3 façons d'installer Java JRE/JDK pour Debian
3 façons d’installer Java JRE/JDK pour Debian
Voici un excellent how-to qui consiste en la présentation de 3 façons différentes pour installer Java JRE
(Runtime Environment) et/ou JDK (Developer Kit) pour Debian.
wiki.serios.net/wiki/Debian_Java … stallation
1/ With java-package/make-jpkg
For e.g. the Sun Java there are no prepackaged deb archives of it. I have written detailed instructions on how to install a Java JRE or JDK with java-package by creating a deb archive of the JRE/JDK .bin installation file.
* [url=http://wiki.serios.net/wiki/Debian_Java_JRE/JDK_installation_with_java-package]Debian Java JRE/JDK installation with java-package[/url]
This method applies for:
* Sun Java 5.0 (x86, AMD64)
* Sun Java 1.4 (x86)
* IBM Java 5.0 (x86, AMD64, PowerPC, PowerPC64, S/390)
* IBM Java 1.4 (x86, AMD64, PowerPC, PowerPC64, S/390)
* IBM Java 1.3 (x86, PowerPC, S/390)
* Blackdown Java 1.4 (x86, AMD64, SPARC)
* Blackdown Java 1.3 (x86, PowerPC)
Quick summary of the procedure for the impatient, please read the full document for all details:
Download JRE/JDK .bin or .tgz archive file from Sun, Blackdown, or IBM
apt-get install java-package fakeroot make-jpkg jre-1_5_0_06-linux-i586.bin dpkg -i sun-j2re1.5_1.5.0+update06_i386.deb
2/ Installing from APT repositories containing Java packages
There are prepackaged JREs/JDKs available for Sun and IBM JRE/JDK 5.0 from a third party repository — Debian Unofficial.
* [url=http://wiki.serios.net/wiki/Debian_Java_JRE/JDK_installation_from_APT_repositories]Debian Java JRE/JDK installation from APT repositories[/url]
* Sun Java 5.0 (x86)
* IBM Java 5.0 (x86, PowerPC)
Edit or add repositories into the APT sources file
apt-get update apt-get install sun-j2se5.0-jre-binary
3/ Manual installation
If you are using some platform that isn’t supported by java-package/make-jpkg, or if you just simply don’t want to use the above two methods for whatever reasons you may have, you can install the JRE/JDK more “manually” too.
The main drawback of installing with this “manual” method is that the JRE/JDK won’t automatically get integrated with the Debian’s package management, so you’ll run into problems if you try to install something that depends on Java, e.g. Tomcat. One can create dummy packages though to make the dependencies appear as if they are fulfilled.
Generally, I do not recommend this unless the two above described methods absolutely don’t work for you.
* [url=http://wiki.serios.net/wiki/Debian_Java_JRE/JDK_installation_manually]Debian Java JRE/JDK installation manually[/url]
* ... and most likely any other version or architecture of the available Sun, IBM and Blackdown JRE/JDKs as well.
Enjoy 8)
[code] apt-get install java-package
je comprens j’arrive pas à installer le java-package, par hasard il faut mettre un truc en plus des sourcs.list
comment ceux tu qu’on le sache ? :laughing:
dans mes soruces j’ai ceci
je suis en amd64 sous sarge
[code]#deb file:///cdrom/ sarge main
deb ftp://ftp.crans.org/debian-amd64//debian stable main
deb-src ftp://ftp.crans.org/debian-amd64//debian stable main
deb http://security.debian.org/ stable/updates main
$ apt-cache policy java-package java-package: Installed: 0.27 Candidate: 0.27 Version table: *** 0.27 0 500 http://ftp.fr.debian.org testing/contrib Packages 500 http://ftp.fr.debian.org unstable/contrib Packages 100 /var/lib/dpkg/status
donc, tu rajoutes contrib partout, et pendant que tu y es non-free, à la suite de main…
donc si je comprend bien il va falloir que je rajoute ces lignes
[code]deb ftp://ftp.crans.org/debian-amd64//debian contrib
deb ftp://ftp.crans.org/debian-amd64//debian non free
non ce n’est pas ce que j’ai dit. mais ça peut aussi suffire à étendre tes sources.
Par contre, si tu arrives à installer java-package, AMA fakeroot make-jpkg jre-1_5_0_06-linux-i586.bin dpkg -i sun-j2re1.5_1.5.0+update06_i386.deb ne va pas te produire un paquet exploitable, parceque tu n’es pas en x86.
