CEST 2014: Awake.
Sat Jun 28 17:33:44 CEST 2014: Running hooks for resume
Running hook /usr/lib/pm-utils/sleep.d/99video resume suspend:
/usr/lib/pm-utils/sleep.d/99video resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend:
/usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95led resume suspend:
/usr/lib/pm-utils/sleep.d/95led resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/94cpufreq resume suspend:
/usr/lib/pm-utils/sleep.d/94cpufreq resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/90clock resume suspend:
/usr/lib/pm-utils/sleep.d/90clock resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/75modules resume suspend:
Reloaded unloaded modules.
/usr/lib/pm-utils/sleep.d/75modules resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend:
Failed to connect to wpa_supplicant - wpa_ctrl_open: No such file or directory
/usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/55NetworkManager resume suspend:
Having NetworkManager wake interfaces back up…Failed.
/usr/lib/pm-utils/sleep.d/55NetworkManager resume suspend: success.
Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend:
/etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00powersave resume suspend:
/usr/lib/pm-utils/sleep.d/00powersave resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00logging resume suspend:
/usr/lib/pm-utils/sleep.d/00logging resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/000kernel-change resume suspend:
/usr/lib/pm-utils/sleep.d/000kernel-change resume suspend: success.
Sat Jun 28 17:33:45 CEST 2014: Finished.
[17:57:17] ~ # [/code]
