@Almtesh
joel@joel-k70ij:~$ sudo iw dev wlp2s0 scan
[sudo] Mot de passe de joel :
BSS 50:39:2f:4a:9c:90(on wlp2s0)
TSF: 15631038770 usec (0d, 04:20:31)
freq: 2412
beacon interval: 100 TUs
capability: ESS Privacy SpectrumMgmt ShortSlotTime RadioMeasure (0x1511)
signal: -35.00 dBm
last seen: 944 ms ago
Information elements from Probe Response frame:
SSID: Livebox-9C90
Supported rates: 1.0* 2.0* 5.5* 11.0* 18.0 24.0 36.0 54.0
DS Parameter set: channel 1
Country: FR Environment: Indoor/Outdoor
Channels [1 - 13] @ 20 dBm
Power constraint: 0 dB
TPC report: TX power: 17 dBm
ERP: <no flags>
Extended supported rates: 6.0 9.0 12.0 48.0
RSN: * Version: 1
* Group cipher: CCMP
* Pairwise ciphers: CCMP
* Authentication suites: PSK
* Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
BSS Load:
* station count: 0
* channel utilisation: 35/255
* available admission capacity: 0 [*32us]
Measurement Pilot Transmission:
* interval: 0 TUs
RM enabled capabilities:
Capabilities: 0x33 0x4f 0x01 0x00 0x00
Link Measurement
Neighbor Report
Beacon Passive Measurement
Beacon Active Measurement
Frame Measurement
Channel Load
Noise Histogram Measurement
Statistics Measurement
Transmit Stream/Category Measurement
AP Channel Report
Nonoperating Channel Max Measurement Duration: 0
Measurement Pilot Capability: 0
HT capabilities:
Capabilities: 0x9ac
HT20
SM Power Save disabled
RX HT20 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 7935 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT RX MCS rate indexes supported: 0-15
HT TX MCS rate indexes are undefined
HT operation:
* primary channel: 1
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* RIFS: 1
* HT protection: nonmember
* non-GF present: 0
* OBSS non-GF present: 1
* dual beacon: 0
* dual CTS protection: 0
* STBC beacon: 0
* L-SIG TXOP Prot: 0
* PCO active: 0
* PCO phase: 0
Extended capabilities:
* Extended Channel Switching
* BSS Transition
* Operating Mode Notification
WPS: * Version: 1.0
* Wi-Fi Protected Setup State: 2 (Configured)
* Response Type: 3 (AP)
* UUID: 00000000-0000-0000-0000-000000000000
* Manufacturer: Sagemcom
* Model: SagemcomFast5656_OFR
* Model Number: SG_LBF_1.2.1
* Serial Number: IA22172FF
* Primary Device Type: 6-0050f204-1
* Device name: Livebox Fibre
* Config methods: Ethernet, Label
* RF Bands: 0x1
* Version2: 2.0
WMM: * Parameter version 1
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
BSS 44:a6:1e:a1:6a:86(on wlp2s0)
TSF: 190528875449 usec (2d, 04:55:28)
freq: 2437
signal: -66.00 dBm
last seen: 648 ms ago
SSID: Livebox-6A86
DS Parameter set: channel 6
TPC report: TX power: 16 dBm
ERP: <no flags>
RSN: * Version: 1
BSS Load:
* station count: 0
* channel utilisation: 39/255
Capabilities: 0x32 0x00 0x00 0x00 0x00
Neighbor Report
HT capabilities:
Capabilities: 0x1ad
RX LDPC
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT RX MCS rate indexes supported: 0-23
HT operation:
* primary channel: 6
* RIFS: 1
* HT protection: no
* non-GF present: 0
* OBSS non-GF present: 0
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
WPS: * Version: 1.0
* UUID: 34344136-3145-f131-f641-383634344136
* Model: SagemcomFast5360_MIB4
* Model Number: SG_LB4_1.2.0
* Serial Number: AN20055FF
* Device name: Livebox 4
* RF Bands: 0x1
* Version2: 2.0
BSS 70:fc:8f:3d:7e:b4(on wlp2s0)
TSF: 585260144991 usec (6d, 18:34:20)
freq: 2437
beacon interval: 120 TUs
capability: ESS Privacy ShortSlotTime RadioMeasure (0x1411)
signal: -89.00 dBm
last seen: 692 ms ago
SSID: Freebox_2629
Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
TIM: DTIM Count 0 DTIM Period 2 Bitmap Control 0x0 Bitmap[0] 0x4
ERP: Barker_Preamble_Mode
Extended supported rates: 24.0 36.0 48.0 54.0
RSN: * Version: 1
BSS Load:
* station count: 4
* channel utilisation: 51/255
Capabilities: 0x72 0x00 0x00 0x00 0x00
Neighbor Report
Beacon Table Measurement
