/boot/grub/grub.cfg
[size=85][code]#
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then
load_env
fi
set default=“0"
if [ “${prev_saved_entry}” ]; then
set saved_entry=”${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry="${chosen}"
fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root=’(hd1,msdos5)‘
search --no-floppy --fs-uuid --set 0ae15c11-2855-4c94-8ddd-0a452232a2ab
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
load_video
insmod gfxterm
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
set root=’(hd1,msdos5)'
set locale_dir=($root)/boot/grub/locale
set lang=fr
insmod gettext
set timeout=5
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
insmod part_msdos
insmod ext2
insmod png
if background_image /usr/share/images/desktop-base/spacefun-grub.png; then
set color_normal=light-gray/black
set color_highlight=white/black
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
menuentry ‘Debian GNU/Linux, avec Linux 2.6.32-5-amd64’ --class debian --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
echo 'Chargement de Linux 2.6.32-5-amd64 …'
linux /boot/vmlinuz-2.6.32-5-amd64 root=UUID=0ae15c11-2855-4c94-8ddd-0a452232a2ab ro quiet
echo 'Chargement du disque mémoire initial …‘
initrd /boot/initrd.img-2.6.32-5-amd64
menuentry ‘Debian GNU/Linux, avec Linux 2.6.32-5-amd64 (mode de dépannage)’ --class debian --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.32-5-amd64 root=UUID=0ae15c11-2855-4c94-8ddd-0a452232a2ab ro single
echo 'Chargement du disque mémoire initial …'
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/30_os-prober
menuentry “Windows Vista (loader) (on /dev/sda1)” {
insmod part_msdos
insmod ntfs
set root=’(hd0,msdos1)‘
search --no-floppy --fs-uuid --set 425a8e8c5a8e7d03
chainloader +1
menuentry “Windows 7 (loader) (on /dev/sda2)” {
insmod part_msdos
insmod ntfs
set root=’(hd0,msdos2)'
search --no-floppy --fs-uuid --set 207464e77464c0e0
chainloader +1
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom ###[/code][/size]
Je ne comprends pas pourquoi mettre à jour, rafraîchir ou générer, ou bien encoreupdate-grub à ce “stade”?
J’ajoute une coquille de Thuban et bash.
