Je ferais mieux de créer un autre topic. M’enfin bon. Quand je fais une connerie j’aime la faire jusqu’au bout.
J’ai donc suivi tes précieux conseils fran.b, malheureusement…
Voilà ce que j’ai fait:
- créer un dossier MathematicaPlayer sous /tmp
- installer checinstall
- puis:
[code]@:/tmp/MathematicaPlayer$ sudo checkinstall sh MathematicaPlayer.sh
checkinstall 1.6.1, Copyright 2002 Felipe Eduardo Sanchez Diaz Duran
This software is released under the GNU GPL.
The package documentation directory ./doc-pak does not exist.
Should I create a default set of package docs? [y]: y
Preparing package documentation…OK
*** No known documentation files were found. The new package
*** won’t include a documentation directory.
Please write a description for the package.
End your description with an empty line or EOF.
mathematicaplayer
**** Debian package creation selected ***
*** Warning: The package name “MathematicaPlayer” contains upper case
*** Warning: letters. dpkg might not like that so I changed
*** Warning: them to lower case.
This package will be built according to these values:
0 - Maintainer: [ root@bender ]
1 - Summary: [ mathematicaplayer ]
2 - Name: [ mathematicaplayer ]
3 - Version: [ 20071022 ]
4 - Release: [ 1 ]
5 - License: [ GPL ]
6 - Group: [ checkinstall ]
7 - Architecture: [ amd64 ]
8 - Source location: [ MathematicaPlayer ]
9 - Alternate source location: [ ]
10 - Requires: [ ]
Enter a number to change any of them or press ENTER to continue: 5
Enter the license type:
licence proprietaire (voir site officiel)
4 - Release: [ 1 ]
5 - License: [ licence proprietaire (voir site officiel) ]
10 - Requires: [ ]
Installing with sh MathematicaPlayer.sh…
========================= Installation results ===========================
Mathematica Player 6.0.1 for LINUX Installer Archive
Verifying archive integrity.
Extracting installer. …
Wolfram Mathematica Player Installer
Copyright © 1988-2007 Wolfram Research, Inc. All rights reserved.
WARNING: Mathematica and Mathematica Player are protected by copyright
law and international treaties. Unauthorized reproduction or distribution
may result in severe civil and criminal penalties and will be prosecuted
to the maximum extent possible under law.
Enter the installation directory, or press ENTER to select
/usr/local/Wolfram/MathematicaPlayer/6.0:
Now installing…
Type the directory path in which the Mathematica Player script(s) will
be created, or press ENTER to select /usr/local/bin:
Installation complete.
======================== Installation successful ==========================
grep: /var/tmp/YXZqfCiPMYKgmCrTWjSHa/newfile: Aucun fichier ou répertoire de ce type
Copying files to the temporary directory…OK
Striping ELF binaries and libraries…OK
Compressing man pages…OK
Building file list…OK
Building Debian package…OK
Installing Debian package…OK
Erasing temporary files…OK
Writing backup package…OK
Deleting temp dir…OK
Done. The new package has been installed and saved to
/tmp/MathematicaPlayer/mathematicaplayer_20071022-1_amd64.deb
You can remove it from your system anytime using:
dpkg -r mathematicaplayer
Mais ensuite C’est le drame:
*****@*****:~$ mathematicaplayer
xset: bad font path element (#422), possible causes are:
Directory does not exist or has wrong permissions
Directory missing fonts.dir
Incorrect font server address or syntax
MathematicaPlayer front end executable
/usr/local/Wolfram/MathematicaPlayer/6.0/SystemFiles/FrontEnd/Binaries/Linux-x86-64/MathematicaPlayer
not found. Your Mathematica Player installation may be incomplete
or corrupted.
/usr/local/Wolfram/MathematicaPlayer/6.0/SystemFiles/FrontEnd/Binaries/Linux/MathematicaPlayer
or corrupted.
Et effectivement il manque ces dossiers et fichiers…