HT capabilities:
Capabilities: 0xee
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
Minimum RX AMPDU time spacing: No restriction (0x00)
HT TX/RX MCS rate indexes supported: 0-23, 32
HT operation:
* RIFS: 0
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
* SSID List
BSS 50:39:2f:3e:9f:20(on wlp2s0)
TSF: 317129640241 usec (3d, 16:05:29)
freq: 2462
signal: -87.00 dBm
last seen: 208 ms ago
SSID: Livebox-9F20
DS Parameter set: channel 11
RSN: * Version: 1
BSS Load:
* station count: 1
* channel utilisation: 36/255
* interval: 0 TUs
Link Measurement
Neighbor Report
Frame Measurement
Channel Load
AP Channel Report
HT capabilities:
Capabilities: 0x9ac
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
HT operation:
* primary channel: 11
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
WPS: * Version: 1.0
* Serial Number: IA22131FF
* RF Bands: 0x1
* Version2: 2.0
BSS 34:49:5b:df:22:60(on wlp2s0)
TSF: 2291076836730 usec (26d, 12:24:36)
freq: 2412
capability: ESS Privacy ShortSlotTime (0x0411)
signal: -89.00 dBm
last seen: 1004 ms ago
SSID: Bbox-C1EDD1A7
ERP: <no flags>
RSN: * Version: 1
BSS Load:
* station count: 0
* channel utilisation: 31/255
* interval: 0 TUs
HT capabilities:
Capabilities: 0x8bc
HT20
RX Greenfield
RX HT20 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 0
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
WPS: * Version: 1.0
* UUID: 111242c3-4f87-50b9-4fcb-c503bbf806af
* Manufacturer: Broadcom
* Model: Broadcom
* Model Number: 123456
* Serial Number: 1234
* Device name: BroadcomAP
* Config methods: Label, Display
* RF Bands: 0x1
* Version2: 2.0
WPA: * Version: 1
* u-APSD
BSS 76:79:70:76:8c:84(on wlp2s0)
TSF: 2291163955570 usec (26d, 12:26:03)
freq: 2462
signal: -88.00 dBm
last seen: 392 ms ago
SSID: papaquenamel
Supported rates: 1.0* 2.0* 5.5* 11.0* 9.0 18.0 36.0 54.0
Extended supported rates: 6.0 12.0 24.0 48.0
AP Channel Report:
* operating class: 32
* channel(s): 1 2 3 4 5 6 7
AP Channel Report:
* operating class: 33
* channel(s): 5 6 7 8 9 10 11
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0xc
HT capabilities:
Capabilities: 0x106e
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
HT RX MCS rate indexes supported: 0-15, 32
HT operation:
* RIFS: 0
* HT protection: 20 MHz
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* HT Information Exchange Supported
WPA: * Version: 1
* Group cipher: TKIP
* Pairwise ciphers: TKIP CCMP
BSS Load:
* station count: 1
* channel utilisation: 74/255
* available admission capacity: 31250 [*32us]
BSS 76:79:70:76:8c:85(on wlp2s0)
TSF: 2291163958075 usec (26d, 12:26:03)
freq: 2462
signal: -90.00 dBm
SSID:
AP Channel Report:
AP Channel Report:
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0x0
HT capabilities:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
HT operation:
* RIFS: 0
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
RSN: * Version: 1
* Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
BSS Load:
* station count: 1
BSS 76:79:70:76:8c:86(on wlp2s0)
TSF: 2291163960437 usec (26d, 12:26:03)
freq: 2462
signal: -86.00 dBm
last seen: 388 ms ago
SSID: FreeWifi_secure
AP Channel Report:
AP Channel Report:
HT capabilities:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
HT operation:
* RIFS: 0
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
WPA: * Version: 1
* Authentication suites: IEEE 802.1X
BSS Load:
* station count: 1
BSS cc:2d:1b:b1:43:fe(on wlp2s0)
TSF: 30381158814 usec (0d, 08:26:21)
freq: 2412
signal: -91.00 dBm
last seen: 1044 ms ago
SSID: HG BG 10 2021 2G
TIM: DTIM Count 0 DTIM Period 3 Bitmap Control 0x0 Bitmap[0] 0x0
RSN: * Version: 1
* Pairwise ciphers: CCMP TKIP
BSS Load:
* station count: 1
* channel utilisation: 53/255
Capabilities: 0x32 0x08 0x01 0x00 0x00
Neighbor Report
AP Channel Report
HT capabilities:
