Yt-dlp ne fonctionne plus
Bonjour à tous
J’utilise souvent yt-dlp pour enregistrer des videos (tuto) car j’ai un forfait limité ,depuis quelque temps cela ne fonctionne plus , j’ai ce message d’erreur :
WARNING: [youtube] unable to extract yt initial data; please report this issue on  https://github.com/yt-dlp/yt-dlp/issues?q= , filling out the appropriate issue template. Confirm you are on the latest version using  yt-dlp -U
[youtube] 8upK-MfOxW0: Downloading initial data API JSON
[info] 8upK-MfOxW0: Downloading 1 format(s): 22
ERROR: unable to download video data: HTTP Error 403: Forbidden
J’ai bien exécuté yt-dlp -U mais sans résultat
Pouvez vous résoudre ce problème.
Je viens de tester avec la même vidéo et chez moi, ça marche pas non plus :
[youtube] Extracting URL: https://www.youtube.com/watch?v=8upK-MfOxW0
[youtube] 8upK-MfOxW0: Downloading webpage
WARNING: [youtube] unable to extract initial player response; please report this issue on  https://github.com/yt-dlp/yt-dlp/issues?q= , filling out the appropriate issue template. Confirm you are on the latest version using  yt-dlp -U
[youtube] 8upK-MfOxW0: Downloading android player API JSON
[youtube] 8upK-MfOxW0: Downloading iframe API JS
[youtube] 8upK-MfOxW0: Downloading player f130aa11
[youtube] 8upK-MfOxW0: Downloading web player API JSON
[info] 8upK-MfOxW0: Downloading 1 format(s): 303+251
[dashsegments] Total fragments: 10
[download] Destination: Welcome Debian 11 [8upK-MfOxW0].f303.webm
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (1/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (2/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (3/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (4/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (5/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (6/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (7/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (8/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (9/10)...
[download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (10/10)...
[download] Got error: HTTP Error 403: Forbidden. Giving up after 10 retries
ERROR: fragment 1 not found, unable to continue
[dashsegments] Total fragments: 2
[download] Destination: Welcome Debian 11 [8upK-MfOxW0].f251.webm
Ça, par contre, ça donne un résultat chez moi :
Available version: stable@2023.09.24, Current version: stable@2023.03.04
ERROR: As yt-dlp has been installed via apt, you should use that to update.  If you're on a stable release, also check backports.
Et, effectivement, la version en backports (Debian 12) est plus récente et j’ai pu télécharger la vidéo sans problème avec.
Par contre, je ne sais pas du tout quelle version tu as, ni comment tu l’as l’installée, ni sur quelle version de Debian tu es, je ne peux donc pas te donner plus d’indications.
yt-dlp changelog 2023.09.24
**youtube**
    - [Add `player_params` extractor arg]
    - [Fix `player_params` arg being converted to lowercase]
    - [Fix consent cookie]
    - tab: [Detect looping feeds]
$ yt-dlp -f17 8upK-MfOxW0
[youtube] Extracting URL: 8upK-MfOxW0
[youtube] 8upK-MfOxW0: Downloading ios player API JSON
[youtube] 8upK-MfOxW0: Downloading m3u8 information
[info] 8upK-MfOxW0: Downloading 1 format(s): 17
[download] Destination: Welcome Debian 11 [8upK-MfOxW0].3gp
[download] 100% of    5.71MiB in 00:00:02 at 2.38MiB/s
Je suis revenu sous debian 11 environnement gnome .
Cela ne fonctionne pas avec les backports activé sous debian 11, pour résoudre ce problème j’ai téléchargé le paquet deb yt-dlp (2023.07.06-1~bpo12+1) bookworm-backports .
Merci de vos réponses
à cause du truc tout pourrio de python3/pip, j’utilise courrament pip
j’ai donc fait un alias qui téklécharge la dernière version de yt-dlp et ça marche avec ton adresse ( sous bookworm )
alias ytdlp='echo "ne pas oublier de détruire le dossier ytdlp-poub";python3 -m venv ytdlp-poub&& source ytdlp-poub/bin/activate && pip install yt-dlp && yt-dlp "$1"'
et je tape
ytdlp https://www.youtube.com/watch?v=8upK-MfOxW0
