Hiberner et mettre en veille
C’est quoi ta carte video déjà?
Graphics : 256 MB ATI Mobility RADEON HD 3650
Pendant que j’étais sur la facture, j’ai aussi relevé :
Wireless : Intel WIFI Link 5100 (802.11 a/b/g/n 1X2) 1/2 MiniCard European
Et il y a des messages dans le syslog ou kern.log?
Voici après un ‘s2ram -f’ la fin du syslog
où il y a reprise par appui sur le bouton “power”, le DD repart mais pas d’écran, donc appui long sur le même bouton pour extinction forcée, (Ctrl Alt sup restant inactif cette fois) La reprise est à la fin en rouge à 00:14.
[quote]Mar 17 00:11:20 localhost kernel: [ 5104.089386] ricoh-mmc: Resuming.
Mar 17 00:11:20 localhost kernel: [ 5104.089400] ricoh-mmc: Controller is now disabled.
Mar 17 00:11:20 localhost kernel: [ 5104.089418] pci 0000:09:01.3: restoring config space at offset 0xf (was 0x200, writing 0x20a)
Mar 17 00:11:20 localhost kernel: [ 5104.089452] pci 0000:09:01.3: restoring config space at offset 0x4 (was 0x0, writing 0xfc101400)
Mar 17 00:11:20 localhost kernel: [ 5104.089462] pci 0000:09:01.3: restoring config space at offset 0x3 (was 0x804000, writing 0x804010)
Mar 17 00:11:20 localhost kernel: [ 5104.089474] pci 0000:09:01.3: restoring config space at offset 0x1 (was 0x2100000, writing 0x2100106)
Mar 17 00:11:20 localhost kernel: [ 5104.121364] ata6: SATA link down (SStatus 0 SControl 300)
Mar 17 00:11:20 localhost kernel: [ 5104.121397] ata5: SATA link down (SStatus 0 SControl 300)
Mar 17 00:11:20 localhost kernel: [ 5104.288243] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Mar 17 00:11:20 localhost kernel: [ 5104.319167] ata2.00: configured for UDMA/100
Mar 17 00:11:20 localhost kernel: [ 5104.340301] ata2: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x9 t4
Mar 17 00:11:20 localhost kernel: [ 5104.340306] ata2: irq_stat 0x40000001
Mar 17 00:11:20 localhost kernel: [ 5104.371096] ata2.00: configured for UDMA/100
Mar 17 00:11:20 localhost kernel: [ 5104.371106] ata2: EH complete
Mar 17 00:11:20 localhost kernel: [ 5104.768276] usb 1-6: reset high speed USB device using ehci_hcd and address 2
Mar 17 00:11:20 localhost kernel: [ 5105.232344] usb 7-1: reset low speed USB device using uhci_hcd and address 2
Mar 17 00:11:20 localhost kernel: [ 5105.546583] sd 0:0:0:0: [sda] Starting disk
Mar 17 00:11:20 localhost kernel: [ 5105.751497] tg3: eth0: Link is up at 100 Mbps, full duplex.
Mar 17 00:11:20 localhost kernel: [ 5105.751502] tg3: eth0: Flow control is off for TX and off for RX.
Mar 17 00:11:20 localhost kernel: [ 5106.864275] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar 17 00:11:20 localhost kernel: [ 5106.875944] ata1.00: configured for UDMA/133
Mar 17 00:11:20 localhost kernel: [ 5106.888282] ata1: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x9 t4
Mar 17 00:11:20 localhost kernel: [ 5106.888287] ata1: irq_stat 0x00400040, connection status changed
Mar 17 00:11:20 localhost kernel: [ 5106.893964] ata1.00: configured for UDMA/133
Mar 17 00:11:20 localhost kernel: [ 5106.893975] ata1: EH complete
Mar 17 00:11:20 localhost kernel: [ 5106.894123] sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors: (320 GB/298 GiB)
Mar 17 00:11:20 localhost kernel: [ 5106.894166] sd 0:0:0:0: [sda] Write Protect is off
Mar 17 00:11:20 localhost kernel: [ 5106.894172] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Mar 17 00:11:20 localhost kernel: [ 5106.894231] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Mar 17 00:11:20 localhost kernel: [ 5106.894309] sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors: (320 GB/298 GiB)
Mar 17 00:11:20 localhost kernel: [ 5106.894345] sd 0:0:0:0: [sda] Write Protect is off
Mar 17 00:11:20 localhost kernel: [ 5106.894350] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Mar 17 00:11:20 localhost kernel: [ 5106.894407] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Mar 17 00:11:20 localhost acpid: client 4450[0:0] has disconnected
Mar 17 00:11:20 localhost NetworkManager: (eth0): carrier now OFF (device state 1)
Mar 17 00:11:20 localhost NetworkManager: (eth0): carrier now ON (device state 1)
Mar 17 00:11:20 localhost kernel: [ 5106.899074] Restarting tasks … done.