Capabilities: 0x8bc
HT20
RX Greenfield
RX HT20 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
HT operation:
* RIFS: 0
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
WPS: * Version: 1.0
WPA: * Version: 1
* u-APSD
BSS 6c:ba:b8:0a:d9:90(on wlp2s0)
TSF: 2291071590801 usec (26d, 12:24:31)
freq: 2412
signal: -84.00 dBm
last seen: 1028 ms ago
SSID: \x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00
RSN: * Version: 1
BSS Load:
* station count: 1
* channel utilisation: 34/255
* interval: 0 TUs
HT capabilities:
Capabilities: 0x8bc
HT20
RX Greenfield
RX HT20 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 1
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
WPS: * Version: 1.0
* Version2: 2.0
WPA: * Version: 1
* u-APSD
BSS ec:6c:9a:39:b0:c2(on wlp2s0)
TSF: 1210669158809 usec (14d, 00:17:49)
freq: 2437
signal: -92.00 dBm
last seen: 704 ms ago
SSID: Livebox-D910
Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0* 9.0* 12.0* 18.0*
TIM: DTIM Count 2 DTIM Period 3 Bitmap Control 0x0 Bitmap[0] 0x0
Channels [1 - 13] @ 30 dBm
TPC report: TX power: 20 dBm
Extended supported rates: 24.0* 36.0* 48.0* 54.0*
BSS Load:
* station count: 2
* channel utilisation: 42/255
Capabilities: 0x73 0x00 0x01 0x00 0x00
Link Measurement
Neighbor Report
AP Channel Report
HT capabilities:
Capabilities: 0x19ad
RX LDPC
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
Minimum RX AMPDU time spacing: 16 usec (0x07)
HT operation:
* RIFS: 0
* HT protection: no
* non-GF present: 0
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
RSN: * Version: 1
WPS: * Version: 1.0
* Version2: 2.0
* BSS Transition
BSS 00:06:91:c8:29:b0(on wlp2s0)
TSF: 2291132504592 usec (26d, 12:25:32)
freq: 2462
signal: -94.00 dBm
last seen: 360 ms ago
SSID: SFR_29AF
RSN: * Version: 1
* Capabilities: 16-PTKSA-RC 1-GTKSA-RC MFP-capable (0x008c)
BSS Load:
* station count: 0
* channel utilisation: 71/255
Neighbor Report
AP Channel Report:
* operating class: 128
* channel(s): 100
HT capabilities:
Capabilities: 0x1ad
RX LDPC
HT20
RX HT20 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
HT RX MCS rate indexes supported: 0-31
HT operation:
* RIFS: 1
* HT protection: no
* non-GF present: 0
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* Event
* BSS Transition
* Interworking
* QoS Map
* Reserved Reserved Channel Schedule Management
* Reserved Channel Schedule Management
* 6
802.11u Interworking:
Network Options: 0x0
Network Type: 0 (Private)
802.11u Advertisement:
Query Response Info: 0x7f
Query Response Length Limit: 127
ANQP
WPS: * Version: 1.0
* UUID: b45ea7c6-7577-ad34-9241-fd2fb545a995
* Manufacturer: AlticeLabs
* Model: AlticeLabs GR120DG
* Model Number: GR120DG
* Serial Number: 5054494E91C829AF
* Device name: FiberGateway
* Config methods: Display
* RF Bands: 0x3
* Version2: 2.0
WPA: * Version: 1
* u-APSD
BSS e4:9e:12:10:b5:77(on wlp2s0)
TSF: 856185062751 usec (9d, 21:49:45)
freq: 2472
signal: -94.00 dBm
last seen: 140 ms ago
SSID: BOX_embu
DS Parameter set: channel 13
TIM: DTIM Count 0 DTIM Period 2 Bitmap Control 0x0 Bitmap[0] 0x0
RSN: * Version: 1
BSS Load:
* station count: 0
* channel utilisation: 62/255
Neighbor Report
HT capabilities:
Capabilities: 0xec
HT20
RX HT20 SGI
RX HT40 SGI
TX STBC
No RX STBC
No DSSS/CCK HT40
HT operation:
* primary channel: 13
* RIFS: 0
* HT protection: no
* non-GF present: 0
* dual beacon: 0
* STBC beacon: 0
* PCO active: 0
* PCO phase: 0
* BSS Transition
* SSID List
WPA: * Version: 1
joel@joel-k70ij:~$
Désolé pour la taille du copier coller, il y a moyen de réduire ?
@Verner : oui je suis bien sous Bullseye, en simple boot
joel@joel-k70ij:~$ /sbin/iwlist wlp2s0 channel
wlp2s0 14 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 14 : 2.484 GHz
joel@joel-k70ij:~$
joel@joel-k70ij:~$ /sbin/iwlist wlp2s0 scanning |grep ESSID
joel@joel-k70ij:~$