[quote=“burinho”]donc si je comprend bien il va falloir que je rajoute ces lignes
[/code][/quote]
tu peux tout mettre à la suite
un peu de recherche et lecture que diantre -> cfr forum.debian-fr.org/viewtopic.php?t=1810
ce qui donnerait dans ton cas:
(pourquoi “//” après le “amd64” au fait?)
quote="MattOTop"
Par contre, si tu arrives à installer java-package, AMA fakeroot make-jpkg jre-1_5_0_06-linux-i586.bin dpkg -i sun-j2re1.5_1.5.0+update06_i386.deb ne va pas te produire un paquet exploitable, parceque tu n’es pas en x86.[/quote]
c’est pour ça qu’il faut telecharger la version AMD64 du JRE ( ici par exemple: www-128.ibm.com/developerworks/j … nload.html ) et avec un peu de jugeotte remplacer i586 par amd64 dans les lignes de commande (enfin, par le nom du package quoi).
bonne merdouille :astonished:
nomdijiou de crévindiou!!
apprenez à faire une recherche et à lire avant de poser des questions!! je desespere là!! :astonished:
wiki.serios.net/wiki/Debian_Java … _for_AMD64
[quote]
2.1 [size=134]About the Java for AMD64[/size]
You need to be using a 64-bit AMD64 version of Debian to be able to use the Java for the AMD64. If you are using a 32-bit x86 version of Debian on an AMD64 processor using system, download the Java for the 32-bit x86 version.
Also worth noting, the Sun Java 1.5.0 for AMD64 doesn’t have the Java web browser plugin currently available, so for browsers that access Java through that plugin, one cannot currently view Java applets with the Sun Java 1.5.0 for AMD64. I suggest using the Blackdown Java 1.4.2 for AMD64 if you want to have Java support in such browsers.
bla bla bla … etc etc etc …[/quote]
et donc, je l’ecris en grand pour les suivants:
[size=184]Java JRE et/ou JDK pour AMD64 c’est par ici[/size]
==> wiki.serios.net/wiki/Debian_Java … _for_AMD64 <==
et je m’en va me tuer now :cry:
:blush:
désolé mais moi et l’anglais ça fait 2,
donc il semblerais d’apès ton post qu’il faudrait utilisé la version 1.4 sous amd 64
C’est incroyable dés qu’il faut installé un truc avec les sources j’y arrive jamais, déjà avec openoffice2.
là j’ai suivis cette démarche
ça c’est ok
au préalable j’ai télécharger k-1_5_0_05-linux-amd64.bin
fakeroot make-jpkg jdk-1_5_0_05-linux-amd64.bin
et la ça passe plus
which will allow no damage to be done to your system files and
still permit the Java distribution to successfully extract.
Tu as un paquet java que j’ai fait pour amd64 sur
deb boisson.homeip.net/amd64/ sarge ./
tu peux le récupérer si tu veux.
Oui je veux bien,
c’est le 1.5
bon j’ai capitulé mon jdk 1.5 par manque de temps je dois bosser sur du java
donc j’ai installé free-java-sdk dispo sur sarge
SableVM version 1.11.3
- compile date and time: 2005-04-14 01:57:03 UTC
- gcc version: 3.3.5 (Debian 1:3.3.5-12)
- 'real life brokenness' features enabled
- copying garbage collection
- bidirectional object layout
- direct-threaded interpreter
je suis quand même frustré, car je sais qu’utilisé des paquet proposer par debian, dés qu’il faut utilisé les sources ça marche pas
make-jpkg, alien ne travaille pas sur des sources mais sur des binaires afin de les adapter à la distribution Debian. Travailler sur les sources, c’est autre chose, pas nécessairement plus compliqué d’ailleurs…
c’étais bien un binaire mais j’y suis pas arrivé, je sais pas trop j’ai péché
[quote=“MattOTop”]fakeroot make-jpkg jre-1_5_0_06-linux-i586.bin dpkg -i sun-j2re1.5_1.5.0+update06_i386.deb[/quote]
fakeroot qu’il faut lancer en tant qu’utilisateur (et non root) me semble-t-il ne se trouve pas le paquet jre-1_5_0_06-linux-i586.bin… Peut être n’est pas la même version qui a été installé sur ma machine après le apt-get install ? Ou puis-je retrouver ce fichier et connaître sa version ?
[quote=“sebiseb”][quote=“MattOTop”]fakeroot make-jpkg jre-1_5_0_06-linux-i586.bin dpkg -i sun-j2re1.5_1.5.0+update06_i386.deb[/quote]
fakeroot qu’il faut lancer en tant qu’utilisateur (et non root) me semble-t-il ne se trouve pas le paquet jre-1_5_0_06-linux-i586.bin… Peut être n’est pas la même version qui a été installé sur ma machine après le apt-get install ? Ou puis-je retrouver ce fichier et connaître sa version ?[/quote]
dis, tu le fais expres?
fakeroot est fait justement pour ne pas devoir proceder à l’installation en tant que root (acronyme de “fake” et de “root”). donc oui, il FAUT lancer la commande en tant qu’utilisateur.
quant à jre-1_5_0_06-linux-xxx.bin c’est le fichier que tu as téléchargé sur l’un des sites mentionnés (sun, ibm, …). donc, si tu ne le trouve pas, cherche encore :smiley:
okay?