Mar 17 00:11:20 localhost acpid: client connected from 4450[0:0]
Mar 17 00:11:20 localhost acpid: 1 client rule loaded
Mar 17 00:14:42 localhost kernel: imklog 3.20.4, log source = /proc/kmsg started.
Mar 17 00:14:42 localhost kernel: [ 0.000000] BIOS EBDA/lowmem at: 0009c400/0009c400
Mar 17 00:14:42 localhost kernel: [ 0.000000] Initializing cgroup subsys cpuset
Et que donne le s2ram si tu te mets en mode console?
Ben il me semble que j’avais déjà essayé mais je vais retenter.
Oui, exactement même chose : ça fonctionne mais l’écran ne se rallume pas.
Laisse tomber va ! ça marche bien avec s2disk, c’est déjà plus rapide que de reprendre complètement.
Ptet qu’un jour …
As tu lu ça:
[quote]Récemment beaucoup de machines rencontrées avec des puces graphiques ATI Radéon ne fonctionnent pas avec un framebuffer (habituellement elles plantent au sein du BIOS, la touche capslock ne fonctionne même pas après essai de reprise). Souvent ça marche avec “vga=0” et “s2ram -f -p -m” ou “s2ram -f -p -s”.
[modifier]
[quote=“fran.b”]As tu lu ça:
[modifier]
[/quote][/quote]Oui, avec -f -p -m ou — -s, j’avais déjà essayé, c’est toi qui me l’avais préconisé et il n’y avait pas eu de rslt.
Par contre, “vga=0”, à quel niveau il faudrait le placer, avant de faire la commande “s2ram -f -p -m” :question:
vga=0, ça fait quoi exactement :question:
J’ai remarqué que — parfois — quand je suis en mode console, les lettres scintillent, absence de netteté. Ce n’est pas souvent et très irrégulier.
vga=0 au boute consiste à désactiver le framebuffer sur les consoles, tu as dans ton menu.lst une ligne genre vga=791 que tu remplacesd par vga=0.
Ben apparemment, en natif, il est désactivé, non ?
[quote]## additional options to use with the default boot option, but not with the
alternatives
e.g. defoptions=vga=791 resume=/dev/hda5
defoptions=quiet
Ou alors il me faut quand même remplacer le ‘quiet’ par ‘0’ :question:
defoptions=vga=0 quiet
Ben tout essayé et résultat toujours le même :
modifié menu.lst
essai en mode console et en mode graphique
essai avec et sans sync
essai avec -f -p -m puis -f -p -s
essai sur secteur et sur batterie
essai en désinstallant KPowersave
Tout ça ds toutes les positions, même les pieds au mur et la tête en bas :smt005
Alors, je laisse tomber et je vais essayer d’avoir plus de chance avec le wifi mais ça non plus, ça n’est pas gagné.
En dernier ressort, j’essaierai d’installer une Kubuntu ou une Mandriva :unamused:
cela peut etre interessant d’installer une mandriva pour voir si techniquement ton materiel est supporter
mais il ne faut pas que tu nous quitte :smiley: :smiley:
Avec une mandriva il n’y a pas de risque : il est trop mal habitué …
Il n’ y aucune raison que je quitte Debian, si j’installe une Mandriva ou une Kubuntu, c’est juste pour faire l’essai mais même si ça marche chez eux et pas chez debian, je gueulerai, c’est sûr mais je resterai Debianiste.
concentre toi sur le WIFI, on verra ce truc après.
C’est exactement ce que j’ai décidé de faire.
Je laisse donc le “slip” en sommeil :mrgreen:
ben j’attends le message de wpa_supplicant alors :slightly_smiling:
Ok, je te réponds tout ça ce soir sur l’autre fil car cet AM, trop beau ==> dehors. :smt004
